Lovelace Google Calendar
This card looks awesome! Unfortunately, I am running into a problem when I try to implement it in my UI. I followed the installation instructions, but I am still getting the “Custom element does not exist” error :disappointed:
I have checked the downloaded file (calendar-card.js) and it is approx 9kB, which seems OK.
I added the following lines to my ui-lovelace.yaml file:
resources:
  - url: https://unpkg.com/[email protected]/moment.js
    type: js
  - url: /local/custom_ui/calendar-card.js?v=1.01
    type: module
And:
  - title: calendar
    icon: mdi:calendar
    cards:
      - type: custom:calendar-card
        showProgressBar: false
        numberOfDays: 5
        entities:
          - calendar.xxxxx
The google calendar component is working as I see it in the “states” section.
In the log file I only get the following error:
2018-11-14 16:21:53 ERROR (MainThread) [frontend.js.latest.201808040] http://x.x.x.x:8123/local/custom_ui/calendar-card.js?v=1.01:7:1 Uncaught SyntaxError: Unexpected token <
I am on a windows machine and tried both Chrome and Microsoft Edge.
Can someone help me figure out what the problem is?
Edit: Fixed the problem. Read through some other posts and determined in the Chrome inspector that home assistant still had the ‘non-raw’ .js file :expressionless:
I think that was a mobile screen shot showing the progress bar being a feature of Google Calendar.
Having those images or being able to break out each event into a separate item under the date) would be great.
Yes it would!
Did you find a solution to integrate you Synology Calendar? I’m looking to use it for a Waste Collection sensor but I get the same error regarding path handling.
Yes, it works.
However :roll_eyes:, I cannot find my configuration anymore of using it with the synology caldav (since I’m not using it myself with Synology caldav). But, I know it worked out in the end… it took me a while though to find the correct synology caldav url.
Well, it was working, then converted back ( I assume it was from a update?)
When changing the line to this
  <div class="time">${event.isFullDayEvent ? 'All day' :
  (moment(event.startDateTime).format('h:mm A') + -+
  moment(event.endDateTime).format('h:mm A'))}</div>
Im getting the correct formatted line but with this at the end 1:00pmNaN , did I place something wrong?
Thanks :slight_smile:
Hi, can i formatting output date in italy?
I have try to modified moment.locale(‘it’) without success.
Yes, look at the line in my post above. This is in your local/www / custom / calendar-card / calendar-card.js file. I believe around line 179 you just have to figure out how you want it formatted.
Would be helpful if this card could display the current date and time. I find that often that when I don’t have an event for today and it’s showing the date of the next event I get easily confused.
UPDATE:
made a small edit to switch out the Calendar title for the date.
Here’s what I did in my ui-lovelace.yaml file where I call the calendar card. Note that I added the ‘name’ field and in my case inserted a sensor – based on how I changed the javascript file I think it would break if it wasn’t an HA entity. I’m not even a JS beginner so I don’t know how to do this better at this time.
ui-lovelace.yaml
      numberOfDays: 7
      entities:
        - calendar.a
And then in my calendar-card.js file I changed the top code block. Note the card.header line in particular.
calendar-card.js
    class CalendarCard extends HTMLElement {
      set hass(hass) {
        if (!this.content) {
          const card = document.createElement('ha-card');
          card.header = hass.states[this.config.name].state;
          this.content = document.createElement('div');
          this.content.style.padding = '0 16px 16px';
          card.appendChild(this.content);
          this.appendChild(card);
          moment.locale(hass.language);
And of course you need a sensor.date
  - platform: time_date
    display_options:
      - 'date'
I tried adding the time too. But I a) didn’t think it looked nice because the JS dropped the whitespace padding in the template sensor I made. And b) it wasn’t updating on the minute so kinda pointless. Going to dive into JS a bit to see if I can make this a bit cleaner, less hacky. But for now, maybe it’ll give another JS newbie the ability to add the date like I did, or how to change the title from Calendar to something else.
