Hi all,
I’m facing some strange behavior with the gui
Independent of which system I’m using. Either on iOS or my Windows System. The first start of Homeassistant or a reload takes a while till everything is visible. Sometime it shows first that the custom card is not available. It happens with all custom cards.
My Setup
System Health
version |
2021.1.1 |
installation_type |
Home Assistant Supervised |
dev |
false |
hassio |
true |
docker |
true |
virtualenv |
false |
python_version |
3.8.7 |
os_name |
Linux |
os_version |
5.4.83-v7+ |
arch |
armv7l |
timezone |
Europe/Berlin |
Home Assistant Community Store
GitHub API |
ok |
Github API Calls Remaining |
5000 |
Installed Version |
1.9.0 |
Stage |
running |
Available Repositories |
719 |
Installed Repositories |
21 |
Hass.io
host_os |
Raspbian GNU/Linux 10 (buster) |
update_channel |
stable |
supervisor_version |
2020.12.7 |
docker_version |
20.10.2 |
disk_total |
109.5 GB |
disk_used |
14.1 GB |
healthy |
true |
supported |
failed to load: Unsupported |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Glances (0.9.1), InfluxDB (3.7.9), Grafana (5.3.6), Check Home Assistant configuration (3.6.0), File editor (5.2.0), Duck DNS (1.12.4), MariaDB (2.2.1), Nginx Proxy Manager (0.8.2), Samba share (9.3.0), WireGuard (0.4.0), Samba Backup (4.3) |
Lovelace
dashboards |
8 |
mode |
yaml |
views |
7 |
resources |
12 |
