Thank you very much for your answer! I have tried hard refresh and clear cache but the problem remains, the triangle is there. I have gone back to the old version (not sure what version numer or where I can check) to get rid of the triangle. I would of course like to use the newer version if it was possible.
Cannot say anything about your config (not a doctor to treat a patient looking at his photo), but in some other cards this âtriangleâ icon usually used for unknown entities.
Oh I must look that I didnt spell the entity wrong, but it did work with the old version. Thank you. Iâll check.
Sometimes entitiesâ names are changing in new HA versions.
Just started with this, so probably a stupid questionâŚ
Is it possible to display the value in each bar ?
type: custom:mini-graph-card
entities:
- entity: input_number.number_aantal_motion_sensor_voordeur
name: Motions on frontdoor
hours_to_show: 168
aggregate_func: max
group_by: date
show:
name: Numbre of motions on frontdoor
icon: mdi:access-point-minus
graph: bar
state: false
labels: true
points: true
I thought âpoints: trueâ would do thatâŚ
No.
Unless someone implements this functionality.
How do I do in order to show a bar for each month? I want the monthly averange electrical price.
Hi folks,
I have a mini graph card inside a custom button card. As I am using templating passing âvariablesâ to the template button card for different sensors, how can I pass to the inside mini graph card the entities as a parameter ? (e.g. instead entities: - sensor.xxx1 , I need something like entities: > [[[ variable1 ]]], where variable1 is already inside the button template)
Any hints if that is possible?
Thanks for your help
Luis
I would really like to have the ability to display values for the x and y axis, is there anyway to accomplish that?
type: custom:button-card
entity: sensor.processor_use
variables:
custom_fields:
graph:
card:
entities:
- entity: '[[[return entity.entity_id]]]'
name: '[[[return variables.NAME]]]'
There is no support for this in an official implementation.
You may only show max/min labels for the Y-axis.
For X-axis there is only a non-elegant & unstable hack like this:
After many hours, itâs time to admit defeat and ask for help: Is it possible to get the states to display on the same line? In this example I would like the temperature for backdoor on the left, Jenni Bedroom in the centre, and Kitchen on the right. But no matter what I try I end up with the two temperatures stacked vertically on the right.
Hi all. I have to ask here, because I canât figure it outâŚ
I have a temperature sensor that is acurate to 0.1 degrees. However, I donât need that accuracy and only want to show a graph of the temperature rounded to the nearest degree. The rounding itself seems to work fine by using the decimals: 0 part. But the graph does not reflect that. As you can see, itâs showing many tiny increments in temperature:
This probably comes directly from the source data:
So how can I set increments for the Y-axis so that it only shows whole degrees (20, 21, 22,âŚ) and not decimals?
The decimal option only affects the state displayed. You didnât share your config, but it looks like youâve deliberately turned smoothing off. I think your best bet is a combination of turning smoothing on and setting y-axis limits to make the âartifactsâ less apparent. Otherwise, create a second template sensor where youâve applied the rounding and display that.
Seems that this option is omitted and hence is =true (default value).
The sensor changes very rarely, hours_to_show=24h, points_per_hour=30 - this looks like the graph is with âsmooth=falseâ, but it could look same with âsmooth=trueâ.
BTW, I always set âaggregate_func=lastâ, âsmoothiing=falseâ, âpoints_per_hour=as many as applicableâ - to reduce an affect of approximation.
Is it possible to use fixed_value to create a height bar per sensor? like this?
this is what i get
type: horizontal-stack
cards:
- type: custom:mini-graph-card
entities:
- entity: sensor.current_l1_tibber
fixed_value: true
show state: true
show:
icon: false
entities:
- entity: sensor.current_l2_tibber
fixed_value: true
show state: true
show:
icon: false
entities:
- entity: sensor.current_l3_tibber
fixed_value: true
show state: true
show:
icon: false
"fixed_value"is used to display one CONSTANT value (flatline).
It has nothing about a height.
What you probably need is:
lower_bound: 0
Thanks!
However, i kinda want that flatline showing only current value out of a max of 50.
The reference i posted is showing not a graph, but only a current state, which for my case would be nice.
How do i do that? Is it possible?
Not clear what you need, elaborate.
