Hey Gareth,
Still a work in progress. Just don’t find the time. :->
Here’s my dashboard and ESPHome config.
The basics work to replicate the Grainfather control panel to HASS, but I havent yet solved setting timers and temp using the thermostat.
Hope it helps and let me know if you get further with any of it.
- title: Home
cards:
- type: vertical-stack
cards:
cards:
- type: horizontal-stack
cards:
- type: entity
entity: sensor.gf_current_temperature
icon: mdi:temperature-celsius
cards:
- type: entity
entity: sensor.gf_set_temperature
- show_name: false
show_icon: false
show_state: true
type: glance
entities:
- entity: sensor.gf_timer_minutes
tap_action:
- action: call-service
service: input_number.reload
entity_id: input_number.gf_timer_start
- entity: sensor.gf_timer_seconds
tap_action:
action: none
title: Timer
tap_action:
action: none
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.pump_status
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: button.up
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: button.set
icon: ''
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: button.down
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.heat_power
- type: thermostat
entity: climate.gf_thermostat
title: Grainfather
and
external_components:
- source:
type: git
url: https://github.com/camsaway/esphome-temp
ref: ble_write_action
components: [ ble_client ]
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# level: VERBOSE
# Enable Home Assistant API
api:
password: !secret api_password
encryption:
key: uvLVRYH+M2rsmc2zjg0e06Y8OLX5NevjgVSi5FwMkFg=
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
# manual_ip: #Optional Manual IP
# static_ip: 192.168.1.84
# gateway: 192.168.1.250
# subnet: 255.255.255.0
ap:
ssid: "Grainfatherwifi Fallback Hotspot"
password: "7fz6PVTCmEBm"
captive_portal:
esp32_ble_tracker:
ble_client:
- mac_address: BB:A0:50:11:29:09 #My Personal GF MAC Address
name: "GF Current Temperature"
unit_of_measurement: "°C"
name: "GF Set Temperature"
name: "GF Timer Minutes"
unit_of_measurement: "min"
name: "GF Timer Seconds"
unit_of_measurement: "s"
switch:
icon: "mdi:pump"
turn_on_action:
- ble_client.ble_write:
service_uuid: 0000cdd0-0000-1000-8000-00805f9b34fb
characteristic_uuid: 0003cdd2-0000-1000-8000-00805f9b0131
value: [0x4c, 0x31, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
turn_off_action:
value: [0x4c, 0x30, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
icon: "mdi:heat-wave"
turn_on_action:
value: [0x4b, 0x31, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
turn_off_action:
value: [0x4b, 0x30, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
button:
icon: "mdi:arrow-up-drop-circle"
on_press:
value: [0x55, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
icon: "mdi:arrow-down-drop-circle"
on_press:
value: [0x44, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
icon: "mdi:alpha-s-circle-outline"
on_press:
value: [0x54, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20]
text_sensor:
- platform: ble_client
ble_client_id: gf_ble
icon: mdi:database-check-outline
service_uuid: '0000cdd0-0000-1000-8000-00805f9b34fb'
characteristic_uuid: '0003cdd1-0000-1000-8000-00805f9b0131'
notify: true
update_interval: 2s
internal: true
filters:
- lambda: |-
std::basic_string<char> retstr;
size_t delimiter;
float value;
retstr = x.substr(1,x.length());
if (x[0] == 'X') {
delimiter = retstr.find(',');
value = atof(retstr.substr(0,delimiter).c_str());
