Lovelace Fan Control Entity Row Error
I’ve installed https://github.com/finity69x2/fan-control-entity-row using HACS
I have the Lovelace UI Resources Set exactly where the JS file is located
But i still get this error
2
My Card Config
entities:
  - entity: switch.sonoff_10003085bd
  - entity: light.sonoff_1000994e05_1
  - entity: fan.sonoff_1000994e05
    type: 'custom:fan-control-entity-row'
show_header_toggle: true
title: Office
type: entities
Change your resource url to:
/hacsfiles/fan-control-entity-row/fan-control-entity-row.js
Yes, from the installation instructions at the link you posted above:
…making sure you note the “url:” section for the resources addition.
and it says in the pop-up in HACS when you install the card:
… When installed, this will be located in '/config/www/community/fan-control-entity-row'
When you add this to your lovelace configuration use this
url: /hacsfiles/fan-control-entity-row/fan-control-entity-row.js
type: module
So the info was all there.
Do you even need to manually add the resources anymore? When I add a custom card from the HACS, the resource shows up automatically. All i need to do is reopen the browser and there it is.
Here’s the auto populated resource on my end:
Screen Shot 2020-08-08 at 11.19.17 AM
I don’t think you do if you use lovelace in storage mode. I don’t so I can’t completely verify that.
But the above instructions will still work, I believe, in either mode.
