Is there a way to hide or display cards based on some rules?
For example when the alarm.panel is “armed” - display an image card from the camera and also an entity card containing the statuses of motion sensors, door sensors and also maybe a map where everybody is.
Well entity filter takes several entities ( let’s say a,b,c,d) and their states and displays them accordingly like a,c,d
What I want to accomplish is to display or not display b,c,d according to the state of a.
P.S. I know about group visibility from the automation, but in my experience it is working unreliably. So i am hoping it could be solved via the lovelace UI
Should it be vertical-stack and horizontal-stack? You have vertical**_stack** and horizontal**_stack**.
Also the indentations seem off after the vertical_stack/cards, I’ve something like this:
In your example you have light.dining and an entity filter of “on”
So if the light.dining will be on can a card be displayed below with the following enitites
Movement dining = off
Dishwasher = on
Kitchen air cond = cooling 22C
Kitchen media player idle
And when you switch off light.dining to off all the above entities and their cards will be hidden until you switch on light.dining once again?
Picture glance might be an option. But looking at the documentation it seems that the entities dispalyed in the picture glance will be the same as in the entity filter conditions? Am i wrong?
Actually, you are right, type: entity-filter card only show entities from the defined list with indicated state_filter, no matter what card-style follows.
Sorry, for the confusion.
Well hopefully it will be integrated soon.Will try to open a feature request.
As a usecase
For example you can have a big block of controls for the av system. Like volume, Different EQ, options and there is no point in displaying it unless the receiver is on.
Sorry to bring this up again but I think my use-case is very similar if not identical to the @moskovskiy82
What I want to acheive is show the time home / work (they are currently in a group) based on a sensor’s state
Is there any solution in Lovelace for this ?
