Lovelace: Flexible Horseshoe Card
Flexible looks-like-a-horseshoe card for Home Assistant Lovelace UI
The Lovelace view of the above examples is in the repository in the examples folder.
So you can see how these layouts are done
Introduction
The flexible horseshoe card can display data from entities and attributes from the sensor and other domains. It displays the current state and for the primary entity it fills the horseshoe with a color depending on the min and max values of the state and the configured color stops and styling.
The main perk of this card is it’s flexibility. It is able to position a number of things where YOU want it using a layout specification for each object you want on the card:
| Feature | Description |
| Any number of entities | For each entity, the attribute, units, icon, name, area and tap action can be specified. There is currently no limit imposed on the number of entities in this card. I’m using max. 3 entities in the examples, but there is no problem using more. |
| Any number of circles, horizontal and vertical lines | To function as a divider between values or background for values. |
| The layout of the card | You can specify each object with a relative position on the card |
| Animations, dynamic behaviour | You can specify what happens if an entity changes state like change color, or execute a CSS animation. There are predefined animations. |
| Several ways to color the horseshoe | From single, fixed color, to a gradient depending on a list of colorstops |
| Actions | Handle click actions per entity to for instance switch a light on/off
Notes
This is my first card ever.
Visit the Github repository for installation and usage instructions. I did my best to describe all the options, and provide 12 examples which include the Lovelace View I used to test this card.
I’m pretty curious what other people can make with this flexible card!
I’m currently on holiday, so I won’t be visiting the forum every hour
