Lovelace in yaml mode "Custom element doesn't exist"
Good day, Community!
I am trying to show a custom “weather-card”, downloaded using HACS. Card sources are located to the path: “/home/homeassistant/.homeassistant/www/community/weather-card”. But Lovelace does not see her.
Снимок
My config files:
configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
lovelace:
  mode: yaml
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Light control on the kitchen
#light: !include kitchen_leds.yaml
switch: !include KITCHEN/switches.yaml
sensor: !include KITCHEN/sensors.yaml
ui-lovelace.yaml
title: Home Assistant
resources:
  - url: /local/community/weather-card.js
  - path: default_view
    title: Главная
    panel: true
    badges:
      - entity: binary_sensor.updater
      - entity: person.aleksei
      - entity: sun.sun
    cards:
      - type: horizontal-stack
        cards:
          - type: 'custom:weather-card'
            entity: weather.home_assistant
            number_of_forecasts: '5'
            hourly_forecast: false
I tried to use different paths to the “weather-card.js” file:
  • url: /local/weather-card.js
  • url: /hacsfiles/weather-card.js
resources:
    type: js
But none of this works. Please tell me what am I doing wrong?
Solution: remove all characters “similar” to space and insert spaces manually …
I spent a lot of time on this. It is very uncomfortable. It would be nice to do configuration based on JSON, for example - it would be much more convenient …
Can you explain the solution more? Where did you have to remove and re-add “spaces”?
I’m having the same issue with ha-card-weather-conditions. Seems too weird to be a coincidence?
Me too having the same problem with custom ha-card-weather-conditions.
I opened an issue about this, hoping the developer will fix it asap.
Do you know how, in the meantime, to downgrade to previous release?
Just installed this HACS integration for the first time. Gives an error.
Custom element doesn’t exist: hourly-weather
Added manually:
lovelace:
  mode: yaml
  resources:
    - url: /hacsfiles/hourly-weather/hourly-weather.js
    type: module
Restarted Home Assistant. Nothing helps.
Home Assistant supervised 2025.2.5.
Hourly Weather Card 6.6.1
