Stu
September 6, 2019, 2:01pm
1
Hello all,
I’ve had this idea for a while now but only just had the time to start it.
I wanted to replicate the Honeywell Evohome controller interface with function and monitor my Viessmann gas boiler.
The basis for both interfaces is the picture element card.
Stu
![evo_lov|542x500](upload://gR
RiUrmBdq77mpmswDU5C0SUCKT.gif)
Looks great, do you have this in a repo as I’d love to copy the evohome piece.
Stu
November 3, 2019, 10:25am
3
I don’t have a repo. But I’ll leave the config here;
Lovelace images;
Shared with Dropbox
#configuration.yaml
##### Evohome Temperature Colours #####
sensors:
evohome_colour_lounge:
friendly_name: Evohome Lounge Colour
value_template: >-
{%- if (states.sensor.evo_living_room_set_temp.state | int <= 5) -%}
grey
{%- elif (states.sensor.evo_living_room_set_temp.state | int > 5) and (states.sensor.evo_living_room_set_temp.state | int <= 15.4) -%}
blue
{%- elif (states.sensor.evo_living_room_set_temp.state | int > 15.5) and (states.sensor.evo_living_room_set_temp.state | int <= 18.8) -%}
green
{%- elif (states.sensor.evo_living_room_set_temp.state | int > 18.9) and (states.sensor.evo_living_room_set_temp.state | int <= 21.4) -%}
lightorange
{%- elif (states.sensor.evo_living_room_set_temp.state | int > 21.5) and (states.sensor.evo_living_room_set_temp.state | int <= 24.9) -%}
orange
{%- elif (states.sensor.evo_living_room_set_temp.state | int >= 25) -%}
red
{%- endif -%}
##### evohome preset icons ######
sensors:
evo_living_current_preset:
friendly_name: Living Room Current Preset
value_template: >-
{%-if (states.climate.living_room.attributes["preset_mode"] == "none") -%}
None
{%- elif (states.climate.living_room.attributes["preset_mode"] == "away") -%}
Away
{%- elif (states.climate.home.state == "off") -%}
Off
{%- elif (states.climate.living_room.attributes["preset_mode"] == "Custom") -%}
Custom
{%- elif (states.climate.living_room.attributes["preset_mode"] == "eco") -%}
Eco
{%- elif (states.climate.living_room.attributes["preset_mode"] == "home") -%}
Home
{%- elif (states.climate.living_room.attributes["preset_mode"] == "temporary") -%}
Temporary
{%- elif (states.climate.living_room.attributes["preset_mode"] == "permanent") -%}
Perminent
{%- endif -%}
entity_picture_template: >-
/local/icons/evohome/none.png
/local/icons/evohome/away_action.png
/local/icons/evohome/temp_overide.png
/local/icons/evohome/perm_overide.png
/local/icons/evohome/custom.png
/local/icons/evohome/eco.png
/local/icons/evohome/off.png
/local/icons/evohome/home.png
{% else %}
{% endif %}
sensors:
evo_controller_current_mode:
friendly_name: Evohome Controller Preset Mode
value_template: >-
{%-if (states.climate.home.attributes["preset_mode"] == "none") -%}
None
{%- elif (states.climate.home.attributes["preset_mode"] == "away") -%}
Away
{%- elif (states.climate.home.attributes["preset_mode"] == "Custom") -%}
Custom
{%- elif (states.climate.home.attributes["preset_mode"] == "eco") -%}
Eco
System_Off
{%- elif (states.climate.home.attributes["preset_mode"] == "home") -%}
Home
{% else %}
Null
{%- endif -%}
/local/images/lovelace/evohome/quick_actions.png
/local/images/lovelace/evohome/action_away.png
/local/images/lovelace/evohome/action_custom.png
/local/images/lovelace/evohome/action_eco.png
/local/images/lovelace/evohome/action_home.png
/local/images/lovelace/evohome/action_off.png
{% else %}
{% endif %}
###### Evohome Date + Time #####
sensors:
date_format_dd_mon_yyyy:
entity_id: sensor.date
friendly_name: 'Date Format DD-Mon-YYYY'
value_template: '{{ now().strftime("%d %b, %Y")}}'
sensors:
evohome_date:
friendly_name: 'Evohome Date Format'
value_template: '{{ states.sensor.weekday.state}}, {{ now().strftime("%d %B") }}'
###### Evohome Temps #####
sensors:
evo_living_room_current_temp:
friendly_name: Living Room Current Temperature
unit_of_measurement: °
value_template: '{{state_attr("climate.living_room", "current_temperature")}}'
sensors:
evo_living_room_set_temp:
friendly_name: Living Room Set Temperature
value_template: '{{state_attr("climate.living_room", "temperature")}}'
sensors:
evo_living_room_setpointstatus:
friendly_name: Living Room Setpoint
value_template: "{{ state_attr('climate.living_room', 'status').setpointStatus.setpointMode }}"
sensors:
evo_outside_temp:
friendly_name: Evohome Outside Temp
value_template: 'Outside {{ states.sensor.dark_sky_temperature.state }}'
##### Evohome HR92 ######
sensors:
evohome_livingroom_hr92:
friendly_name: Living Room HR92
value_template: >-
{% if state_attr('climate.living_room', 'status').active_faults[0].faultType == 'TempZoneActuatorLowBattery' %}
Low_Battery
{% else %}
Normal
{% endif %}
/local/icons/evohome/low_battery.png
{% else %}
{% endif %}
#customize.yaml
script.1567201872207:
friendly_name: Turn Off
entity_picture: /local/icons/evohome/off_blue.png
script.1567202166957:
friendly_name: Away
entity_picture: /local/icons/evohome/away_action_blue.png
script.1567427338437:
friendly_name: Eco
entity_picture: /local/icons/evohome/eco_blue.png
script.1567427367682:
friendly_name: Day Off
entity_picture: /local/icons/evohome/home_blue.png
script.1567503322803:
friendly_name: Cancel
entity_picture: /local/icons/evohome/reset.png
##scripts.yaml
'1567201872207':
alias: Evohome Off
sequence:
- data:
entity_id: climate.home
hvac_mode: 'off'
service: climate.set_hvac_mode
'1567202166957':
alias: Evohome Away
sequence:
- data:
preset_mode: away
service: climate.set_preset_mode
'1567427338437':
alias: Evohome Preset Eco
sequence:
- data:
preset_mode: eco
'1567427367682':
alias: Evohome Preset Home
sequence:
- data:
preset_mode: home
'1567503322803':
alias: Evohome Reset Preset
sequence:
- data:
preset_mode: Reset
### Control to switch the lovelace evo controller pages
input_boolean:
evo_controller_switch:
name: Evohome Controller Navagation
initial: on
Cheers Stu
Stu
November 3, 2019, 10:28am
4
and the lovelace card config…
cards:
- elements:
- conditions:
- entity: sensor.evohome_livingroom_hr92
state: Low_Battery
- entity: input_boolean.evo_controller_switch
state: 'on'
elements:
style:
'--iron-icon-height': 13px
'--iron-icon-width': 13px
'--paper-item-icon-color': red
left: 34%
top: 34%
transform: 'translate(-45%, -45%) scale(0.3, 0.3)'
type: state-icon
type: conditional
- conditions:
- entity: sensor.evohome_top_landing_hr92
state: Low_Battery
state: 'off'
elements:
style:
left: 34%
top: 34%
type: state-icon
type: conditional
- conditions:
- entity: sensor.evohome_kitchen_hr92
state: Low_Battery
state: 'on'
elements:
style:
'--iron-icon-height': 12px
'--iron-icon-width': 12px
left: 51.5%
top: 34%
type: state-icon
type: conditional
- conditions:
state: 'on'
- entity: sensor.evohome_bed1_hr92
state: Low_Battery
elements:
style:
left: 69%
top: 34%
type: state-icon
type: conditional
- conditions:
- entity: sensor.evohome_grd_flr_hall_hr92
state: Low_Battery
state: 'on'
elements:
style:
left: 69%
top: 56%
type: state-icon
type: conditional
- conditions:
- entity: sensor.evohome_bed2_hr92
state: Low_Battery
state: 'on'
elements:
style:
left: 51.5%
top: 56%
type: state-icon
type: conditional
- conditions:
- entity: sensor.evohome_bed3_hr92
state: Low_Battery
state: 'on'
elements:
style:
left: 34%
top: 56%
type: state-icon
type: conditional
- entity: sensor.time
style:
color: white
font-size: 65%
left: 80%
top: 18%
type: state-label
- entity: sensor.evo_outside_temp
style:
color: White
font-size: 55%
left: 24%
top: 18%
type: state-label
- entity: sensor.evohome_date
style:
color: White
font-size: 65%
left: 50%
top: 18%
suffix: ' '
type: state-label
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_lounge
image: /local/images/lovelace/evohome/evo_room-off.png
state_image:
blue: /local/images/lovelace/evohome/lounge/evo_LR-blue-01.png
green: /local/images/lovelace/evohome/lounge/evo_LR-green-01.png
grey: /local/images/lovelace/evohome/lounge/evo_LR-grey-01.png
lightorange: /local/images/lovelace/evohome/lounge/evo_LR-light_orange-01.png
orange: /local/images/lovelace/evohome/lounge/evo_LR-orange-01.png
red: /local/images/lovelace/evohome/lounge/evo_LR-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'off'
elements:
- entity: sensor.evohome_colour_toplanding
state_image:
