Lovelace: mini graph card
Beautiful work!
Can you advise is there a way to display entities names aligned with states?
I’m trying to visualise 4 differente temperature entities on one graph:
I’d love to see the names and the states close to oneanother. Is it doable? :slight_smile:
I’m trying to have the blue entity to be drawn on top of the light grey ones:
Is there a way to draw the main entity after the secondary ones?
Or maybe there is a way to display the last entity’s value instead of the first one?
Thanks!
  1. There is an issue for this.
  2. Probably could be fixed by playing with “z-index” for:
    – fill
    – line
    – points
    by card-mod.
Oh thanks! That makes sense. I will follow the issue thread :+1:
Brilliant! If displaying the states of two entities on the card, Is it possible to identify just one entity and display the UoM before the state for just that one - while leaving the other UoM displaying after the state? My use case is displaying $ (before state) and kw (after state) . Thanks.
type: custom:mini-graph-card
entities:
  - entity: sensor.xiaomi_cg_1_co2
    unit: €
  - entity: sensor.xiaomi_cg_2_co2
    unit: $
    show_state: true
  - entity: sensor.mijia_300_1_co2
    unit: €
    show_state: true
icon: mdi:currency-eur
card_mod:
  style: |
    .states > .state {
      flex-direction: row-reverse;
    .states .states--secondary .state:nth-child(2) {
is there any way to have colour threshold per entity in a stacked graph?
align_state: center
icon: mdi:speedometer
line_width: 3
hours_to_show: 168
points_per_hour: 0.2
show:
  extrema: true
  labels: true
  icon_adaptive_color: true
entities:
  - entity: sensor.speedtest_download
    color_thresholds:
      - value: 100
        color: red
      - value: 200
        color: amber
      - value: 300
        color: green
  - entity: sensor.speedtest_upload
    color: red
  - entity: sensor.speedtest_ping
    color: yellow
above gives me: image
instead of: image
if i hard code it to always green
Currently no, these thresholds are card-wide.
Imho these thresholds (especially with fill) for more than 1 sensor might be like “too much info” & confusing.
Can someone explain, why this is always showing the FIRST state and not the last:
>       name: Network RX / TX (7 Days)
>       entities:
>         - entity: sensor.fritz_box_6660_cable_gb_received
>           color: rgb(52, 152, 219)
>         - entity: sensor.fritz_box_6660_cable_gb_sent
>           color: orange
>           y_axis: secondary
>       show:
>         labels: true
>         labels_secondary: true
>         graph: bar
>         icon: false
>       height: 200
>       hours_to_show: 168
>       line_width: 2
>       group_by: date
>       aggregate_func: diff
>       lower_bound_secondary: 0
>       lower_bound: 0
>       style: |
>         ha-card {
>           background:none;
>         rect.bar {
>           filter: drop-shadow(0px 0px 5px rgba(0, 0, 0, 0.3));
>           width:65px;
>         .bars:first-of-type {
>           transform: scaleY(49%);
>         .bars:last-of-type {
>           transform-origin: center;
>           transform: rotateX(180deg) scaleY(49%) translateY(-51%) translateX(-35.5px);
>         .graph__labels.--secondary {
>           flex-direction: column-reverse;
>           align-items: flex-end;
>         .graph__container__svg {
>           margin-bottom: 16px;
For the record: how to show a graph for TODAY only:
Calculate a value for “hours_to_show”:
type: custom:config-template-card
entities:
  - sensor.xiaomi_cg_1_co2
card:
  hours_to_show: >-
      var date = new Date();
      var curHour = date.getHours() + date.getMinutes()/60.0 + date.getSeconds()/3600.0;
      curHour
  entities:
    - sensor.day_vs_night_time
  points_per_hour: 120
  line_width: 1
  smoothing: false
  aggregate_func: last
Here “day_vs_night_time” is a history stats sensor which is set to 0 at 00:00.
But this method is “too precise” because it may give a tiny amount of data from “yesterday”:
As a possible workaround - do not add seconds))).
I have a graph I am trying to create that has two y-axes and I would like to overlay with a state map. The first y-axis is a humidity value. The second y-axis is a humidity derivative sensor I have created. I have that working fine, but I would also like to overlay when the exhaust fan is running on the graph. I cannot figure out how to show that on the same graph. I currently have it as a secondary graph below using a custom stack-in card. Is there a way to show the three on the same graph where the gray fill is just overlaid over the other sensors.
Short answer: no, not with this card, since you’re talking about having 3 y-axes in reality. This might be easier with the Apex chart.
But you could hack it… You haven’t posted your config so I’ll make some necessary assumptions. Give the humidity axis a fixed lower and upper bound of 0% and 100% respectively. Make a template sensor of the exhaust fan’s state that’s 0% for off and 100% for on. You can now plot those two on the same axis.
… or place the 2nd card with the 3rd Y-axis over the 1st card.
Example was provided above, search for “display: grid”.
Yes, very nifty! But, I think, ultimately one must choose the right tool for the job.
Sometimes values of sensors are too different and you cannot place 2 of them on a same axis.
For instance, CO2 + temperature + day/night.
Indeed, which is, with only two axes, I know that humidity is 0-100% so they can scale the overlay to be binary 0 or 100 (these values don’t matter in this case since its purely visual), and the secondary axis can then display the other series.
graph
I’m having some issues with the background of my card. No matter what I do its always cut in two like the picture above.
Anyone have a solution either through card_mod or the mini graph its self? I want the entire background above and below the line to be one color.
Try this and read the manual.
entities:
 - sensor.illumination
align_icon: left
align_state: center
show:
  fill: false
Start with testing the simplest code:
entities:
  - one entity
hours_to_show: 24
Since you have not given a code of your card, people may only guess.
Thanks. Code probably would have helped. :man_facepalming:
After trying the suggestions from both of you neither fixed it and hiding the fill actually made it worse. I decided to use inspector to dig through the css and found a conflicting .graph { section in my theme. After removing that, it’s fixed.
Thanks for the help! Much appreciated.
