I have 6 Heatit thermostat and I started using Lovelace UI.
I wanted to have a surface where I can control everything at a place. But I can’t find, so I make one.
The surface is not the most beautiful (beta ) , but simple.
I am about to purchase two of the Heat it thermostats and was wondering what you were controlling with yours ? Underfloor heating? Electric radiators ?
I’ve got 8 Heatit thermostat and im trying to configure them for Lovelace.
Im trying to use your setup for the thermostats. Sensor and input select works fine. But I can’t really understand your automations.yaml.
It seems a bit backwards to me. Have you made some changes to this for recent versions?
I would like to use your lovelace.yaml because it really has nice features.
Currently I’m trying to get control through the Zwave menu to the HeatIt thermostat.
After sending a setpoint temp to the thermostat, the old value comes back.
Could you please share your zwcfg file, for this node?
