Have been experimenting with lovelace and made some really great picture element cards for my heating system. I have made a picture element card for each room with thermostat and lighting but I am now trying to make a picture element for my boiler. I have an ebusd bridge so can get all sorts of data from my boiler controller such as flow and return temperatures, water pressure, pump status etc. I have created a picture element but would like to display the water pressure and a few other stats as gauges within the picture element if at all possible. I have attached a very rough early version or the card, a work in progress and I will make sure I do an update with the finished card when I am done.
Having looked at all the documentation a gauge only seems to be available as a seperate card. Is there a way to display a gauge as an element within a picture element card?
Hello
I’m reviving this thread because I have the exact same question.
The gauge map has been integrated into Home assistant but I can’t include it in a picture elements map
Do you have a solution ?
