I believe you indentation is wrong, try this:
- type: custom:mini-graph-card
entities:
- entity: sensor.daily_energy
name: Daily Electricity
show:
graph: bar
labels: true
entities:
show:
graph: bar
labels: true
Thatâs done it.
Thank you!
A further question from me.
Iâm measuring energy usage, using the utility meter function.
I have one card for showing me the past 7 days, where the data is grouped by date.
How do I get it to show me by month? So that I have 12 bars, one for each month?
I use this combination of config-template-card and mini-graph-card to generate this bar chart over time. The use of the config-template-card is only to create a dynamic title for the chart. And the use of the âstate_mapâ is only needed because the state value is text not numeric. Perhaps this will give you some ideas:
- type: 'custom:config-template-card'
variables:
- states['sensor.air_quality_living_room'].state
entities:
- sensor.air_quality_living_room
card:
name: "${ states['sensor.air_quality_living_room'].attributes.room + ' updated (hh:mm:ss) ' + states['sensor.air_quality_living_room'].attributes.update_age_text + ' ago' }"
icon: mdi:smog
hours_to_show: 12
labels: false
entities:
aggregate_func: max
points_per_hour: 8
bar_spacing: 1
font_size_header: 16
upper_bound: 3
lower_bound: 0
show_legend: false
state_map:
# - value: "-1"
# label: ""
# - value: "0"
# label: ""
- value: "-1"
label: Unit Sleeping
- value: "1"
label: Good
- value: "2"
label: Fair
- value: "3"
label: Poor
show:
points: false
state: true
legend: false
graph: bar
labels: false
I think the max in Lovelace cards is 168 hours, any more then that and you have to use Grafana/influx or similar setups!
Unfortunately you canât do that, you can have the whole year of data showed, but not grouped by month.
You would end up having something like this:
OK. Understood. Thanks.
Would you mind sharing your YAML for how you convert to euros? I would like to do this to GBP.
Thanks!
My code is all available here:
Itâs quite complicated my setup so youâll need to dig the code to understand how the view integrate with templates and thresholds, but with some time and patience youâll be able to get what you need out.
Hello, at the moment i am plotting current and target temp along with heating percentage in same plot.
I want to add current and target temp value beside the legend. i know i can do this with config-template-card. I tried following code, but didnt work. can anyone point me to the right direction?
variables:
current_temp: states['bedroom_temperature'].state
heating: states['bedroom_heating'].state
target_temp: states['target_temp_bedroom'].state
entities:
- sensor.bedroom_temperature
- sensor.bedroom_heating
- sensor.target_temp_bedroom
card:
type: 'custom:mini-graph-card'
entities:
- entity: sensor.bedroom_temperature
name: "${'Temp ' current_temp}"
#name: Temp
- entity: sensor.bedroom_heating
color: grey
show_line: false
show_points: false
show_legend: true
y_axis: secondary
- entity: sensor.target_temp_bedroom
show_line: true
show_ponts: false
show_fill: false
hours_to_show: 24
group: false
hour24: true
line_width: 2
points_per_hour: 10
show:
extrema: true
icon: true
labels: true
labels_secondary: true
You are missing the âsensorâ in the variables state and some issue in your template:
variables:
current_temp: states['sensor.bedroom_temperature'].state ## Missing sensor
heating: states['sensor.bedroom_heating'].state ## Missing sensor
target_temp: states['sensor.target_temp_bedroom'].state ## Missing sensor
entities:
card:
entities:
name: "${'Temp ' + current_temp}" ### Missing +
#name: Temp
color: grey
show_line: false
show_points: false
show_legend: true
y_axis: secondary
show_line: true
show_ponts: false
show_fill: false
hours_to_show: 24
group: false
hour24: true
line_width: 2
points_per_hour: 10
show:
extrema: true
icon: true
labels: true
thanks a lot, its perfect now.
Hi fellow mini-graph-card users
Iâm trying to help @kalkih with this card, and weâre evaluating the possibility of using an external library to build the graphs. We think that it would give you (and us) a lot more possibilities.
You can see some of the examples of what you could build here
And just a screenshot below:
That would come with a lot of breaking change and some feature loss, at least at the beginning (stuff like state_map or color_threshold for eg would probably be missing initially), but would bring a lot more possibilities to this card in the future (zooming, all kinds of charts, unlimited number of axis, displaying axis, etcâŠ).
Before we start to try to integrate it since it will require quite a lot of work, weâd like to understand if that is something in which youâd be interested in.
Yay, that would be great
No, keep the card as it is
0 voters
Thanks for your feedback
I definetely like the look of it, but I would highly recommend to have it realeased only when the current options set can be replicated, this to avoid many many users having the card broken and asking for help
(specially the two you menthioned I would say)
Beside, not sure if this graph engine will allow, but maybe you can also introduce different style (such as âcakeâ for example that could be very useful)
It will be hard to replicate the same options with the same format I think, but weâll see how it goes if we try it.
On your other question, you have other examples of what the graph library can do here
This sounds nice and progress is good.
My suggestion is more on the practical side: Perhaps it would be good to use a new card name and see this really as a new card. You then freeze the development of this card but perhaps support a few new HA versions into the future in case of breaking changes in HA. That way, users can transition cards bit by bit instead of all at once. I donât have that many cards but other users may.
Good feedback, thanks.
I vote for this.
My best wishes to developers!
Thank you very much for your efforts.
New card name sounds best to me also.
Thanks for all the work.
agree. New card and possibly end of development/support for current one is the most practical choice
