Hey Thomas,
I did what you said and I can change the friendly name now. But the screen no longer goes to sleep and I can not turn it off or adjust the brightness via the switch.
Hey Thomas,
Wow this is so easily setup with all your instructions and hard work you have shown hereā¦thanks very much!
I have a question though about how to get the binary sensor (when movement is detected) to send a specific topic to another MQTT device?
I use sonoff devices and usually I publish this via a rule when the device sees movementā¦
It sends ācmnd/sonoff16/Event Movement_rumpusā
That then is received by the target device =sonoff16
sonoff16 then triggers its responce which is what I need.
So I setup this for my deviceā¦
I dont think that is right though as no MQTT topic is received by my target device atm?
I believe the sonoff ālistenā for that āstate_topicā and respond with their STATE? How do I setup topics to be published?
Any help would be fantasticā¦cheers!
Hi.
The mqtt motion sensor you set up is not actually a working mqtt motion sensor.
I chose mqtt because that works as an easy to set up ādummy sensorā which doesnāt require any special backend support - but it wonāt actually send or receive any mqtt messages.
I suppose an automation would be best, that listens for changes in the motion sensor, and published that to mqtt via some other means.
First thingā¦thanks for the quick reply!
Ok I see. An automation it is then. I will report back here if/when I get it sorted Thomas.
Regards Steve Wells
Automation (2 required) for my needs was reasonably easy but I did need to reuse some code I found online.
# Dashboard ScreenLight ON Then turn off after delay
#light.dashboard_screen Light OFF after time delay
- id: DashboardScreenLightOffWhenTimerEnds
alias: Dashboard Screen Light Off when Unoccupied
platform: state
entity_id: light.dashboard_screen
to: 'on'
for:
minutes: 1
condition:
condition: state
state: 'on'
service: homeassistant.turn_off
# Dashboard Sensor ON Publish a MQTT Packet
#When binary_sensor.back_door_occupied Light ON Publish a MQTT Packet
- id: DashboardMotionSensorONPublishPacket
alias: Dashboard Motion Sensor On Publish Packet
platform: state
entity_id: binary_sensor.dashboard_motion
to: 'on'
condition:
condition: state
state: 'on'
service: mqtt.publish
topic: "cmnd/sonoff16/Event"
payload: "Movement_rumpus"
Thanks again for your invaluable initial work with this plugin!
I will no doubt be rolling this out to several local screens around my installation.
This looks like a really cool plugin. Iām new to Hass and thinking of using my old Nexus 7 (2012) as a dashboard device. If the thing is not under powered. Maybe a custom ROM will help.
Since the tablet will be sitting in a charging dock I want some automation as well to only turn on the charging dock (with a smart plug) when battery is below a certain level and turn off the plug/charging dock again when fully charged. Never mind, I didnāt even read the OT properly. Apparently battery level is provided, so I can use this in an automation, cool!!
Not really related to this, but thinking of also using the Nexus 7 as a (local, not cloud) voice assistant, or is that asking too much from this old poor tablet
Just started using this.
Am I right in thinking that the user that the panel is logged into HA with must be an Admin?
It is certainly the only way I could make it work.
Alsoā¦ I canāt control the screen from Lovelace. It reports on and off correctly I just canāt control it.
For me it also only works when logged in with an admin account.
Iāve moved to using browser-mod.
Give it a try, itās very good.
You should.
Since the latest update of browser_mod, it has all functions of lovelace-fullykiosk and more.
And browser_mod works even for non-admin users.
In fact, lovelace-fullykiosk is now to be considered deprecated and no support will be given.
I just havenāt gotten around to updating the readme yet.
