Lovelace: Mini Media Player
Please read the docs and try them. Look at when_standby.
I’ve just tried both, with no change to behaviour.
when_standby: true
when_idle: true
Then I think your options are to use card-mod (expanding on what you have in the config you shared) or make a background image that matches what size a cover would be when the player is on.
Thanks Pieter, I hadnt thought of the background image, that could work well… will investigate!
While investigating how to do the background image, I came across the idea of using card_mod to set hight. I’m sure I’d tried that already, but nevertheless tried again and voila, the below solves the problem. Now I just need to work out how to centre the text vertically (place-self: center doesn’t seem to work in this section)
      - type: custom:mini-media-player
        card_mod:
          style: |
            ha-card {
              height: 65px;
Is it possible to have vertical volume slider?
This thread was a looong time ago! Need to pick your brains. I have the yaml below…based on your post. I have two questions.
First, you will note that I am repeating exactly the same styling for each mini-media-player card. (I will eventually have 8 of them!). There must be a way of moving the styling up a level, once, so that all cards reflect the styling. Try as I might, I can’t get it to work. Maybe its a css specificity thing? Or a syntax thing. Have tried 50 combos. to no avail.
Second, I’d like a bottom divider (border) between the cards. Just a 1 pixel straight line. No matter what I do, even editing the css in dev tools, I can’t get it to work!
Thanks in advance.
- type: custom:vertical-stack-in-card
        title: Matrix
        cards:
            entity: media_player.xantech8_main_xxx
            hide:
              play_pause: true
              prev: true
              next: true
              info: true
              volume_level: false
            group: false
            source: full
            sound_mode: full
            card_mod:
              style: |
                ha-card div.mmp-player {
                  padding-bottom: 0px;
                ha-card div.mmp-player__adds {
                  min-height:40px !important;
            entity: media_player.xantech8_z2_porch_rear
            hide:
              play_pause: true
              prev: true
              next: true
              info: true
              volume_level: false
            group: false
            source: full
            sound_mode: full
            card_mod:
              style: |
Questions above still valid. But the divider thing is a non-thing.
I have a working integration of mini media player and custom sonos card.
Look’s like this (with full access to favorites, grouping etc… from the sonos card.
I would love to be able to show the currently playing playlist (it’s an attribute) in the top right of the mini media player card. Is it possible? Could it be added?
Thanks.
Why not use a decluttering card and put all the players in there. My DAX88 Xantech8 players are done that way.
decluttering_templates:
  mediaplayer:
    default:
      - mediaplayer: media_player.xantech8_deck
    card:
      type: custom:mushroom-media-player-card
      tap_action:
        action: call-service
        service: media_player.toggle
          entity_id: '[[mediaplayer]]'
      entity: '[[mediaplayer]]'
      layout: horizontal
      fill-container: true
      show_volume_level: true
      collapsible_controls: false
      use_media_info: true
      volume_controls:
        - volume_set
      card_mod:
        style:
          mushroom-shape-icon$: |
            .shape {
              perspective: 7px;
            ha-state-icon {
              {% if is_state(config.entity,'on') %}
                {% set animation_sec_min = 0.15 %}
                {% set animation_sec_max = 5 %}
                {% set vol_min = 0 %}
                {% set vol_max = 0.7 %}
                {% if state_attr(config.entity,'volume_level') > vol_max %}
                  {% set input_value = vol_max %}
                {% else %}
                  {% set input_value = state_attr(config.entity,'volume_level') %}
                {% endif %}
                {% set output_value = (input_value - vol_max) / (vol_min - vol_max) * (animation_sec_max - animation_sec_min) + animation_sec_min %}
                animation: music {{output_value}}s ease-in-out infinite alternate;
              {% endif %}
            @keyframes music {
              0%, 100% { transform: translateY(0px) scaleX(1); }
              20% { transform: translateY(2px) scaleX(0.9); }
              40% { transform: rotateY(10deg) rotateZ(-10deg); }
              60% { transform: translateY(-4px) scaleX(1.1); }
              80% { transform: rotateY(-10deg) rotateZ(10deg); }
Then I use this to draw every media player (which is actually multiple cards, see image below):
      - type: custom:stack-in-card
        view_layout:
          grid-area: col2
        mode: vertical
        cards:
          - type: custom:auto-entities
            card:
              type: vertical-stack
              show_header_toggle: false
              state_color: true
              square: false
              title: Music Zones
            card_param: cards
            filter:
              template: >
                {% for MEDIAPLAYER in states.media_player |
                selectattr("entity_id","in",integration_entities("xantech")) -%}
                  {% set SELECTZONE = "input_select.dax_source_" + (MEDIAPLAYER.entity_id).split("xantech8_")[1]
