Hello, everyone.
Is anyone of you on 2021.12.1 and using gauges? They are not rendering correctly at my end (tried IOS and/or browser) as you can see in the attached picture.
I didn’t do any changes between upgrades…
Thanks.
Hello, everyone.
Thanks.
Can confirm. I have the same issue.
Working fine on 2012.12.1 for me - on Android and in the browser - and 2012.12.0 worked fin as well:
Sorry for not being able to help you narrow down the issue you’re seeing.
It work’s semi correctly with the needle on but if you switch the needle off it will look like above.
I see it too, only on iOS, and only since iOS 15.2.
I also see it on my Mac. Not sure if it’s IOS related or not. Will need to check on other machines.
Confirmed to be a bug on IOS15.2+ and equivalent MacOS devices. See Lovelace Gauge UI Bugs · Issue #10910 · home-assistant/frontend · GitHub
Same here with 2021.12.3.
