Did a little searching, did not see any discussion specially about linking an user to a Lovelace card.
I believe I have heard on the podcast this is in the works, just curios if there is a status?
Just in case I am not picture the feature correctly, in the user configuration, you set a Lovelace card to that user. When they log in, that is what they see for the UI.
My use case would be adding all the kid’s as user. Then setting a card with just the garage door on it.
I am by no means a Lovelace expert. Just to see if I am understanding correctly, under the views: each tab is a -title: section. Is t hat the level you are talking about? Kind of what I think as a page tab.
Is this on the road map?
Will it hide views that the user does not have access to?
Am I even in the ball park?
If I am in the ball park, then that will be cool. Right now the garage doors are on their own tab.