                  {% if MEDIAPLAYER.entity_id != "media_player.xantech8_xantech_house_audio"
                        'type': 'custom:layout-card',
                        'layout_type': 'custom:grid-layout',
                        'layout': {
                          'max_cols': 3,
                          'grid-template-columns': 'auto 150px'
                        'cards': [
                          'type': 'custom:decluttering-card',
                          'template': 'mediaplayer',
                          'variables': [
                             'mediaplayer': MEDIAPLAYER.entity_id
                            "type": "custom:mushroom-select-card",
                            "entity": SELECTZONE,
                            "name": "Set Zone Sources",
                            "layout": "horizontal",
                            "icon_type": "none",
                            "primary_info": "none",
                            "secondary_info": "none",
                            "card_mod": {"style": "ha-card {box-shadow:  none;}"}
                  {%- endif %}
                {%- endfor %}
This is what the whole panel look like, the area highlighted is what this draws:
While this uses mushroom, you could do the same with mini-media-player
i want card corner more radius, why radius not work, anybody help me please
    artwork: full-cover
    entity: media_player.demir
    idle_view: when_idle
    info: scroll
    max_volume: 100
    sound_mode: full
    volume_stateless: false
    hide:
      icon: true
    toggle_power: true
    card_mod:
      style: |
        ha-card {
          width: 200px;
          height: 200px;
          card-border-radius: 90px;
          margin-left: auto;
          margin-right: auto;
          margin-top: 150px;
          background: transparent;
Very cool. Thanks!
Hi, i have an issue with the covers. Its not a mini media player problem, i belive, is most a css problem.
I have the aspect ratio like this:
      ha-card {
          aspect-ratio: 1 / 1;
And i have 3 vertical stacks, all works great this way but if i put the 3 vertical stacks inside and horizontal one in some random songs the player is bigger than the vertical stack as you can see in the image.Only the player is bigger, the rest of the content of the vertical stack remains in its original size. The player overflow the stack and goes behinds the next vertical stack,
If i remove the aspect-ratio the problem is fixed but i need it. Does anyone know a way to avoid this issue?.
Thanks in advance.
EDIT: Easy fix. In case anyone encounters the same problem
      ha-card {
          width: 100% !important;
Soo close.
Am loving mini media player and card-mod (and lovelace_gen).
But stuck on two things.
In the image below, I want to change the down icon to an input icon, and I want to make the volume and transport icons bigger - and bonus - increase size of power icon.
I have tried every thing I could find in the (long) thread…but without success.
Existing yaml snippet below:
          entity: media_player.samsung_q90_porch
          volume_stateless: true
          artwork: cover
          scale: 1.1
          source: icon
          info: scroll
          group: true
          hide:
            jump: false
            volume_level: false
            power_state: false
          card_mod:
            style: |
              :host {
                margin: 12px 12px 12px 12px !important;
              .entity__info__name {
                font-size: 15px !important;
                #color: magenta !important;
              div.mmp-player__adds mmp-media-controls {
                opacity: 75%;
                font-size: smaller;
              div.mmp-player {
                border: 0px solid rgba(0,0,0,0.12);
                border-radius: 12px 12px 12px 12px;
                margin-left: 12px;
                margin-right: 0px;
Can you post the entire cards code? The icon sizes are tied to a multiplier --mmp-unit:
Do you care if the TV gets bigger too?
PS…I like the card layout!
cards:
    entity: media_player.media_players
    artwork: cover
    scale: 1.1
    source: icon
    info: scroll
    group: true
    hide:
      volume: true
      controls: true
      progress: true
    toggle_power: false
    card_mod:
      style:
        mmp-powerstrip $: |
          ha-icon-button {
            color: red !important;
          ha-card {
             --mmp-icon-color: yellow !important;
             --mmp-text-color: lime !important;
             --mmp-unit: 1.5 !important;
             --mdc-icon-size: 50px  !important;
    artwork: null
    scale: 1.1
    source: icon
    info: scroll
    group: true
    hide:
      icon: true
      info: true
      volume: false
      power: true
      progress: true
    toggle_power: false
    card_mod:
      style: |
        ha-card {
           --mmp-text-color: blue !important;
If my code works for you, I’d still would like the whole card to possibly use…
I would prefer individual control. I inserted your helpful code and I’ve tried playing with --mmp-unit, but it wrecks havoc! ).
card_mod:
    style: |
      ha-card {
        --mmp-unit: 1.1 !important;
        --mdc-icon-size: 32px  !important;
      :host {
        opacity: 75%;
        font-size: smaller;
      div.mmp-player {
        margin-left: 12px;
        margin-right: 0px;
The main file code is below, but if you want it all, I’d need to make a repo - which I can. There’s a lot of code for the fancy dpad!
