If you put it inside a grid then it will auto resize to that cell. This is the only way i got it working.
Thanks. My full tablet code is here Full config for my Home Assistant photo frame dashboard Ā· GitHub
Iām certain your code is good. Further reading in the forum here reveals others having the problem I have. Prior to your code, I had the card not configured error. Now I just get a blank card, as others have had. I think it is not installed properly, and unable to draw the card from the python script.
You may be right. Best to try fresh and reinstall again. The card wouldnāt load for me too with the different apostrophe you had; weird. Good luck, report back when you get it going and how you fixed it.
All entities must exist else the card is not drawn. I think it also only reads states not attributes.
Got it working with Card-mod plugin.
https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card/120744
type: 'custom:flex-horseshoe-card'
style: |
ha-card {
height: 90px !important;
entities:
- entity: sensor.family_room_temperature
decimals: 1
area: ''
unit: °C
tap_action:
action: more-info
- entity: switch.family_room
icon: 'mdi:lightbulb'
tap_action:
action: call-service
service: switch.toggle
service_data:
entity_id: switch.family_room
- entity: sensor.family_room_humidity
attribute: humidity
decimals: 0
unit: '%'
icon: 'mdi:water-percent'
tap_action:
action: more-info
- entity: sensor.family_room_temp_battery
attribute: battery
decimals: 0
unit: '%'
icon: 'mdi:battery'
tap_action:
action: more-info
animations:
entity.1:
- state: 'on'
circles:
- animation_id: 11
styles:
- fill: var(--secondary-text-color);
- opacity: 0.9;
- animation: jello 1s ease-in-out both;
- transform-origin: center;
icons:
- animation_id: 0
styles:
- fill: white;
- state: 'off'
circles:
- animation_id: 11
reuse: true
styles:
- animation: zoomOut 1s ease-out both;
icons:
- animation_id: 0
styles:
- fill: var(--primary-text-color);
show:
horseshoe_style: lineargradient
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 25
uom_font_size: 1.5
styles:
- font-size: 1.9em;
- opacity: 0.9;
- id: 2
entity_index: 2
xpos: 25
ypos: 43
uom_font_size: 1.5
styles:
- font-size: 1.9em;
- opacity: 0.9;
- id: 3
entity_index: 3
xpos: 77
ypos: 43
uom_font_size: 1.5
styles:
- font-size: 1.9em;
- opacity: 0.9;
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
styles:
- font-size: 1.5em;
- opacity: 0.7;
icons:
- id: 0
animation_id: 0
xpos: 50
ypos: 75
entity_index: 1
icon_size: 4
styles:
- color: var(--primary-text-color);
- id: 2
entity_index: 2
xpos: 35
ypos: 57
align: end
icon_size: 2.9
styles:
- color: orange
- id: 3
entity_index: 3
xpos: 85
ypos: 57
align: end
icon_size: 2.9
styles:
- color: orange
color: orange
circles:
- id: 0
animation_id: 0
xpos: 50
ypos: 70
radius: 35
styles:
- fill: var(--primary-background-color);
- id: 1
animation_id: 11
xpos: 50
ypos: 70
radius: 25
entity_index: 1
styles:
horseshoe_scale:
min: 0
max: 40
width: 2
color: var(--primary-background-color)
horseshoe_state:
width: 2
color: '#FFF6E3'
color_stops:
'0': '#FFF6E3'
'10': '#FFE9B9'
'20': '#FFDA8A'
'30': '#FFCB5B'
'40': '#FFBF37'
'50': '#ffb414'
'60': '#FFAD12'
'70': '#FFA40E'
'80': '#FF9C0B'
'90': '#FF8C06'
Awesome! Thank you so much. Very nice multi-use gauge now.
