Lovelace Floorplan
Hi
I’m trying to get the Lovelace Floorplan running, but I’m stumped on this one:
To run this example, copy the following files to the www/floorplan/examples/simple folder of your Home Assistant configuration…
Where is the “www” folder?
My Setup: Raspberry PI3B+, HASSio installation on 32 GB SD.
I’m very familiar with Linux, but have never used Docker…
Thanx
Andy
/config/www
You have to manually create it.
Hi
Thx.
In my case it had to be on the top level…
Andy
No it doesn’t. You must be misunderstanding the example.
EDIT: if you link the example, I can steer you in the correct direction.
Hi
Thx, but it’s already up & running!
:slight_smile:
