Lovelace: irrigation-card (help needed)
Hi there brains trust.
I am trying to create a new card to represent an irrigation zone in my veggie patch.
The idea being that that I can create one card, and display it three times for each zone.
I have been able to create the card with static data, but am unable to get the card to display when I try and read the configuration items.
The error that I keep getting is:
19:47 Uncaught TypeError: Cannot read property ‘card_title’ of undefined
My lovelace-ui config has:
- type: vertical-stack
cards:
- type: “custom:irrigation-zone-card”
entity_title: sensor.zone_1_irrigation_status
Have tried to rename the config options, change where i read the options from, using just a text value (instead of a sensor).
No idea, but I am sure its something obvious. :slight_smile:
Have put the code on github, and happy to share as its finalised:
This is what the static version looks like:
sample
Update:
Finally found the problem… Hope this helps someone else, as I was stumped for days.
First, In the setConfig function you need this:
setConfig(config) {
this._config = config;
secondly you can then reference the _config variable in the hass function:
const zone_title = this._config.zone_title;
I have cleaned up some of the code an put it in github.
This is what I have in my ui-lovelace.yaml:
  • icon: mdi:water
    title: Irrigation
    cards:
    • type: custom:irrigation-zone-card
      zone_title: Zone 1
      next_water: sensor.next_run_irrigation_zone_1
      last_water: sensor.last_run_irrigation_zone_1
      zone_status: sensor.zone_1_irrigation_status
      moisture_level: sensor.irrigation_zone_1_soil_moisture_level
      temperature: sensor.irrigation_zone_1_temperature
      light_level: sensor.irrigation_zone_1_light_level
and this what it looks like in action:
sample
Next step is to have a settings pane popup.
Then fix the css I think as it doesn’t scale quite properly on my mobile phone.
Excellent! I’d just pulled out the coding pad to start work on this when I saw your post. Giving it a try now, thanks @nmurden.
Looks great will be following to see how this progresses would definitely like to use it with my setup
Hi Nmurden,
That’s exactly what I was looking for,
Can you please share(upload) your ui-lovelace.yaml in GitHub.
Thanks.
Looks good :grinning: was just thinking of doing some things like this but this is 10x better
id like to use this with my rachio
I’m trying to find a way to display a timer showing the current time left on an active irrigation. Like a countdown thing…
You can use a timer.
Yes that one did the trick, just wondering if there is a way to remove the start/stop reset buttons…
2019-05-28_11-20-14
How are you displaying them in Lovelace?
I just use simple entities and I get this (it shows the time remaining counting down when active, not ‘Idle’).
oh that is a nicer view…what type of card is that? and what mdi icon are you using?
It is just a simple entities card…
      entities:
        - entity: sensor.cycle1_zone_being_watered
          icon: mdi:fountain
        - timer.cycle1_zone_duration
Your - timer.cycle1_zone_duration is one timer? Because I have several timers (25mins, 45mins, 60mins)
I can’t seem to display the counter though…
    sensors:
      rainbird_status:
        friendly_name_template: >-
          {% if states('switch.cedar_trees') == 'on' %}
            Cedar Trees
          {% elif states('switch.front_guest_room') == 'on' %}
            Front Guest Room
          {% elif states('switch.front_main') == 'on' %}
            Front Main
          {% elif states('switch.front_side') == 'on' %}
            Front Side
          {% else %}
            None
          {% endif %}
        value_template: >-
            {{ states.timer.rainbird_60.attributes.remaining }}
            {{ states.timer.rainbird_25.attributes.remaining }}
            {{ states.timer.rainbird_45.attributes.remaining }}
          {% else %}
            None
          {% endif %}
Nevermind I got it working, thanks again!
