Sorry the conversation has got confused. I was replying to @RobertJB
I wondered if anyone had found a way to pop-up the media browser from a button/shortcut on the mini media player. The media control card has it available, but its lack of customiseability is terrible. I canāt figure out a way to do it, but wondered if anyone else had worked it out. I know we can tap on the card for more info and get it there, but thatās not very intuitive.
Trying to fire a browser-mod popup off a shortcut button but Iām not getting much luck. Keep getting the error Failed to perform the action fire-dom-event/undefined. required key not provided @ data['service']. Got None
The popup works fine in tap_action on the entire card though. Using the light & telephone buttons to test the browser-mod service.
type: custom:mini-media-player
entity: media_player.android_tv_192_168_1_216
name: Main Hall Cast
source: icon
artwork: material
shortcuts:
columns: 4
hide_when_off: true
buttons:
- icon: mdi:lightbulb
type: service
entity_id: light.main_hall_lights_l2
- icon: mdi:phone-classic
type: service
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Tablet Setup
timeout: 200
content:
square: true
columns: 3
type: grid
cards: null
- icon: mdi:remote-tv
type: service
browser_mod:
title: Cast Controls
dismissable: true
card_mod:
style: |
ha-dialog$:
div.mdc-dialog div.mdc-dialog__scrim {
backdrop-filter: blur(5px);
ha-dialog {
--vertical-align-dialog: center !important;
--mdc-dialog-min-width: 50px;
--mdc-dialog-max-width: 400px;
--mdc-dialog-min-height: 350px !important;
content:
type: vertical-stack
cards:
- type: custom:android-tv-card
card_mod:
style: |
} ha-card {
margin-bottom: 20px; }
remote_id: media_player.android_tv_192_168_1_216
keyboard_id: media_player.android_tv_192_168_1_216
media_player_id: media_player.android_tv_192_168_1_216
hold_action:
action: more-info
tap_action:
browser_mod:
dismissable: true
card_mod:
style: |
ha-dialog$:
ha-dialog {
I am a newbie to mini media player and I have the card on my dash to control a mini pc (Libreelec/Kodi).
I have a seperate card using WOL to turn the pc on, is it possible to use the power button on the media player card to do this? Effectively intergrate the WOL button to the player card?
If anyone has any suggestions I would be ever so grateful.
Welcome to HA!
Your best bet is probably to create a new media player entity using the Universal Media Player integration, and then use that on the card.
This should allow you to set the turn_on
action to your WOL action.
and nobody answerdā¦ Iām looking for the same thing.
@nickrout not everybody is as good as you and comes here to ask (maybe for you) silly questions, but even after reading the manual and searching for hours I also havenāt found the answer,
At a guess card-mod.
Hi @SirMarco, Donāt know if you found a solution.
But Iāve found a temporary ādirtyā solutionā¦
If you go to the file www\community\mini-media-player\mini-media-player-bundle.js
edit line 1013 from height: 24px; to (in my case I took) height: 95%; the images will be resized.
question still stays (as we otherwise need to change this at every update ;-)) if anyone knows the correct card-mod syntax, please enlighten me as Iāve tried all of them, but they never got changedā¦
This works for me:
card_mod:
style:
mmp-shortcuts $:
div.mmp-shortcuts__buttons mmp-button.mmp-shortcuts__button div: |
img {
height: 95% !important;
Canāt say I like the result much - it depends on the size of the original image I suppose. With the larger images I use, it makes the buttons ridiculously proportioned. The fixed height is there to constrain the button height I guess.
Is the solution to just use a larger image with the smallest margins possible?
@reste_narquois youāre a champ!
Thanks thatās what Iāve been looking for. % isnāt really doing what itās supposed to, but when I change it tot 60px is really what I want
Helo all! I am looking for some inspiration for my NSPanel Pro music dashboard, as I am done with the mini media player section what I donāt have figured out is a beautiful and elegant solution to select/browse music when you tap on the card. Any of you implemented such a solution, would you mind sharing? Thanks!
Hallo!
I want to use the mini media player zu hear radio on the EchoDot
This card i have;
This is my radio station:
Radio 21
I tried this. But it does not work!
type: media-control
entity: media_player.gunters_echo_dot
artwork: cover
info: short
shortcuts:
buttons:
- name: Radio21
icon: mdi:radio
type: music
so i need some help!
it show something like this:
Translate please
If you want to use the mini media player card, you should use
I have no idea, what āmedia-controlā is
@EddieFAF I change the type and it looks better
When i switch the play button i hear no music.
Do I actually have to change the configuration.yaml?
Or can I make all the settings on the mini media card?
Do you perhaps have a code that I can use where I only change the url of the radio station
Please look at the very extensive docs.
Would you care to share the musiccast-logo-new.png? Thank you.
Hallo @ All
I tried it another way:
HA - Automation - Script - made a new script
in yellow: The media player does not support media browsing
yaml mode:
action: media_player.play_media
entity_id: media_player.gunters_echo_dot
media_content_id: media-source://radio_browser/e417eec8-b2ad-466f-9a3c-ce4abd05c37a
media_content_type: music
metadata: {}
The result on the EchoDot is:
to send TTS; please send annouct like true; music cant be played this way
What mistake am I make?
