HI,
trying to migrate this regular HA card with sensor:
hassio_log_tail:
icon: mdi:library-books
entities:
- sensor.log_tail
to Lovelace
- type: entities
title: Logtail
entities:
- sensor.log_tail
and/or
- type: custom:useful-markdown-card
content: >
[[ sensor.log_tail ]]
or:
- type: markdown
content: >
the entities card shows correctly but the markdown card errors:
using:
content: >
[[ states.sensor.log_tail.state ]]
gives:
while dev-state is showing as it should:
what should I change to get this showing correctly?
this is the sensor definition:
# https://home-assistant.io/components/sensor.file/
- platform: file
file_path: /config/home-assistant.log
petro
(Petro)
2
From the other thread about this, shouldn’t it be:
content: >
[[ sensor.log_tail.state ]]
Notice the word state after your entity_id and the lack of the word states before.
Exact same issue you had here:
The key being
No, that’s what I tried of course, but it shows:
should have mentioned that, sorry
petro
(Petro)
4
in the custom:useful-markdown-card? That doesn’t make sense.
it doesn’t, and it didn’t… I tried all combinations both with the custom card or the regular markdown. Except for this:
title: Logtail
content: >
et voilĂ :
thank you…
petro
(Petro)
6
weather coordinates? That’s odd… You may have found an issue with the custom card.
EDIT: Nevermind, you’re saying it works.
the card now shows my log. that works.
the OWM component doesn’t
nickma
(Nick)
9
with the built in Markdown card the following worked for me:
type: markdown
content: |
{{ states('sensor.log_tail') }}
Ispired by this post.
petro
(Petro)
10
This whole thread was using the custom:markdown card prior to the existence of Jinja templates in the built in markdown card.
petro
(Petro)
12
That you revived an old outdated thread.
petro
(Petro)
14
it is when the main topic at hand is about the useful-markdown-card which is deprecated
nickma
(Nick)
15
Which it wasnt (exclusively). Discussion Done.
petro
(Petro)
17
Deleting the post doesn’t mean I agree with you.