I copied your code and changed the entities to some I have, and it worked! Thank you. But all I see is the small gauge on the right. Is this right? Is the code not there for the gauge on the left? I can steal code and modify it, but I really donāt know what Iām doing. If you donāt mind and if Iām right that the left gauge code isnāt there, could you provide it so I have something to work with? Thanks
Add this card thru HACS.
https://github.com/custom-cards/canvas-gauge-card
And hereās the code.
font_size: 1em
gauge:
animatedValue: true
borders: true
colorBorderInner: '#111'
colorBorderInnerEnd: '#333'
colorBorderMiddle: '#222'
colorBorderMiddleEnd: '#111'
colorBorderOuter: '#333'
colorBorderOuterEnd: '#111'
colorNumbers: '#ccc'
colorPlate: ''
colorTitle: '#f5f5f5'
colorUnits: '#f5f5f5'
height: 200
highlights:
- color: 'rgba(0, 68, 255, .75)'
to: 5
- color: 'rgba(74, 123, 180, .75)'
to: 15
- color: 'rgba(4, 205, 24, .75)'
to: 25
- color: 'rgba(239, 93, 13, .75)'
to: 40
majorTicks:
- '0'
- '5'
- '10'
- '15'
- '20'
- '25'
- '30'
- '35'
- '40'
maxValue: 40
minValue: 0
minorTicks: 5
startAngle: 45
strokeTicks: true
ticksAngle: 270
title: Family Room
type: radial-gauge
units: °C
valueBox: true
valueDec: 1
valueInt: 2
width: 205
type: 'custom:canvas-gauge-card'
Thank you. I now have 2 custom cards to play with. Thanks again.
Is there a way to call a popup on this card?
something like this for example:
tap_action:
action: fire-dom-event
browser_mod:
command: toast
message: Hello
any idea regarding this misalignment on android APP HA?
It is aligned on the browserā¦
The xpos: of the icon and of the circle is the same (50)!
icons:
- id: 0
animation_id: 0
xpos: 50
ypos: 75
circles:
- id: 0
animation_id: 0
xpos: 50
ypos: 70
radius: 35
How do you configure that background?
By(t)e
Hi, any possibility to show ālast_changedā in this card?
How do I achieve this? Cant find any example code on this? Want to make my gauge being only a half circle.
Is it possible to set a width for the card itself ?
Kr,
Bart
Logger: frontend.js.latest.202204050
Source: components/system_log/__init__.py:190
First occurred: 18:26:52 (4 occurrences)
Last logged: 18:26:55
https://xxxxxx.duckdns.org:8123/hacsfiles/flex-horseshoe-card/flex-horseshoe-card.js?hacstag=2427790308781368:1609:26 Uncaught TypeError: Cannot read properties of undefined (reading 'action')
I have a problem since update to 2022.6.0 with the companion app. Itās working fine with browser version and worked in the app before.
Pushing the now āinvisibleā fan button in mobile app gives me the following error:
Logger: frontend.js.latest.202206010
First occurred: 08:54:06 (1 occurrences)
Last logged: 08:54:06
https://xxxxxxxxxxx.duckdns.org:8123/hacsfiles/flex-horseshoe-card/flex-horseshoe-card.js?hacstag=1111111111:222:333 Uncaught TypeError: Cannot read properties of undefined (reading 'action')
Mobile app:
Browser:
Lovelace configuration:
type: custom:mod-card
card_mod:
style: |
restriction-card {
--lock-margin-left: 88%;
card:
type: custom:restriction-card
restrictions:
block: true
condition:
entity: sensor.i3s_120_remaining_battery_percent
value: 30
operator: <
card:
type: custom:flex-horseshoe-card
entities:
- entity: sensor.i3s_location_temp
decimals: 1
tap_action:
action: more-info
- entity: input_boolean.virtual_i3s_climate
icon: mdi:fan
tap_action:
service: input_boolean.toggle
service_data:
entity_id: input_boolean.virtual_i3s_climate
