Lovelace: Flexible Horseshoe Card (Donut graph, flexible layout, multiple entities, actions & animations), including next-gen experimental examples
Is the project still alive? I can’t make it work at all
Color name between ‘’ works
Is it possible to change font color? I have tested several metods and nothing works.
the card is great and works like a charm. I use it mainly to display solar and electric car battery status.
The only limitation I have: instead of an icon I want to display an svg or png image. Any idea if feasible and how to do that?
Last Update CORE, Stop working card… solution?
The developer fixed it, and it works again, thank you!
The same here.
Stopped working after CORE/os upgrade.
Getting ‘ Custom element doesn’t exist’ error on the dashboard
Exactly the same problem since yesterday, after reboot the card cannot be found in lovelace. Tried to remove and HACS re-install, error persists.
Really annoying after all the work spent especially on this great UI component. Any ideas how to recover?
Maybe this will help:
Great, that solved it! Thx a lot
I’m losing my mind here. How does one get this card installed? Every single thing I’ve tried just gets me nowhere.
  1. I’ve installed through HACS and tried adding the resources to the resource list (dashboard, menu, resources, etc.). Nothing
  2. I’ve downloaded it separately and put it in the custom components folder and added the references to the resource list (even tried in the configuration.yaml). Nothing
Can anyone explain the process in detail and with examples, because I must be missing something obvious. Every other custom card simply installs and is usable.
Please?
hi all,
i’ve been maintaining HA on two of my friends sailingboats. both have they horseshoe card on the dash. does this card only works when there is an active internet connection ? both have lte routers and when offshore they lose connection and they go local. got the ‘complaint’ that this card gave an error when offshore. might be related to the loss of an internet connection ?
many thanks
Yes, it seems to be dead because it doesn’t work for me either, and the github issues are similar. Seems to be breaking with every Home Assistant update.
