During the winter break, I started to learn about HA custom cards a bit. As an example project, I chose a departure overview card for my local transportation service HVV (Hamburg, Germany).
The card is based on the existing HVV Departure Integration from @vigonotion and uses the sensor’s data to create an overview of all departing trains and buses for a certain station.
The code is available on Github including instructions on how to use the card via HACS or manual installation.
I’m not a frontend expert, but I’m happy to receive feedback and learn how to improve the card.
Nice! I also developed such a card but I never finished it and never published it, but it has some more CSS code for the bus and fairy icons. If you want to take a look and implement it in your card, feel free to do so: https://gist.github.com/vigonotion/77fe535198ec8d0aa19388d500e01a18
I would do a PR but that might take a while before I can start that, don’t have much time currently.
currently with HA 2022.7.2 (probably since 2022.7.0) there is a problem with the authentication against gti.geofox.de - Failed to connect
Does anyone have an workaround? Thanks
Probably a hint - there was a breaking change with 2022.7.0
Home Assistant now ships with Python 3.10. This might be a breaking change in case you are using custom integration that does not support Python 3.10 yet.
What a great Card! The only problem I have with it is that it won’t update the times shown. For example when it says in 10 minutes, it stays there for hours and doesn’t refresh.
Am I doing something wrong or what can I do to have the times updated every minute?
