Please take a look at this. These are two lovelace gauge cards, doing almost the same thing, except that the above card (with the overlapping bars), has conditions in it (This is the card I want to use). Why are the gauges overlapping and not resized properly?
Thank you…
This is the code from the first card:
cards:
- cards:
- card:
entity: sensor.homeserver_cpu_usage
name: CPU homeserver
type: gauge
severity:
green: 0
red: 85
yellow: 45
theme: default
conditions:
- entity: switch.homeserver
state: 'on'
type: conditional
tap_action:
action: none
hold_Action:
action: more-info
- card:
entity: sensor.homeserver_ram_usage
name: ram homeserver
type: gauge
severity:
green: 0
red: 85
yellow: 45
conditions:
state: 'on'
type: conditional
tap_action:
action: none
hold_Action:
action: none
- card:
entity: sensor.homeserver_hdd_free_d
type: gauge
max: 867
severity:
green: 0
red: 20
yellow: 50
conditions:
state: 'on'
type: conditional
tap_action:
action: none
hold_Action:
action: none
type: horizontal-stack
- cards:
- card:
entity: sensor.gateway_cpu_usage
type: gauge
severity:
green: 0
red: 85
yellow: 45
conditions:
- entity: switch.gateway
state: 'on'
hold_action:
action: more-info
tap_action:
action: toggle
type: conditional
- card:
entity: sensor.gateway_ram_usage
type: gauge
severity:
green: 0
red: 85
yellow: 45
conditions:
state: 'on'
hold_action:
action: more-info
tap_action:
action: toggle
type: conditional
- card:
entity: sensor.gateway_hdd_free_c
max: 256
min: 0
severity:
green: 0
red: 20
yellow: 50
type: gauge
conditions:
state: 'on'
hold_action:
action: more-info
tap_action:
action: toggle
type: conditional
type: vertical-stack
And this is the second card:
cards:
- cards:
- entity: sensor.homeserver_cpu_usage
max: 100
min: 0
name: cpu homeserver
severity:
green: 0
red: 85
yellow: 45
theme: default
type: gauge
- entity: sensor.homeserver_ram_usage
max: 100
min: 0
severity:
green: 0
red: 80
yellow: 60
theme: default
type: gauge
- entity: sensor.homeserver_hdd_free_d
max: 867
min: 0
name: hdd homeserver
severity:
green: 0
red: 20
yellow: 50
theme: default
type: gauge
conditions:
state: 'on'
- cards:
- entity: sensor.gateway_cpu_usage
max: 100
min: 0
severity:
green: 50
red: 0
yellow: 30
theme: default
type: gauge
- entity: sensor.gateway_ram_usage
max: 100
min: 0
severity:
green: 50
red: 0
yellow: 30
theme: default
type: gauge
- entity: sensor.gateway_hdd_free_c
max: 256
min: 0
severity:
green: 0
red: 20
yellow: 50
theme: default
type: gauge