Full Main File Code:
# lovelace_gen
# setup variables
{% set dpad_entity = "remote.samsung_q90_porch" %}
{% set menu_entity = "media_player.samsung_q90_porch" %}
{% set dpad_menu_icon_color = "white" %}
{% set dpad_menu_bg = "dimgrey" %}
{% set dpad_menu_br = "10px" %}
{% set dpad_bg = "lightgrey" %}
{% set dpad_icon_color = "black" %}
{% set dpad_br_center = "0% 0% 0% 0% / 50%" %}
{% set btn_data = {
  "btnTopLeft": {"command": "KEY_INFO", "icon": "mdi:information-variant"},
  "btnTopRight": {"command": "KEY_MENU", "icon": "mdi:tools"},
  "btnBotLeft": {"command": "KEY_RETURN", "icon": "mdi:arrow-u-left-top"},
  "btnBotRight": {"command": "KEY_HOME", "icon": "mdi:home"},
  "btnLeft": {"command": "KEY_LEFT", "icon": "mdi:arrow-left-thick"},
  "btnUp": {"command": "KEY_UP", "icon": "mdi:arrow-up-thick"},
  "btnRight": {"command": "KEY_RIGHT", "icon": "mdi:arrow-right-thick"},
  "btnDown": {"command": "KEY_DOWN", "icon": "mdi:arrow-down-thick"},
  "btnCenter": {"command": "KEY_ENTER", "icon": "mdi:circle-outline"}
{% set shortcut_data = [
  {"command": "JBL BAR 9.1", "icon": "mdi:hdmi-port", "color": "black"},
  {"command": "Peacock TV", "icon": "fapro:peacock#fullcolor"},
  {"command": "Prime Video", "icon": "si:prime", "color": "rgb(0,168,225)"},
  {"command": "Netflix", "icon": "fapro:netflix#fullcolor"},
  {"command": "YouTube TV", "icon": "mdi:youtube-tv", "color": "rgb(255, 0, 0)"},
  {"command": "YouTube", "icon": " fapro:youtube#fullcolor"},
  {"command": "Apple TV", "icon": "si:appletv", "color": "black", "size":'64px'},
  {"command": "ESPN", "icon": "fapro:espn3#fullcolor", "size":'48px'},
  {"command": "Paramount+", "icon": "fapro:paramounto#fullcolor", "size":"64px"},
  {"command": "KEY_ENTER", "icon": "mdi:circle-outline"},
{% set test = (btn_data | tojson) %}
# remote_command, remote_icon
# send variables to include file
button_card_templates:
  !include
    - includes/components/dpad/dpad_bc_template.yaml
    - dpad_bg: {{ dpad_bg }}
      menu_bg: {{ dpad_menu_bg }}
      menu_br: {{ dpad_menu_br }}
      dpad_entity: {{ dpad_entity }}
      menu_entity: {{ menu_entity }}
      menu_icon_color: {{dpad_menu_icon_color}}
      dpad_icon_color: {{dpad_icon_color}}
      dpad_br_default: {{ dpad_br_center }}
title: My Awesome Home
  # View tab title.
  - title: Example
    type: masonry
    cards:
        card_mod:
          style: |
            ha-card {
              max-width: 388px;
              #lenght: 500px;
              #height: 65px;
              #border-radius: 20px;
              #margin-bottom: 1px;
        cards:
          artwork: cover
          scale: 1.1
          source: icon
          info: scroll
          group: true
          hide:
            jump: false
            volume_level: false
            power_state: false
          card_mod:
            style: |
              ha-card {
              :host {
                opacity: 75%;
                font-size: smaller;
              div.mmp-player {
                margin-left: 12px;
                margin-right: 0px;
        # ********* top menu shortcuts ***********
        - !include
            - includes/components/services_menu.yaml
            - menu_bg: {{ dpad_menu_bg }}
              btn_data: {{ btn_data }}
              shortcut_data: {{shortcut_data}}
        # ********* dpad shortcut ***********
        - !include
            - includes/components/dpad/dpad.yaml
              entity: {{ entity }}
        #- type: custom:button-card
        #  entity: media_player.samsung_q90_porch
        #  name: >
        #      return entity.attributes['source']
        #  icon: mdi:circle-outline
        #  name: {{(test | fromjson).btnTopLeft.icon}}
I don’t get the same spacing issues you see with your code. Can you test removing the max width?
