thats the point I don’t understand… with the native entities card it works. That’s the reason I tried it with the wrapped entities card in the second example.
With other cards, which had this problem, it worked good as a workaround. But not with mini-graph ![]()
Hi kalkih, Just want to say that I really love this!
Thanks and keep up the good work
Hi @MISEV
Can you share the code for this?
Really nice!!!
EDIT:
Done it!
This is my code
- type: custom:mini-graph-card
align_state: center
icon: mdi:speedometer
show:
extrema: true
labels: true
points: true
entities:
- entity: sensor.speedtest_download
color: green
- entity: sensor.speedtest_upload
color: red
- entity: sensor.speedtest_ping
color: yellow
Thank you, great setup!
@woody4165, Yes that is the code. Only thing you forgot is the s from labels ![]()
labels: true
Is there a way to set the height of the card?
I usually change the line_height to adjust overall card height.
any thoughts why this is showing:
HA 84.3. Ive updated all lovelace cards yesterday and have some issues. Not sure where to look for though. please have a look?
align_state: center
show:
extrema: true
labels: true
points: true
entities:
color: green
color: red
color: yellow
the sensors all exist and are populated.
try to manual update with speedtestdotnet.speedtest
and/or try to clean browser cache
not sure what you mean by this? Ive indeed manually updated via the homeassistant update entity service. but thats of no use, since the sensors are updated correctly, only not displayed in this card now.
Are the sensors showing values other than 0?
Do you have those three sensors in history: and recorder: in configuration.yaml ?
You can adjust the height of the graph with the height option, you also have the various font size options which also affect the overall height of the card.
Check the browser developer console and see if you get any errors there.
Do the history show up in the default history-graph card?
duh, this was really stupid…had taken the sensors out of history a long time ago, since that is a component that never worked in my setup, and I tried to keep the amount of recorded entities as small as possible.
re-added them again:
thanks ! (and again sorry…)
Hi, first of all thanks for this awesome card, really nice.
I just added custom_updater to my install but for some reason it shows n/a on the current version of this card.
What have I done wrong?
I followed the instructions, the cards are working really nice but the version is “n/a”
I have:
“mini-graph-card-bundle.js” in my www folder.
This in the top of my “raw editor”:
resources:
- url: /local/mini-graph-card-bundle.js?v=0.3.3
type: module
This is in my configuration.yaml:
custom_updater:
card_urls:
- https://raw.githubusercontent.com/kalkih/mini-graph-card/master/tracker.json
Edit: I feel so stupid, clicked “Update All” and the version appeared. I clicked “Check” multiple times before but was thinking that “Update All” actually updates the cards/components with new “Available” versions.
Loving this card <3
Is there any way to display a climate thermostat, with the temperatures and the heating ?
Thanks a lot in advance!
Thanks!
No, not unless you create template sensors for each state/attribute you want to display, that should be fairly easy though!
I don’t know if this is a problem with the mini-graph-card or not but…
I have a vertical-stack with a mini-graph-card in it and if I hover over the points on the graph the whole of that vertical stack jitters like mad, but only from the mini-graph-card down (which is why I suspect this card to be the root of the problem).
Unfortunately I can’t show it here short of posting a video but below is a picture of the vertical-stack, followed by my config.
I’m happy to raise a GitHub issue if you think it ‘belongs’ to you
#=== Network & HA Components
- type: vertical-stack
cards:
#=== Network
- type: entities
title: '-- Network --'
show_header_toggle: false
entities:
- entity: sensor.public_ip_address
icon: mdi:ip-network
- type: custom:card-modder
style:
background: transparent
card:
name: ' ' # Internet Speed
align_state: left
hour24: true
points_per_hour: 2
line_width: 3
font_size: 75
font_size_header : 22
show:
icon: false
extrema: true
labels: true
points: true
entities:
color: green
color: red
color: yellow
- type: horizontal-stack
cards:
- type: custom:button-card
color_type: blank-card
name: Do Speed Test Now
lock: true
tap_action:
action: call-service
service: speedtestdotnet.speedtest
color_type: card
color: rgba(20, 20, 20, 0.4)
layout: icon_name_state
styles:
card:
- border-radius: 15px
- border-style: solid
- border-width: 1px
- border-color: '#e5e5e5'
- white-space: nowrap
grid:
- grid-template-areas: '"n"'
- grid-template-columns: 1fr
#=== Component Counts
- type: glance
title: '-- Component Count --'
columns: 4
entities:
- entity: sensor.count_automations
icon: mdi:autorenew
- entity: sensor.count_scripts
icon: mdi:script-text-outline
- entity: sensor.count_zones
icon: mdi:map-marker-radius
- entity: sensor.count_device_trackers
- entity: sensor.count_switches
icon: mdi:light-switch
- entity: sensor.count_sensors
icon: mdi:resistor
- entity: sensor.count_binary_sensors
icon: mdi:unfold-more-horizontal
- entity: sensor.count_input_booleans
icon: mdi:toggle-switch
- entity: sensor.count_input_numbers
icon: mdi:numeric
- entity: sensor.count_input_texts
icon: mdi:alphabetical
- entity: sensor.count_input_selects
icon: mdi:view-list
- entity: sensor.count_input_datetimes
name: Input Date Times
icon: mdi:calendar-clock
I think this is a limitation of the vertical in stack card
I don’t use the vertical-stack-in-card in this part of the config for this view, just the core vertical-stack
I do have the vertical-stack-in-card in this view in ‘column 1’ of three (‘this is column2’) but I tried changing it to a core vertical-stack and I still had the jittering. Just for completeness, ‘column 3’ is the tracker-card
