Lovelace is holding the mjpeg camera stream, can't open it from another location
I’m not 100% sure in which category does this belong but here is the problem.
I experimented with several mjpeg cameras. they integrate easily and everything works fine. I use “picture-elements” card and i added “more-info” as a live camera popup.
The problem happens once i open the “live camera” and close it, if i don’t refresh the webpage, it “holds” the stream going on in the background so from another location it’s not possible to open the stream unless the first one is released.
Is there any quick fix for that (i don’t want to use re-stream software etc. I want something as simple as it can be)?
