D’oh! Thanks for that, I had updated the HACS card, but there was another button to “install” or “deploy” or something like that which I failed to notice at first!
Thanks for putting me straight!
Fantastic addon! I really love how smooth and well everything looks, and it has so much configuration options I have one question that documentation was not able to answer (from my searches). Is it possible to disable title/name change when hovering over measure points? Here is quick example:
I manually assign title of the card/graph but it changes to the sensor name when hovering over data points. I know that that might be the desired behavior but still I would prefer to have control over it and disable this function if possible. Any ideas are welcome
Try to use the same name for your card and your entity:
- type: custom:mini-graph-card
name: Air Purifier Pro
entities:
- entity: sensor.home_aqi
Maaan! It works! I can’t imagine I didn’t think about something as simple as this:) Thank you
There is one flaw. When you show two entities like so:
you can’t actually name both the same way
Anyone else seeing Attempted to assign to readonly property
errors? I’ve been having these since updating to the new version of the card. Error was occurring on 0.107.7 and 0.108.0.
A few posts up
Hay bro
how you make this card bit
I’m trying to squeeze the card’s height a little bit but the graph gets an unwanted padding (it doesn’t reach left and right margins anymore). Any help? Here’s the before and after, and the code I’m using:
color_thresholds_transition: smooth
entities:
- entity: sensor.pool
index: 0
- entity: sensor.phlevel
index: 1
show_state: true
y_axis: secondary
font_size: 105
hour24: true
hours_to_show: 24
icon: 'mdi:pool'
line_color:
- orange
- blue
line_width: 12
name: Pool Temp / pH
show:
extrema: true
style: |
ha-card {
height: 220px !important;
type: 'custom:mini-graph-card'
entity: weather.dark_sky
primary_info:
- humidity
- extrema
secondary_info:
- precipitation
- wind_speed
type: 'custom:simple-weather-card'
one question: i integrated the mini-graph-card into ressources.
Then added a manual card by Lovelace UI with the following config:
color_thresholds:
- color: '#FFFF00'
value: 25
- color: '#3498db'
value: 0
entities:
- sensor.speedtest_ping
fill: true
font_size: 70
graph: bar
height: 20
hours_to_show: 72
line_width: 3
points_per_hour: 1
show: null
But it still shows a line, so the graph: bar line seems to be ignored.
I am doing s.th. wrong here?
/ Ralf
Since the update to 108 some of my mini graph cards don’t display the actual graph lines at the first ui load. I have to switch to another page and back (for example Configuration page and then back to the dashboard) in order for the graph lines to appear, otherwise the cards remain blank. Any ideas what may cause this? It worked fine on 107 and I have not changed anything.
In order to display a bar graph you need to put the config under show element like this:
show:
graph: bar
Thanks for the quick help.
Indeed missed the ‘show:’ part - stupid fro me.
Thanks, Ralf
@kalkih Is there a way with Card-Mod to move the position of the graph?
I wish to make the card size really small and move the graph element towards the top of the card as much as posible.
Strange to quote myself…but I didn’t get an answer for multiple senors. Is there a way to make the title not change on mouse over? Because I can’t name both sensors the same way as was suggested (and what actually works).
I have troubles displaying properly the mini graphs on my Samsung Tab S2 tablet as shown on the picture below and this video screenshot :
Thanks for this wonderful card
It’s a real pleasure to monitor temperature, humidity, pool water temperature etc on a wall mounted tablets ! Very nice !
I have a request. As we can display a secondary graph with its own scale (using y_axis), is it possible to have a color_thresholds_secondary ?
I have different thresholds for different types of sensors, but when I display, let’s say a temperature and a humidity sensor on the same graph, color_thresholds cannot be used because it will not be suited for one of them…
Thanks you again @kalkih
Could you post your config Dining? thx