auto call = id(gf_thermostat).make_call();
call.set_target_temperature(value);
call.perform();
id(gf_set_temperature).publish_state(value);
retstr = retstr.substr(delimiter+1,retstr.length());
id(gf_current_temperature).publish_state(value);
else if (x[0] == 'Y') {
id(gf_heat).publish_state(value);
id(gf_pump).publish_state(value);
else if (x[0] == 'W') {
id(gf_power).publish_state(value);
else if (x[0] == 'V') {
id(gf_voltage).publish_state(value);
id(gf_temp_units).publish_state(retstr.substr(0,delimiter).c_str());
else if (x[0] == 'C') {
id(gf_boil_temperature).publish_state(value);
else if (x[0] == 'F') {
id(gf_version).publish_state(retstr.substr(0,delimiter).c_str());
else if (x[0] == 'T') {
id(gf_timerminutes).publish_state(value);
id(gf_timerseconds).publish_state(value);
else if (x[0] == 'I') {
//Interaction Mode
retstr = 'I';
else if (x[0] == 'A') {
retstr = 'A';
else if (x[0] == 'E') {
retstr = 'E';
else if (x[0] == 'B') {
retstr = 'B';
else {
retstr = x;
return retstr;
climate:
- platform: thermostat
icon: mdi:thermostat
name: "GF Thermostat"
sensor: gf_current_temperature
default_target_temperature_low: 60
min_idle_time: 0s
idle_action:
- delay: 0s
heat_action:
- delay: 0s
min_heating_off_time: 0s
min_heating_run_time: 0s
visual:
min_temperature: 0
max_temperature: 100
temperature_step: 1
target_temperature_change_action:
then:
- lambda: |-
int target = id(gf_thermostat).target_temperature;
std::vector<unsigned char> GFcommand;
//GFcommand = {0x24, 0x35, 0x30, 0x2c, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20};
if (target > 99) {
ESP_LOGD("GFCode", "Writing 120C");
GFcommand = {0x24, 0x31, 0x32, 0x30, 0x2c, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20};
else if (target < 10) {
ESP_LOGD("GFCode", "Writing 0C");
GFcommand = {0x24, 0x30, 0x2c, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20};
else {
ESP_LOGD("GFCode", "Writing some value");
GFcommand[0] = 0x24;
switch((target/10)%10){
case 0: GFcommand[1] = 0x30;
case 1: GFcommand[1] = 0x31;
case 2: GFcommand[1] = 0x32;
case 3: GFcommand[1] = 0x33;
case 4: GFcommand[1] = 0x34;
case 5: GFcommand[1] = 0x35;
case 6: GFcommand[1] = 0x36;
case 7: GFcommand[1] = 0x37;
case 8: GFcommand[1] = 0x38;
case 9: GFcommand[1] = 0x39;
default: GFcommand[1] = 0x20;
switch(target % 10){
case 0: GFcommand[2] = 0x30;
case 1: GFcommand[2] = 0x31;
case 2: GFcommand[2] = 0x32;
case 3: GFcommand[2] = 0x33;
case 4: GFcommand[2] = 0x34;
case 5: GFcommand[2] = 0x35;
case 6: GFcommand[2] = 0x36;
case 7: GFcommand[2] = 0x37;
case 8: GFcommand[2] = 0x38;
case 9: GFcommand[2] = 0x39;
default: GFcommand[2] = 0x20;
GFcommand[3] = 0x2c;
for (int i = 4; i < 19; i++) {
GFcommand[i] = 0x20;
ble_client::BLEClientWriteAction<> *my_bleclientwriteaction_1;
my_bleclientwriteaction_1 = new ble_client::BLEClientWriteAction<>(gf_ble);
my_bleclientwriteaction_1->set_value(GFcommand);
my_bleclientwriteaction_1->set_service_uuid128((uint8_t*)(const uint8_t[16]){0xFB,0x34,0x9B,0x5F,0x80,0x00,0x00,0x80,0x00,0x10,0x00,0x00,0xD0,0xCD,0x00,0x00});
my_bleclientwriteaction_1->set_char_uuid128((uint8_t*)(const uint8_t[16]){0x31,0x01,0x9B,0x5F,0x80,0x00,0x00,0x80,0x00,0x10,0x00,0x00,0xD2,0xCD,0x03,0x00});
my_bleclientwriteaction_1->write();
# HEX CONVERSIONS
# ABCDEFGHIJKLMNOPQRSTUVWXYZ
# 0123456789
# $, (space)
# abcdefghijklmnopqrstuvwxyz
# 0x41 0x42 0x43 0x44 0x45 0x46 0x47 0x48 0x49 0x4a 0x4b 0x4c 0x4d 0x4e 0x4f 0x50 0x51 0x52 0x53 0x54 0x55 0x56 0x57 0x58 0x59 0x5a
