I’m having some strange behavior when loading the lovelace with gauge, it shows the error for a second and then the normal gauge appears correct, see below:
I have this behaviour too, but additionally other card are also affected:
This is the view, if “custom-gauge” is commented out in ui-lovelace.yaml
Seems, this is probably the error message, while “custom-gauge” is loading http://192.168.2.141:8123/static/webcomponents-bundle.js:151:186 TypeError: 'dispatchEvent' called on an object that does not implement interface EventTarget.
EDIT: This behaviour does NOT happen in Chrome, only with Firefox and Edge.
@Klagio I will try to give you a more complete answer, maybe it helps other understand some of the decisions I’ve had to take along the way. The explanation below is from a personal perspective and I am sure I might have a distorted view on things but people should take it as it is
Background
The way most of custom cards are built is using vanilla javascript. This allows for easier development and no need for extra tools to make the code available. Also leaves the code readable so users can test and try changes and fixes if something is not how they desire.
The downside of using vanilla javascript is that some features might not be available on all browsers. Majority of my cards for example are using shadow DOM for better context separation and to avoid css conflicts or id conflicts in the DOM. This is far easier to maintain than prefixing everything with a card name that someone could potentially do in a different card. The downside is that you need your browser to support shadow DOM (the major culprit in compatibility). There are also some other side effects like special styles (For example in SVG) that browsers render differently.
Potential approaches to fix downsides
User polymer or some other framework that provides polyfills for the missing features
Advantage:
Majority of features work cross browser without writing specific code because of polyfills
Easier to get a card into core if it’s written in polymer as it would require less modification to do so
Disadvantages:
Requires extra files to be loaded by the UI either from the internet (which I disagree with) or from local storage
Requires a bundler or a preprocessor to reduce the number of resources loaded
Harder for people to create a ‘dev’ environment to write code and improve features - less contributions
If you use a bundler to reduce code loaded you will obfuscate and mimify which makes code unreadable once it’s ‘published for production’ which makes it harder to get relevant errors from users
Avoid using shadow DOM & other incompatible features
Advantages
More compatibility between browsers (not guaranteed)
Easier to read if you keep to vanilla javascript
Easier contributions
Easier to read relevant errors (if you don’t use a bundlers / obfuscation)
Disadvantages
If code grows, you can’t do code splitting for better maintenance and development
Development is harder sometimes as you have to keep track of which feature is compatible with which browser
Using something like StencilJS which I tested out which compiles code to vanilla javascript
Advantage:
You can keep code without obfuscation and get more relevant errors
You can code split for easier development
Disadvantages
Still harder to build a dev environment and get new contributions in
Requires you to know the framework syntax (similar to angular or polymer) but this is the same with all frameworks
The main reasons I chose my cards to avoid frameworks are
No extra resources except the card - My goal is for people to just link one javascript file and that includes everything: style, code, etc.
No internet resources - My setup must work without internet connection
Errors received from people are directly relevant without trying to ping-pong dev versions and clearing caches to understand the exact error
More people contribute - If people can read the code directly in their downloaded javascript, they can make small mods or fixes that if relevant can get back into the upstream code without any headache - Also true because you just need the 1 file and refresh to see changes
What I’m missing out
Browser compatibility - chrome, opera, safari are supported for most part with firefox requiring the two ‘dev’ flags, only edge is not supported
Code splitting - at the moment I can’t keep code split and can’t reuse code between cards - Can lead to code duplication if I end up doing similar things between card variations (translations support?!)
Notes
I am happy with the browser support vs the disadvantages of using a framework. I plan to do code splitting by building just a bundler (bash or something very lightweight) to concatenate multiple files together. Keeping just 1 file (Thermostat is a good example of how complexity can grow) makes it easier for tools like tracker-card to also install cards or update cards without too much complexity.
This is a fantastic card! Have it working but there’s a slight display issue - when I put two cards in a horizontal stack (just as in the example) it seems to break out of its boundaries. Is there a way to resize the gauge?
Hey, how did you achieve this? What do you specify in CPU load entity? My log shows this error: https://hassio.hub:8123/local/gauge-card.js?v=1:169:21 Uncaught TypeError: Cannot read property 'state' of undefined
My default UI is dark-themed and STATE elements show up as blue, therefor I would like these gauge’s to be blue on “default” aka “green” instead of actually green.
Is there a way to have the severity options work with a sensor where the higher the value, the better it is (such as a battery charge)? If have tried it like this:
With the battery level at 15% the gauge is showing green when I would want it to be red.
Edit: It turns out that this was an issue with a dark theme I was using (not one of my own). The theme set label-badge-red to the same as accent-color, which was set to a shade of green. After editing the theme to remove this, it is working fine and shows as red when the battery level is low as expected.
I think I’ve tried everything I’ve seen in the thread to address this including: downloading the .js file using the raw button in Github, putting it in a www directory in config (note: I had no such directory so I had to create one), restarting Hassio, clearing browser cache.