Everything was working great and now I am getting this error
Error handling message: {‘type’: ‘lovelace/config/card/get’, ‘id’: 32}
7:02 AM components/websocket_api/connection.py (ERROR)
2018-11-28 21:48:27 ERROR (MainThread) [frontend.js.es5.201811033] https://xxx.duckdns.org:8123/static/custom-elements-es5-adapter.js:4:618 Uncaught TypeError: Class constructor CalendarCard cannot be invoked without ‘new’
How to make translation of weekdays and text under the event like “All day” to native language…
HA default choosed language is not English, but in Google Calendar I see all in English…
Thank you for your answer…
Hello, how do i fit the code in exactly in my ui-lovelace.yaml?
I get a few bad indentation…
Where i want to fit it in is the code:
  - title: Algemeen
    icon: mdi:home-outline
    cards:
      - type: glance
        title: In & Uitschakelen
        show_state: false
        column_width: calc(100% / 3)
        entities:
          - entity: switch.tv
            icon: mdi:television-classic
            tap_action: toggle
          - entity: group.sfeerlicht
            icon: mdi:lamp
            tap_action: toggle
          - entity: light.fibaro_system_fgd212_dimmer_2_level_4
            icon: mdi:track-light
            tap_action: toggle
          - entity: light.fibaro_system_fgd212_dimmer_2_level_2
            icon: mdi:lightbulb
            tap_action: toggle
          - entity: script.hombot_aan
            icon: mdi:robot-vacuum
            tap_action: toggle
      - type: entities
        title: Radio
        show_header_toggle: true
        entities:
          - input_select.chromecast_radio_station
          - input_select.chromecast_radio_speakers
          - input_number.volume_radio
          - script.play_chromecast_radio
          - script.stop_chromecast_radio
      - type: media-control
        entity: media_player.android_tv
      - type: weather-forecast
        entity: weather.smhi_terschelling
      - type: entities
        title: Lokatie
        entities:
          - group.tracker_combi_roelof
          - group.tracker_combi_inger
This code i want to fit in:
resources:
    type: js
  - url: /local/custom_ui/calendar-card/calendar-card.js?v=1.0.1
    type: module
- type: "custom:calendar-card"
      entities:
        - calendar.namegmailcom
        - calendar.feestdagen_in_nederland
        - calendar.name2gmailcom
      numberOfDays: 14
      entities:
        - calendar.contacts
Thanks!
If someone wants tot share their ui-lovelace.yaml would be great.
Everything else is set up oke accept this :sunglasses:
I think i’ve got it allright in the ui-lovelace.yaml now, but there is an error on my lovelace screen:
lovelace%20error
I’ve added the calendar-card.js to several folders to test such as:
  • www
  • www / custom / calendar-card
  • www / dist
The size of my calender card is 8,7kb
Already added the following to my config:
frontend:
javascript_version: latest
Sorry for all the reply’s !!! :slight_smile:
Hi rdehuyss,
I have implemented the Lovelace Google Calendar, works great, excellent!!
Just one question, I have imported Outlook in Google Calendar which only show Busy/Tenative/etc., would it be possible to show these events with entity_id in front so I can tell it’s source? Maybe a simple abbreviation of the entity_id/name? i.e.
JT: Busy
11:30-12:30
I feel it may also be helpful to tell similar events from different calendar entity_id’s.
TIA
He is working, the calendar-card.js was in the wrong folder!
Great project!
Thanks for making rdehuyss :slight_smile:
How do i get the “send congrats” behind the birthday’s?
And what happens when you click on it?
Opens it the greetz website to send a postcard or something?
My calendar is displaying yesterday’s events. How do I force the card into my correct time?
Untitled
I added the date as a title. But as you can see the first event displayed has already passed.
How can I change the event location text colour? It doesn’t look good with my theme.
first of all thank you for the amazing works. I’ve just set it up on my living room tablet and it is great!
I just have one question: it is possible to localize it?
Thank you in advance