# 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39
# 0x24 0x2c 0x20
# 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a
# # https://github.com/kingpulsar/Grainfather-Bluetooth-Protocol #
# Bluetooth Low Energy
# The system uses Bluetooth Low Energy for it's communiation.
# Here's a list with the UUIDs for the grainfather system.
# Device UUID: 0000cdd0-0000-1000-8000-00805f9b34fb
# Read Characteristic UUID: 0003cdd1-0000-1000-8000-00805f9b0131
# Write Characteristic UUID 0003cdd2-0000-1000-8000-00805f9b0131
# Commands
# The commands are sent to the grainfather system via Bluetooth. Commands are plain text.
# All commands should be exactly 19 characters in length. Pad the end with spaces.
# Anything between curly braces is a parameter.
# Dismiss Boil Addition Alert: A
# Cancel Timer: C
# Decrement Target Temp: D
# Cancel Or Finish Session: F
# Pause Or Resume Timer: G
# Toggle Heat: H
# Interaction Complete: I
# Turn Off Heat: K0
# Turn On Heat: K1
# Turn Off Pump: L0
# Turn On Pump: L1
# Get Current Boil Temp: M
# Toggle Pump: P
# Disconnect Manual Mode No Action: Q0
# Disconnect And Cancel Session: Q1
# Disconnect Auto Mode No Action: Q2
# Press Set: T
# Increment Target Temp: U
# Disable Sparge Water Alert: V
# Get Firmware Version: X
# Reset Controller: Z
# Reset Recipe Interrupted: !
# Turn Off Sparge Counter Mode: d0
# Turn On Sparge Counter Mode: d1
# Turn Off Boil Control Mode: e0
# Turn On Boil Control Mode: e1
# Exit Manual Power Control Mode: f0
# Enter Manual Power Control Mode: f1
# Get Controller Voltage And Units: g
# Turn Off Sparge Alert Mode: h0
# Turn On Sparge Alert Mode: h1
# Set Delayed Heat Function: B{Minutes},{Seconds},
# Set Local Boil Temp To: E{Temperature},
# Set Boil Time To: J{Minutes},
# Skip To Step: N{Step Num},{Can Edit Time},{Time Left Minutes},{Time Left Seconds},{Skip Ramp},{Disable Add Grain},
# Set New Timer: S{Minutes},
# Set New Timer With Seconds: W{Minutes},{Seconds},
# Set Target Temp To: ${Temperature},
# Edit Controller Stored Temp And Time: a{Stage Num},{New Time},{New Temperature},
# Set Sparge Progress To: b${Progress},
# Skip To Interaction: c{Code},
# Sending a recipe
# Sending a recipe is a bit more complex. Commands need to be sent in the correct order:
# R{Boil Time},{Mash Step Count},{Mash Volume},{Sparge Volume},
# {Show Water Treatment Alert},{Show Sparge Counter},{Show Sparge Alert},{Delayed Session},{Skip Start},
# {Recipe Name}
# {Hop Stand Time},{Boil Addition Stop Count},{Boil Power Mode},{Strike Temp Mode},
# Then for every 'boil stop' or 'unique boil addition time', send the time remaining in minutes.
# Then if you're using strike temp mode, send: 0. (Not sure why, maybe it's not yet implemented)
# Then for every 'mash stop' or 'step' in your mash, send: {Mash Step Temperature}:{Mash Step Duration} (Temperature in degC and Duration in Min)
# If delayed session is enabled, send: {Delay Minutes}, {Delay Seconds}
# Example:
# R75,2,15.7,16.7, 75 minute boil, 2 mash steps, 15.6L mash volume, 16.7L sparge volume
# 0,1,1,0,0, No water treatment alert, show sparge counter, show sparge alert, no delayed session, do not skip the start
# SAISON Recipe name that will be displayed in the top left
# 0,4,0,0, No hop stand, 4 boil addition stops, no boil power mode, no strike temp mode
# 75, Boil addition stop 1, at 75 minutes boil time remaining
# 45, Boil addition stop 2, at 45 minutes boil time remaining
# 30, Boil addition stop 3, at 30 minutes boil time remaining
# 10, Boil addition stop 4, at 10 Minutes boil time remaining
# 65:60, Mash step 1, 65C for 60 minutes
# 75:10, Mash step 2, 75C for 10 minutes
# Notifications
# The system sends it's current status every so often.
# All notifications start with one of these characters: A, B, C, E, F, I, T, V, W, X, Y.
# Notifications look like this:
# X{Target Temperature},{Current temperature}
# Y{Heat Power},{Pump Status},{Auto Mode Status},{Stage Ramp Status},{Interaction Mode Status},{Interaction Code},{Stage Number},{Delayed Heat Mode}
# T{Timer Active},{Time Left Minutes},{Timer Total Start Time},{Time Left Seconds}
# I{Interaction Code}
# V{Voltage: 0=230V, 1=110V},{Units: 0=°F, 1=°C}
# W{Heat Power Output Percentage},{Is Timer Paused},{Step Mash Mode},{Is Recipe Interrupted},{Manual Power Mode},{Sparge Water Alert Displayed}
# C{Boil Temperature}
# F{Firmware version}
# Examples:
# T0,0,0,0,ZZZZZZZZ
# X61.0,22.8,ZZZZZZ 61.0C target temperature, 22.8C current temperature
# W0,0,0,0,0,0,ZZZZ
