I do not understand. Consider explaining your needs with details & pics, otherwise too cryptic.
Anyone an idea how to change font style of the title?
And what is the standard font style in HA (from scratch)?
greetings
card-mod thread â 1st post â link at the bottom â mini-graph
Itâd be nice if we could use a slider to dynamically adjust hours_to_show. Or better yet, having support for it natively in mini graph.
I mostly use mini graph to show temperature and humidity in each room for the last 24h to give me an idea, but I often want to only see the last 1 to 6 hours to have a bit more details. In order to do so, for a 1-hour step slider for instance, Iâd need conditional cards wirh 24 different cards:
- Now to -1hr
- Now to -2hr
- Now to -3hr
etcâŠ
If someone has a suggestion to achieve this, Iâm all ears. Because the latter solution would be quite cumbersome when you have a mini graph for humidity and another one for temperature in every room. But yeah, having support of it natively would be a blessing!
Thereâs two other options:
- Use config-template-card to template the graph duration based on a helper entity you create.
- Look into apexcharts-card and its brush functionality.
Happy searching ![]()
I am coming back to this to see if anyone can help. I tried to create a template sensor and use that in the graph, but still could not show the legend. Can anyone help me to figure out how to show the state of my input_select helper in the legend of each graph? Or is it just not possible to show the input_select helper state in the legend? Thanks in advance.
I seem to miss something. I want to a bar chart with rounded corners. Similar like the the example with hte custom:bar-chart shown in the screenshot in the lower half. I want similar design, but using custom:mini-graph-card in a bar chart with daily grouped values like shown in the upper part of the screenshot.
How do I get rounded corners in the upper graph?
For reference the YAML code to create both cards
type: vertical-stack
cards:
- type: custom:mini-graph-card
name: Autarkie pro Tag
icon: mdi:solar-power-variant
align_icon: left
align_state: right
group_by: date
hours_to_show: 336
aggregate_func: last
entities:
- entity: sensor.solar_autarky_daily
show:
graph: bar
icon_adaptive_color: true
bar_spacing: 10
lower_bound: 0
upper_bound: 100
color_thresholds:
- value: 0
color: '#e64747'
- value: 10
color: '#e64747'
- value: 30
color: '#e09c3b'
- value: 50
color: '#e6e22e'
- value: 70
color: '#8fb935'
card_mod:
style: |
ha-card {
box-shadow: 0px 0px;
background: none;
- type: custom:bar-card
height: 20
severity:
- color: '#e64747'
to: 29.9
- color: '#e09c3b'
to: 49.9
- color: '#e6e22e'
to: 69.9
- color: '#8fb935'
to: 100
entity_row: true
positions:
icon: false
indicator: false
width: 75%
entities:
- entity: sensor.solar_autarky_monthly
icon: mdi:calendar-blank
target: 70
- entity: sensor.solar_autarky_yearly
icon: mdi:calendar-clock-outline
target: 70
target: 70
card_mod:
style: |
ha-card {
padding: 12px;
margin-left: 12px;
--bar-card-border-radius: 15px;
bar-card-backgroundbar {
opacity: 0.2;
filter: brightness(1);
I want to do a bar graph below, but I donât find a configuration option similar to âchangeâ in the default statistics graph card.
My sensor is an increasing valueâŠ
got my graphs back, and based on other entities this time, all core now, so thats better.
as we have negative prices currently id love that to show in the bars poiting down, but cant find an option to do so in mini-graph-card.
Cant this be done, would appreciate if anyone had tried that.
I do have an apex charts graph, but find that to be very heavy on the system, especially with more than 1 graph per view
it does show what I am after though
please let me know if it can be done with mini-graph-card
hours_to_show: 1
icon: none
name: EasyEnergy electriciteit prijzen
show:
graph: bar
labels: true
legend: false
# extrema: true
# average: true
# lower_bound: 0
flip negative would be nice.