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_kitchen
state_image:
blue: /local/images/lovelace/evohome/kitchen/evo_KT-blue-01.png
green: /local/images/lovelace/evohome/kitchen/evo_KT-green-01.png
grey: /local/images/lovelace/evohome/kitchen/evo_KT-grey-01.png
lightorange: >-
/local/images/lovelace/evohome/kitchen/evo_KT-light_orange-01.png
orange: /local/images/lovelace/evohome/kitchen/evo_KT-orange-01.png
red: /local/images/lovelace/evohome/kitchen/evo_KT-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_ghall
state_image:
blue: /local/images/lovelace/evohome/g_hall/evo_GH-blue-01.png
green: /local/images/lovelace/evohome/g_hall/evo_GH-green-01.png
grey: /local/images/lovelace/evohome/g_hall/evo_GH-grey-01.png
lightorange: /local/images/lovelace/evohome/g_hall/evo_GH-light_orange-01.png
orange: /local/images/lovelace/evohome/g_hall/evo_GH-orange-01.png
red: /local/images/lovelace/evohome/g_hall/evo_GH-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_bed3
state_image:
blue: /local/images/lovelace/evohome/bed3/evo_B3-blue-01.png
green: /local/images/lovelace/evohome/bed3/evo_B3-green-01.png
grey: /local/images/lovelace/evohome/bed3/evo_B3-grey-01.png
lightorange: /local/images/lovelace/evohome/bed3/evo_B3-light_orange-01.png
orange: /local/images/lovelace/evohome/bed3/evo_B3-orange-01.png
red: /local/images/lovelace/evohome/bed3/evo_B3-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_bed2
state_image:
blue: /local/images/lovelace/evohome/bed2/evo_B2-blue-01.png
green: /local/images/lovelace/evohome/bed2/evo_B2-green-01.png
grey: /local/images/lovelace/evohome/bed2/evo_B2-grey-01.png
lightorange: /local/images/lovelace/evohome/bed2/evo_B2-light_orange-01.png
orange: /local/images/lovelace/evohome/bed2/evo_B2-orange-01.png
red: /local/images/lovelace/evohome/bed2/evo_B2-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evohome_colour_bed1
state_image:
blue: /local/images/lovelace/evohome/bed1/evo_B1-blue-01.png
green: /local/images/lovelace/evohome/bed1/evo_B1-green-01.png
grey: /local/images/lovelace/evohome/bed1/evo_B1-grey-01.png
lightorange: /local/images/lovelace/evohome/bed1/evo_B1-light_orange-01.png
orange: /local/images/lovelace/evohome/bed1/evo_B1-orange-01.png
red: /local/images/lovelace/evohome/bed1/evo_B1-red-01.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
type: image
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed1_current_preset
style:
'--paper-item-icon-color': white
left: 82%
top: 38.8%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed2_current_preset
style:
left: 47%
top: 60.4%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed3_current_preset
style:
left: 65%
top: 60.4%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_gfhall_current_preset
style:
left: 82%
top: 60.4%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_kitchen_current_preset
style:
left: 65%
top: 38.8%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_living_current_preset
style:
left: 47%
top: 38.8%
type: state-icon
type: conditional
- entity: sensor.evo_controller_current_mode
image: /local/images/lovelace/evohome/quick_actions.png
state_image:
Away: /local/images/lovelace/evohome/action_away.png
Custom: /local/images/lovelace/evohome/action_custom.png
Eco: /local/images/lovelace/evohome/action_eco.png
Home: /local/images/lovelace/evohome/action_home.png
None: /local/images/lovelace/evohome/quick_actions.png
'Null': /local/images/lovelace/evohome/quick_actions.png
System_Off: /local/images/lovelace/evohome/action_off.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Quick Actions
card:
type: entities
entities:
- script.1567201872207
- script.1567202166957
- script.1567427338437
- script.1567427367682
- script.1567503322803
deviceID:
- this
type: image
- conditions:
state: 'off'
elements:
- entity: sensor.evo_landing_current_preset
style:
left: 47%
top: 38.8%
type: state-icon
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed1_current_temp
style:
color: Grey
font-size: 130%
left: 75%
top: 30%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed2_current_temp
style:
color: Grey
font-size: 130%
left: 42%
