Lovelace Horizon card
I wasn’t able to change the timezone manually in the card. How can I do?
You need to be a little more specific. :slight_smile:
The time_zone is changed by replacing the entry “Europe/Sofia” with your time zone. You can find the so called TZ identifier in this list on wikipedia:
If that wasn’t what you’re asking for, please describe your problem more detailed. Thanks!
I want to see the sunset/sunrise time in Greek near Athens.
On the card documentation it said to use time_zone to use a different one than the hass default. I tried that one but the sunset time didn’t changed at all. I tried some other value from the wiki list, but I got the same time.
I also tried putting it in a double quote but nothing.
Finally using the latitude and longitude value it did work but I would like to use the time_zone cause it is more basic and readable instead of using Lat and long.
Thanks for the clarification. :slight_smile:
I’d speculate that you’re unfortunately hit by this bug:
You could try what is mentioned in the first post of that issue => change the setting for the user which time zone to use. :slight_smile:
Would be nice, if you could report back if this works for you! Thanks!
I’ve also installed this card and don’t understand how to enable the “Dark theme full look”. The Horizon Card configuration options don’t show up. Can anybody help? Running HA Core 2024.10.1 on Raspberry Pi4.
I set the user to use server time and I set the card timezone to the one I want, but still I don’t see any change in time displayed. Sun rise and set are in my local time, and not in the timezone I set on the card.
