Looks like the graph gets inverted, seems strange, only the graph is inverted and nothing else.
Try without the “fancy” effect on the swipe card.
Hi!
I want another line horizontally. I’m not a programmer and I don’t understand how.
cards:
- entities:
- entity: sensor.router_power
index: 0
font_size: 75
line_color: blue
line_width: 8
type: 'custom:mini-graph-card'
- entities:
- entity: sensor.j_power_0
index: 0
font_size: 75
line_color: '#e74c3c'
line_width: 8
- entities:
index: 0
font_size: 75
line_color: var(--accent-color)
line_width: 8
type: horizontal-stack
Narrowed it down to the IOS App, the inverting of the graphs only happens there. and only when i touch the screen (points: hover) It still happens when I take out the effects on the swipe card.
I remember reading someone else’s post about the graphs inverting, but I cant for the life of me find the post and/or the solution.
Okay, does it still happen if you don’t nest the it inside the swipe-card as well?
I’ve never seen the issue before.
Found the problem and am kindof embarrased I missed it, as it was infact the effects on the cards like you said. Thought I removed all the code for the effect from the card, but accidently left one line. Works fine without the effects. Thanks for taking your time to help
Would still be cool to be able to use the effects, even though they’re a bit of a gimmick. But I suppose the issue lies in the swipe card and not the graph cards.
Simply add more entities as any of the three you already have
- entities:
- entity: sensor.great_power_great_responsabilities
index: 0
font_size: 75
line_width: 8
If instead you meant inside the same graph, inside the entities simply add it:
- entities:
index: 0
index: 0
font_size: 75
line_width: 8
TBH, I am not sure what “index: 0” does so I am not sure that might or not cause an issue with multiple entities.
Hi! thanks for the quick answer! I misspelled it (sorry). I would like to. so another line
Could you share your config for above?
Hello everyone,
I really love mini-graph-card and I’m trying to use it in a lot of my pages.
I just have a question: is there a way to fill the card with more “graph”?
I tried upper_bound and lower_bound but most of the space of the card is pretty much empty.
Sure! This is a switch and three sensors in a horizontal stack:
cards:
- aspect_ratio: 1/1
color: 'rgba(25, 25, 25, 0.5)'
color_type: card
entity: switch.aquecedor
hold_action:
action: more-info
state:
- color: 'rgb(255, 255, 255)'
icon: 'mdi:radiator'
value: 'on'
styles:
card:
- font-size: 12px
name:
- letter-spacing: 0.05em
type: 'custom:button-card'
- aspect_ratio: 1/1
color_type: card
entity: sensor.temperature_8
show_icon: true
show_name: false
show_state: true
styles:
icon:
- padding-top: 16%
state:
- font-size: 18px
- font-weight: 300
- padding-bottom: 18%
tap_action:
action: more-info
- aspect_ratio: 1/1
color_type: card
entity: sensor.humidity_9
icon: 'mdi:water'
show_icon: true
show_name: false
show_state: true
styles:
icon:
- padding-top: 16%
state:
- font-size: 18px
- font-weight: 300
tap_action:
action: more-info
- aspect_ratio: 1/1
color_type: card
entity: sensor.temperatura
show_icon: true
show_name: false
show_state: true
styles:
icon:
- padding-top: 16%
state:
- font-size: 18px
- font-weight: 300
tap_action:
action: more-info
Hope this helps you!
In that case simply copy the whole thing you pasted below it, and it will create a second row with the same entities, then change the entities to what you need
Did you perhaps use the font_size
options in those graphs? The white space doesn’t scale with them atm which they probably should.
There’s a height option that you can use to increase the height of the graph but that will still not eliminate the white space.
I’ve tried different font_size now that you mentioned and even without it, but still the cards mostly still look the same. (I’ve tried font_size = 10, same graph but now I can’t even see the label)
this is an example card I’m using
That’s was what I was trying to say, the gaps between elements (white space) doesn’t scale with the font size.
Ok, I understand that but even if I disable everything and only leave the graph:line the card looks the same
Looks like 0.106.0b0 breaks the mini graph card.
mini-graph-card TypeError: "0 is read-only"
Mc mini-graph-card-bundle.js:1
setConfig mini-graph-card-bundle.js:1
s create-element-base.ts:39
a create-element-base.ts:58
c create-element-base.ts:102
zt create-card-element.ts:52
_createCardElement hui-stack-card.ts:77
_cards hui-stack-card.ts:39
setConfig hui-stack-card.ts:38
c create-element-base.ts:129
Thanks for the heads up, I’ll take a look at it!
I just came to notify the same
In addition, in home-assistant.log file I found this:
2020-02-19 18:02:38 ERROR (MainThread) [frontend.js.latest.202002190] https://SOME-HIDDEN-HOST/community_plugin/mini-graph-card/mini-graph-card-bundle.js:1:75151 Uncaught TypeError: Cannot add property index, object is not extensible
The View doesn’t load and it loops on requests for historical data forever
Hi Folks,
I’m trying to get tap_action to toggle a switch for my AC zones when I click on a sensor graph, but for the life of me can’t work out the syntax.
here’s my graph, and the ULTIMATE would be having a state sensor for the zone embedded in it, but I’m happy to be able to click on and off to turn the zone on and off
My lovelace YAML currently looks like this, but I just can’t get the tap_action working… any help appreciated !
- type: custom:mini-graph-card
show:
icon: true
height: 35
entities:
- sensor.kitchen
color_thresholds:
- value: 0
color: "#CCE5FF"
- value: 10
color: "#66B2FF"
- value: 18
color: "#0080FF"
- value: 20
color: "#87c087"
- value: 21
color: "#389638"
- value: 22
color: "#FF9932"
- value: 23
color: "#FF8000"
- value: 24
color: "#ff0000"
It should be something like this:
show:
icon: true
height: 35
entities:
- sensor.kitchen
color_thresholds:
- value: 0
color: "#CCE5FF"
- value: 10
color: "#66B2FF"
- value: 18
color: "#0080FF"
- value: 20
color: "#87c087"
- value: 21
color: "#389638"
- value: 22
color: "#FF9932"
- value: 23
color: "#FF8000"
- value: 24
color: "#ff0000"
tap_action:
action: call-service
service: switch.toggle
service_data:
entity_id: switch.ac_switch