I have the following mini graph card displaying:
- ceiling temperature (blue)
- floor temperature (yellow line)
- night/day alternance: yellow area
- ceiling fan activity (red line)
Everything is fine except the red line. The fan.fan_bureau entity value is âonâ or âoffâ.
When state is off I want to display the line in the bottom of the screen. But it appears in the middle.
As you can see in the code, I use 2 ây_axis: secondaryâ. It may not be the right way to do it but I couldnât find a better way.
Any help will be more than welcome ![]()
Thanks so much !!!
name: Contraste de température
entities:
- entity: sensor.capteur_bureau_temperature
show_graph: true
show_state: true
show_fill: false
- entity: sensor.bureau_temperature_plafond
show_graph: true
show_state: true
show_fill: false
- entity: fan.fan_bureau
color: red
show_legend: false
show_line: true
show_points: false
y_axis: secondary
- entity: sensor.nuit
color: yellow
show_legend: false
show_line: false
show_points: false
y_axis: secondary
show:
labels: true
labels_secondary: true
extrema: true
line_width: 1
font_size: 60
hour24: true
points_per_hour: 60
state_map:
- value: '1'
label: nuit
- value: 'off'
label: 'off'
- value: '0'
label: jour
- value: 'on'
label: 'on'
Try increasing points per hour to 120 and set average func to last.
Thanks for your answer. Do you mean set agregate_fun to last ?
And remove y_axis ? like this:
color: red
show_legend: false
show_line: true
show_points: false
Then it look like this. Indeed the red line is floored but the scale is completely changed if you compare with previous graph.
I would like to keep the temperature range/scale like in my previous post. Just get the red line down, like I did for day/night.
Hey. Hey,
Iâd like to ask you about my problem.
I am monitoring the energy consumption of a small boiler through a smart plug. I use a helper to calculate hourly, daily energy consumption.
When I would graph it it shows me a different value than the helper.
Here is the graph for the last 7 days. Today it shows me 0.08kWh (last bar):
But the current value is 0.16kWh:
Yesterday it was 0.22kWh:
But if I look at historical measures, the last value was 0.45:
Here is my configuration:
icon: mdi:lightning-bolt-circle
hours_to_show: 168
hour24: true
points_per_hour: 1
line_width: 4
group_by: date
entities:
- sensor.boiler_spotreba_1d
show:
graph: bar
labels: true
extrema: true
state: true
average: true
color_thresholds:
- value: 0
color: '#2b603c'
- value: 0.05
color: '#3d8540'
- value: 0.1
color: '#fcef1c'
- value: 0.5
color: '#f6b92b'
- value: 1
color: '#c4252d'
Do I something wrong?
OK.
I have figured it out.
I need to use aggregate_func: last then it show me the last value that represent the energy consumption. ![]()
How did you made the MĂŒlltermine card?
hi, i have issue by reducing my font size, can some please have a look
i want to reduce the font size, and hav try a lot different versions
entities:
- entity: sensor.channel10_temperature
unit: C
font_size: 20
- entity: sensor.channel10_humidity
font_size: 10
font_size_header: 20
unit: '%'
show_state: true
show_graph: false
font_size: 10
Your font options are misplaced. Check the Docs.
So I have been working on this off and on for a while now. I finally got it to show, but there is a catch. In order for the legend to show up, I have to show both legends. I would prefer to only have the legend for the input select helper show up. I have another graph that has 4 entities and I am able to show legends for two of them and hide the other two.
However, this graph only has two entities and I either have to show them both or I get nothing. I am not sure if this is a bug or intended. Like I said, I would prefer to show only the input select. But this at least gets me something.
