Lovelace in 106 beta
My speedtest cards broke as well on 106. I went back to 105 which I had a snapshot of right before I did the ug.
EDIT:
Hm… ok, so custom cards break in 106 and it appears the hui card is somehow being customized by the speedtest card.
Unfortunately debugging this this is above my pay grade.
Please make a little test for me. Create one normal gauge card on your view.
Do the gauges in the entities card load?
Why are you discussing 0.106 in the 0.105 thread?
This is the only thread I could find discussing and if the beta releases. Point me in the right direction and I’m happy to pack up and move…
Go on discord and there is a beta channel there to discuss the current beta build.
@jazzmonger, there’s an open issue and a temporary fix about this now.
Create a file preloader.js in your www folder,
const preloadCard = type => window.loadCardHelpers()
  .then(({ createCardElement }) => createCardElement({type}))
preloadCard("gauge");
and add it to the resources in ui-lovelace.yaml or the raw config editor.
  - url: /local/preloader.js
    type: js
Works for me with a markdown card.
preloadCard("markdown");
Thanks @balloob, for this!
I think that’s a good point for the release tomorrow.
EDIT: I’m ready for 0.106 now! :tada:
EDIT 2: The PR that caused this issue was reverted until 0.107. So this is NOT needed.
Is this for custom cards as well? I’ve noticed on iOS in the App and also chrome (iOS) that my animated icons on a weather card are not animated anymore since 0.106.0bx
Good info. Thx.
@DavidFW1960, sorry, no clue. Just copied the code from balloobs comment. :innocent:
This was added using a standard gauge card… here is the code from the card:
