I seem to be having display problems with input_number slider entities under Lovelace. When I click on the pin on the slider bar the pin should expand and display the current value. However, the top of the expanded pin is cut off so all you can see is the bottom half of the pin and no value.
This issue should be fixed in 0.77.
Thanks. I will just have to upgrade.
Hi
The value bubble is still partial hidden, even with “2021.10.6”
Same for default and nord theme