--mmp-unit: has to be at least 2.1
card_mod:
  style: |
    ha-card {
      #lenght: 500px;
      #height: 65px;
cards:
    artwork: cover
    scale: 1.1
    source: icon
    info: scroll
    group: true
    hide:
      jump: false
      volume_level: false
      power_state: false
    card_mod:
      style: |
        ha-card {
          --mmp-unit: 2.1 !important;
        :host {
          opacity: 75%;
          font-size: smaller;
        div.mmp-player {
          margin-left: 12px;
          margin-right: 0px;
I think you can scale your mod code down a bit
cards:
    artwork: cover
    source: icon
    info: scroll
    group: true
    hide:
      jump: false
      volume_level: false
      power_state: false
    card_mod:
      style: |
        ha-card {
          --mdc-icon-size: 40px  !important;
          font-size: 10px !important;
          opacity: 75%;
You rock. Your code got me moving in the right direction!
Below is a pic and below that is the card-mod stuff.
You will note that I did the opposite of scaling down the card-mod code! I’m only a few weeks into homeassistant, yaml, card-mod etc… so I’m using this little component to help me understand how it all works.
I don’t actually understand it all – but I’ve fudged it and my code works.
Here’s what I think I understand, but would love plain English explanations of:
  1. There are two modes in card-mod, object mode and text/css. Default is ā€˜object mode’ that let’s us navigate to elements. We use a $: to get into a shadow-root. When we get to the element we want to style we use the pipe (|) + newline, that now puts us into css/text mode for applying the actual styles.
  2. I don’t know what ā€œ.:ā€ actually does, but I’m guessing it moves us up a level in the object hierarchy and we can start with #1 again, from that point in the hierarchy. I don’t quite know why we need the ā€œ.:ā€ if we don’t need to go up a level, but I can’t find any other way (see ha-icon-button stuff in code below).
I’m sure I’m missing the joke, and certain that I am using terrible syntax to describe it all. As I said I’m a newbie. If folk can unpack #1 and #2 it would be super helpful, for me and all other newbies!
Right, here’s the card:
I have changed the icon sizes and text styles of various elements in mini-media-player and adjusted formatting so it sits nicely with the menu and dpad below.
I would love to switch the dropdown icon for an mdi:import icon, but can’t figure out if and how that would be possible.
And now the code (for the mini-media-player):
          artwork: cover
          scale: 1.1
          source: icon
          info: scroll
          group: true
          hide:
            jump: false
            volume_level: false
            power_state: false
          card_mod:
            # the pipe ("|") + newline says what follows is a string block.
            # we need it behind any css styling. but not before object oriented shadowroot selection
            # when in object mode, the ".:" seems to be needed to reselect the current level of objects.
            style:
              mmp-powerstrip:
                  ha-icon-button:
                      mwc-icon-button:
                        # increase the size of the power button
                          button {
                            padding: 4px !important;
                            justify-content: flex-end !important;
                            --mdc-icon-size: 36px;
                            --mmp-unit: 2.1;
                  # the pipe moves us up a level (in object mode) to the mmp-powerstrip$
                  # i don't understand it exactly. but it works!
                  # styling the ha-icon-button, the parent of mwc-icon-button
                  # don't need it. just to show it can be done.
                  # mmp-source-menu -- shrink the dropdown icon
                    ha-icon-button {
                      # for testing padding-left: 180px;
                    mmp-source-menu {
                      --mmp-unit: 2.1;
                      --mdc-icon-size: 24px;
              # ".: |" seems to say, move up a level (in this case to ha-card $)
              # the pipe puts us into css selector mode (string)
              # there is no shadow-root in the way of accessing the below.
              # set the device name size .entity__info__name
              # increase the size of volume and transport controls
              # .mmp-player__adds > mmp-media-controls
              # finally go up a level (mini-media-player) create a margin
              # using :host
                  font-size: 16px !important;
                  /* color: magenta !important; note css style comments */
                .mmp-player__adds > mmp-media-controls {
                :host {
                  margin: 12px 12px 0px 12px !important;
              div.mmp-player__adds>mmp-media-controls:
              # finally, shrink and fade the displayed volume % and push it right a little.
                  div.--buttons.mmp-media-controls__volume.flex>span {
                    opacity: 75%;
                    font-size: 12px !important;
                    padding-left: 6px;
Check out this guide if you haven’t already
As usual thanks. Yes - I’ve read so many of those links!
Can you explain what exactly .: means? I have it working, but don’t know what it means. i.e. select parent object from current level?
