Lovelace issues after update
Hi all,
since carrying out the latest HA update I am getting constant errors for the Recorder and logbook which weren’t there before.
Has anyone encountered these issues.
Thanks.
Are you using any specific settings for the recorder? Like an external DB? If so, is it running, is it on the same installation? (Eg an addon)
Please post the errors.
I have not touched any settings for anything is should all be as standard.
Is this what you are after Tom?
Most likely cause : your database is corrupted. If you are using the default database, delete home-assistant_v2.db and restart HA
OK thanks,
maybe a stupid question but how do I do that.
Your database is normally where your configuration.yaml is located. If you have samba access to your HA , use windows explorer to navigate to your config folder, stand on the home-assistant_v2.db file and click delete.
If you don’t have samba access, but only ssh access, ssh in, cd to your config folder, and issue the command
rm home-assistant_v2.db
If you have neither samba nor ssh access, I strongly suggest to install at least one (and better all two)
I am having issues with samba, I can’t get access I have hassio showing in my network but I just get an error when trying to connect. I could use it no problem with my old windows 7 laptop but this one is windows 10 I don’t know if that is the issue but I messed with this for months on and off but no luck.
