Lovelace: Gauge card
Have you checked the entity?
-> Dev Tools/States
Sigh…thanks for suggesting I check. I simply had a typo in the entity name!
Just wondering if there is a list of the colours that we could use.
Only red, green, amber?
why when you do a horizontal stack does it squish the cards into the space of 1 card is there a way to keep the cards the original size but tile them horizontally?
Does anyone know how to read the power consumption of a “Xiaomi Aqara Wall Plug” socket in a GAUGE Card?
The HAss can display the this value, but this Wall Plug is a Binary Sensor and I can not extract the value in watts.
Any tip? Thanks
Create a template sensor to extract the attribute value as a state. I think the component page has some examples.
is it possible to create a card with mixed formatting? I mean within the same table insert a gauge card and an entity card, for example … such as a gauge for charging the iphone and next to the same tab the battery status. I hope I managed to explain myself
I think my gauge card’s a little drunk or has a hard time with negative values now… :frowning:
Anyone else run into this issue?
Seems to be working fine so far:
Screenshot_2018-11-15_13-20-52
- type: gauge
  title: Outside Temp
  entity: sensor.dark_sky_apparent_temperature
  min: -40
  max: 40
  severity:
    red: -40
    green: 0
    yellow: 30
When I started this post it was at -1, will have to wait until the temperature goes below zero again.
This topic is for the - type: custom:gauge-card
I’m having some strange sizing behaviour. Admittedly this is after I started using the pop-up card by @thomasloven but would that have an effect? They seem to jump from large to small and back again every time they update.
My yaml for the whole view is at the bottom but it is long so I have also copied the gauge and pop-up sections here separately. Any ideas?
          - type: horizontal-stack
            cards:
              - type: gauge
                title: "Disk usage"
                entity: sensor.disk_use_percent_
                scale: 35px
                min: 0
                max: 100
                severity:
                  green: 0
                  yellow: 60
                  red: 85
              - type: gauge
                title: "Memory usage"
                entity: sensor.memory_use_percent
                scale: 35px
                min: 0
                max: 100
                severity:
                  green: 0
                  yellow: 60
                  red: 85
            cards:
              - type: gauge
                title: "Processor usage"
                entity: sensor.processor_use
                scale: 35px
                min: 0
                max: 100
                severity:
                  green: 0
                  yellow: 60
                  red: 85
              - type: gauge
                title: "CPU Temp"
                entity: sensor.cpu_temp
                scale: 35px
                min: 0
                max: 100
                severity:
                  green: 0
                  yellow: 60
                  red: 70
      - type: custom:popup-card
        entity: sensor.tasmota_earliest_installed_version
        title: Tasmota Firmware Versions
        card:
          type: entities
          entities:
            - entity: sensor.sonoff01_firmware
              icon: mdi:alpha-s-box-outline
            - entity: sensor.sonoff02_firmware
            - entity: sensor.sonoff03_firmware
            - entity: sensor.sonoff04_firmware
            - entity: sensor.sonoff05_firmware
            - entity: sensor.sonoff06_firmware
            - entity: sensor.sonoff4ch01_firmware
            - entity: sensor.sonoff_rf01_firmware
            - entity: sensor.sonoff_rf02_firmware
#=== SYSTEM
  - title: System Information
    icon: mdi:home-assistant
    panel: true
    cards:
        cards:
          - type: vertical-stack
            cards:
                card:
                  type: entities
                  entities:
              - type: entities
                title: Software & Firmware Versions
                show_header_toggle: false
                entities:
                  - entity: sensor.installed_version
                    name: Hassio Installed Version
                  - entity: sensor.latest_available_version
                    name: Hassio Current Version
                  - type: divider
                  - entity: sensor.tasmota_current_version
                    name: Tasmota Current Version
                  - entity: sensor.tasmota_earliest_installed_version
                    name: Tasmota Earliest Installed Version
              - type: custom:tracker-card
                title:
                trackers:
                  - sensor.custom_card_tracker
                  - sensor.custom_component_tracker
              - type: custom:migrate-card
            cards:
              - type: entities
                title: System
                entities:
                  - sensor.last_boot
                  - sensor.rpi_uptime
                  - sensor.ha_uptime
                  - type: divider
                    style:
                      height: 10px
                  - sensor.rpi_power_status
                cards:
                  - type: gauge
                    title: "Disk usage"
                    scale: 35px
                    min: 0
                    max: 100
                    severity:
                      green: 0
                      yellow: 60
                      red: 85
                  - type: gauge
                    scale: 35px
                    min: 0
                    max: 100
                    severity:
                      green: 0
                      yellow: 60
                      red: 85
                cards:
                  - type: gauge
                    scale: 35px
                    min: 0
                    max: 100
                    severity:
                      green: 0
                      yellow: 60
                      red: 85
                  - type: gauge
                    title: "CPU Temp"
                    scale: 35px
                    min: 0
                    max: 100
                    severity:
                      green: 0
                      yellow: 60
                      red: 70
              - type: entities
                title: Logging
                entities:
                  - input_boolean.debug_messages
                  - input_select.log_level
            cards:
              - type: entities
                title: Internet
                entities:
                - type: weblink
                  url: http://192.168.1.254/
                  icon: mdi:router-wireless
                - sensor.public_ip_address
              - type: picture-elements
                image: /local/lovelace/internet-card.png
                elements:
                - type: state-icon
                  entity: sensor.speedtest_download
                  style:
                    top: 20%
                    left: 4%
                    color: white
                - type: state-label
                  style:
                    top: 20%
                    left: 18%
                    font-size: 115%
                    color: white
                - type: state-icon
                  entity: sensor.speedtest_upload
                  style:
                    top: 53%
                    left: 4%
                - type: state-label
                  style:
                    top: 53%
                    left: 18%
                    font-size: 115%
                    color: white
                - type: state-icon
                  entity: sensor.speedtest_ping
                  style:
                    top: 85%
                    left: 4%
                    color: black
                - type: state-label
                  style:
                    top: 85%
                    left: 17%
                    font-size: 115%
                    color: white
              - type: history-graph
                title: Speedtest Graph
                hours_to_show: 48
                refresh_interval: 1800
                entities:
                  - sensor.speedtest_download
                  - sensor.speedtest_upload
The core Gauge card has no option scale.
Thanks, yes. That was mistakenly left over from the old custom card.
However removing it hasn’t fixed the sizing issue…
It seems to be a problem with the sizing of the actual gauges. If I make the browser window bigger they fit properly and don’t jump about in size.
If I make the browser window smaller they really don’t scale properly…
and they still jump about in size
I have that as well but if I refresh the page in the browser it comes good.
I also find the card titles revert to plain text the same size as the other text… a refresh fixes that as well.
@cogneato
I am trying to do the same, but I cannot figure out how to use the info on the system monitor page - this renders nothing:
- icon: mdi:settings
title: System monitor
cards:
  title: Disk usage
  entity: disk_use_percent /home
  min: 0
  max: 100
Can you please share your code for those 4 systemmonitors you did?
entity needs to be a sensor ie: sensor.disk_used_home
thanks, @firstof9
however - no effect - I get this in the log:
(my url+port)/local/gauge-card.js?v=1:169:21 Uncaught TypeError: Cannot read property ‘state’ of undefined
this is the full code:
cards:
title: “Disk usage”
entity: sensor.disk_use_home
min: 0
max: 100
severity:
green: 0
yellow: 60
red: 85
Use the code formatting: </> on your code to make sure that the spacing is correct.
You have the system monitor sensor component enabled right?