- entity: switch.virtual_i3s_climate
tap_action:
action: more-info
animations:
entity.1:
- state: 'on'
icons:
- animation_id: 0
styles:
- color: var(--paper-item-icon-active-color);
- state: 'off'
icons:
- animation_id: 0
styles:
entity.2:
- state: 'on'
icons:
- animation_id: 0
styles:
- color: var(--text-primary-color);
circles:
- animation_id: 1
styles:
- fill: var(--cool-blue);
- state: 'off'
circles:
- animation_id: 1
styles:
show:
horseshoe_style: colorstopgradient
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 42
styles:
- font-size: 3.5em;
- text-transform: none;
- font-weight: 500;
- id: 1
entity_index: 3
xpos: 50
ypos: 95
styles:
- text-transform: lowercase;
- font-size: 1.6em;
- font-weight: 500;
- letter-spacing: inherit;
hlines:
- id: 0
xpos: 50
ypos: 51
length: 50
styles:
- stroke: var(--primary-text-color);
- stroke-width: 5;
- stroke-linecap: round;
- opacity: 0.7;
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
styles:
- font-size: 1.6em;
- font-weight: 500;
icons:
- id: 0
entity_index: 1
animation_id: 0
xpos: 50
ypos: 74
icon_size: 3.8
circles:
- id: 0
entity_index: 2
animation_id: 1
xpos: 50
ypos: 68.5
radius: 25
horseshoe_scale:
min: -20
max: 60
width: 10
horseshoe_state:
width: 14
color_stops:
'10': orange
'18': var(--cool-blue)
'25': orange
'35': red
'-20': red
card_mod:
style: |
ha-card {
padding: 12px !important;
Hello I try to change Icon Color with the fill option for the light and the blind, but nothing change code are accepted but if light change from on to off or inverse or blind change from closed to open nothing chance can you help me
here my code
entities:
- entity: sensor.station_sdj_co2_ambient
attribute: CO2
decimals: 0
unit: ppm
icon: mdi:molecule-co2
- entity: sensor.sation_sdj_temperature_ambiante
attribute: temperature
decimals: 1
unit: °C
icon: mdi:thermometer
- entity: sensor.salle_de_jeux_humidity
attribute: humidity
decimals: 0
unit: '%'
icon: mdi:water-percent
- entity: switch.nspanel_sdj_relay_2
icon: mdi:lightbulb-outline
tap_action:
service_data:
entity_id: switch.nspanel_sdj_relay_2
- entity: cover.store
icon: mdi:blinds-horizontal
animations:
entitiy.3:
- state: 'on'
icons:
- animation_id: 10
styles:
- fill: yellow;
- state: 'off'
icons:
- animation_id: 10
styles:
- fill: black;
entitiy.4:
- state: open
icons:
- animation_id: 11
styles:
- fill: blue;
- state: closed
icons:
- animation_id: 11
styles:
- fill: black;
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
animation_id: 0
xpos: 55
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
animation_id: 0
xpos: 30
ypos: 57
styles:
- text-anchor: start;
- font-size: 1em;
- id: 2
entity_index: 2
animation_id: 0
xpos: 30
ypos: 72
styles:
- font-size: 1em;
- id: 3
entity_index: 3
animation_id: 0
xpos: 70
ypos: 57
styles:
- font-size: 1em;
- id: 4
entity_index: 4
animation_id: 0
xpos: 70
ypos: 72
styles:
- font-size: 1em;
icons:
- id: 0
entity_index: 1
xpos: 30
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 30
ypos: 72
align: end
- id: 2
entity_index: 3
animation_id: 10
xpos: 68
ypos: 57
align: end
styles:
- color: var(--primary-text-color);;
- id: 3
entity_index: 4
animation_id: 11
xpos: 68
ypos: 72
align: end
styles:
- color: blue
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: 400
max: 2500
color_stops:
'16': '#29c5f6'
'17': lime
'18': '#86DC3D'
'19': '#C5E90B'
'20': '#ff8b3d'
'21': '#ff6600'
'22': '#f94001'
'23': red
'24': '#FF9C0B'
'25': '#FF8C06'