Here is my code.
type: custom:stack-in-card
card_mod:
style: |
ha-card {
--ha-card-background: rgba(115, 115, 115, 0.25);
--primary-text-color: '#97989c';
border-radius: 10px;
border: none;
cards:
entities:
- entity: input_select.washer
color: '#3182b7'
show_line: false
- entity: sensor.basement_aqara_washer_active_power
color: 'rgb(255,0,0)'
y_axis: secondary
line_width: 1
decimals: 0
hours_to_show: 12
points_per_hour: 60
hour24: true
state_map:
- value: Empty
label: Empty
- value: Complete
label: Complete
- value: Running
label: Running
lower_bound_secondary: 0
upper_bound_secondary: 500
show:
icon: false
state: false
fill: true
points: false
legend: true
extrema: false
labels: false
labels_secondary: false
card_mod:
style: |
ha-card {
border: none;
.graph__legend__item {
justify-content: center
.graph__legend__item:nth-of-type(1) .ellipsis:after {
content: ": {{states('input_select.washer')}}";
color: '#97989c';
.graph__legend__item:nth-of-type(2) .ellipsis:after {
content: ": {{states('sensor.basement_aqara_washer_active_power')}}";
color: 'transparent';
.graph .graph__legend {
font-size: 12px;
entities:
- entity: input_select.dryer
color: '#3182b7'
show_line: false
- entity: sensor.basement_aqara_dryer_active_power
y_axis: secondary
group: true
line_width: 1
decimals: 0
hours_to_show: 12
points_per_hour: 60
hour24: true
state_map:
- value: Empty
label: Empty
- value: Complete
label: Complete
- value: Running
label: Running
show:
icon: false
state: false
fill: true
points: false
legend: true
extrema: false
labels: false
card_mod:
style: |
ha-card {
border: none;
content: ": {{states('input_select.dryer')}}";
color: '#97989c';
content: ": {{states('sensor.basement_aqara_dryer_active_power')}}";
color: '#97989c';
font-size: 12px;
And here is the result.
Also, is there a way to remove the decimal in the legend? I would prefer to have whole numbers without creating a bunch of template sensors.
This is my card @wookiee
card_mod:
style: |
ha-card {
height: 100% !important;
#padding-bottom: 5px !important;
cards:
- type: custom:auto-entities
card:
card_mod:
style: |
ha-card {
--mdc-icon-size: 26px;
margin: 10px;
margin-top: -5px;
border: 0px !important;
height: 160px !important;
.card-content div {
margin-top: 0px !important;
margin-bottom: 0px !important;
height: 24px;
font-size: 14pt;
title: MĂŒlltermine
type: entities
state_color: false
show_header_toggle: false
entities:
- entity: sensor.grune_tonne
card_mod:
style: |
:host {
--paper-item-icon-color: green;
- entity: sensor.graue_tonne
card_mod:
style: |
:host {
--paper-item-icon-color: gray;
- entity: sensor.blaue_tonne
card_mod:
style: |
:host {
--paper-item-icon-color: blue;
- entity: sensor.gelbe_tonne
card_mod:
style: |
:host {
--paper-item-icon-color: yellow;
sort:
method: attribute
attribute: daysTo
reverse: false
numeric: true
ignore_case: true
line_width: 2
font_size: 100
lower_bound: 0
upper_bound: 100000
height: 100
align_header: left
show:
icon: false
legend: false
state: true
entities:
- entity: sensor.kg_lan_fb7530_maximaler_download_durchsatz_der_verbindung
color: '#00FF0022'
show_fill: false
show_legend: false
show_state: true
show_graph: true
- entity: sensor.kg_lan_fb7530_maximaler_upload_durchsatz_der_verbindung
color: '#FF000022'
show_fill: false
show_legend: false
show_state: true
show_graph: true
- entity: sensor.fritzboxdownloadumgerechnet
color: green
- entity: sensor.fritzboxuploadumgerechnet
color: red
hours_to_show: 1
points_per_hour: 60
card_mod:
style: |
ha-card {
height: 250px !important;
margin: 10px;
.header.flex {
font-size: 20px !important;
.states.flex {
font-size: 8px !important;