top: 52%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed3_current_temp
style:
color: Grey
font-size: 130%
left: 58%
top: 52%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_living_room_current_temp
style:
color: Grey
font-size: 130%
left: 42%
top: 30%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'off'
elements:
- entity: sensor.evo_top_landing_current_temp
style:
color: Grey
font-size: 130%
left: 42%
top: 30%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_gfhall_current_temp
style:
color: Grey
font-size: 130%
left: 76%
top: 52%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_kitchen_current_temp
style:
color: Grey
font-size: 130%
left: 58%
top: 30%
tap_action:
action: more-info
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_living_room_set_temp
style:
color: white
font-size: 50%
left: 35.5%
top: 39.5%
tap_action:
service_data:
card:
entity: climate.living_room
type: thermostat
deviceID:
- this
title: Set Temperature
type: state-label
type: conditional
- conditions:
state: 'off'
elements:
- entity: sensor.evo_top_landing_set_temp
style:
color: white
font-size: 50%
left: 35.5%
top: 39.5%
tap_action:
service_data:
card:
entity: climate.top_landing
type: thermostat
deviceID:
- this
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_kitchen_set_temp
style:
color: white
font-size: 53%
left: 53.5%
top: 39.5%
tap_action:
service_data:
card:
entity: climate.kitchen
type: thermostat
deviceID:
- this
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_gfhall_set_temp
style:
color: white
font-size: 53%
left: 71%
top: 61%
tap_action:
service_data:
card:
entity: climate.grd_flr_hall
type: thermostat
deviceID:
- this
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed1_set_temp
style:
color: white
font-size: 53%
left: 71%
top: 39.5%
tap_action:
service_data:
card:
entity: climate.bedroom_1
type: thermostat
deviceID:
- this
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed3_set_temp
style:
color: white
font-size: 53%
left: 53.3%
top: 61%
tap_action:
service_data:
card:
entity: climate.bedroom_3
type: thermostat
deviceID:
- this
type: state-label
type: conditional
- conditions:
state: 'on'
elements:
- entity: sensor.evo_bed2_set_temp
style:
color: white
font-size: 53%
left: 35.5%
top: 61%
tap_action:
service_data:
card:
entity: climate.bedroom_2
type: thermostat
deviceID:
- this
type: state-label
type: conditional
image: /local/images/lovelace/evohome/evo_main_controller-switch01.png
state_image:
'off': /local/images/lovelace/evohome/evo_main_controller-switch02.png
'on': /local/images/lovelace/evohome/evo_main_controller-switch01.png
style:
left: 76%
top: 68%
width: 14%
tap_action:
action: toggle
type: image
image: /local/images/lovelace/evohome/evo_main_controller-03.png
state_image:
'off': /local/images/lovelace/evohome/evo_main_controller-04.png
'on': /local/images/lovelace/evohome/evo_main_controller-03.png
type: picture-elements
type: 'custom:vertical-stack-in-card'
Brilliant! Thanks will have a go at this tonight
getting there slowly… “input_boolean.evo_controller_switch”? is that just son you can enable/dasable the functionality?. thanks again.
Stu
November 4, 2019, 9:08am
7
The switch is to allow you to toggle between the two controller pages which displays the different zones by way of the conditional option of the picture_elements card.
I’ve updated the post with the config code to include this input boolean.
taz68
(Hans)
November 7, 2019, 1:53pm
8
Which version of home assistant are you running?
I changed your config to my environment, but whatever I try, I cannot get the popup-card working.
I am running 0.101.2 of HA
Stu
November 7, 2019, 2:29pm
9
I am currently on 0.101.
The pop ups work fine for me.
If I have a chance I’ll upgrade to see if I also have the issue.
My popup cards aren’t working too. I believe since 0.101.2.
I found out that the plugin is deprecated:
You should use browser_mod instead:
Stu
November 7, 2019, 9:18pm
12
Lovelace code to post 4 now updated for the browser_mod.popup
Cheers,
Stu
Stefan_U
(Stefan Uytterhoeven)
June 9, 2021, 7:07pm
13
Any progress of changes ?
