This is the location
Is it better to use configuration.yaml or lovelace to do my settings?
Lovelace and configuration.yaml are 2 totally different things for totally different usesâŠ
Would I be right in saying that if you are using storage for Lovelace and not the yaml that I could not use this custom mini media player?
Youâve not followed the instructions correctly, youâve downloaded the source and not the release.
Please go through the instructions again.
With the release of v1.0.0, I feel like this would be the next step.
No, you can use custom cards in storage mode as well, I just donât cover the setup process in my instructions.
Check this post
Hi, iâve updated to the last version 1.0.1
now iâm bit confused about the tts config, this is my config :
entities:
- entity: media_player.beoplay_m5
group: true
icon: 'mdi:speaker-wireless'
power_color: true
show_progress: true
show_source: true
type: 'custom:mini-media-player'
- entity: media_player.google_home
group: true
icon: 'mdi:google-home'
power_color: true
show_progress: true
show_source: true
show_tts: google
- entity: media_player.google_home_mini
group: true
hide_controls: false
icon: 'mdi:dots-horizontal-circle'
power_color: true
show_progress: true
show_source: true
show_tts: google
- entity: media_player.chromecastsalotto
group: true
icon: 'mdi:google-chrome'
power_color: true
show_progress: true
show_source: true
- entity: media_player.chromecast_soggiorno
group: true
power_color: true
show_progress: true
show_source: true
show_header_toggle: false
title: Media Players
type: entities
iâve to change anything?
Thank you for this card; fantastic!
Iâm trying to get the shortcuts to work for a streaming radio station. I pulled the url (id) from the entity.attribute.media_content_id listed in the HA interface. This isnât working. Can anyone help? Specifically looking at CBC Radio 1 Toronto:
- type: custom:mini-media-player
entity: media_player.office
group: true
artwork: full-cover
source: icon
info: short
shortcuts:
buttons:
- name: CBC
icon: mdi:heart
type: music
id: http://cbc_r1_tor.akacast.akamaistream.net/7/632/451661/v1/rc.akacast.akamaistream.net/cbc_r1_tor
Yes, Iâve updated your configuration to work with the new options, see below.
To summarise the changes relevant to your setup, show_source, show_progress and power_color were moved into the hide object and there renamed to source, progress & power_state. source and progress are visible by default and power_state is hidden.
The tts option now takes an object, to enable the addition of the new optional tts options such as language and target entity.
- type: entities
entities:
- type: 'custom:mini-media-player'
group: true
hide:
power_state: false
group: true
hide:
power_state: false
tts:
platform: google
group: true
hide:
power_state: false
tts:
platform: google
group: true
hide:
power_state: false
group: true
hide:
power_state: false
Thank you, your configuration looks alright, what is the platform of the media player? Also do you get any errors?
Thanks for the link and information. Worked like a charm
Hi !
The âfull-coverâ artwork option actually does not display the entire cover in case of vertical artworks (movie posters for instance). See example below:
So I tried âfull-cover-fitâ option, which works great in this case. see screenshot below:
However, when the artwork is in âlandscapeâ, the âfull-cover-fitâ options adds black margins on top and bottom of the image :
So, is there a way to have a fit-to-width option or something similar ?
Thanks !
thanks
The media player is a Google Chromecast Audio.
Right now the card looks for the media_content_type, if itâs music the card assumes the artwork is a perfect square 1:1 (album cover). If itâs video the artwork expects a thumbnail in 16:9 format and resizes the card accordingly.
This behaviour is very similar to the default media-control
card.
full-cover-fit
always displays in a square but instead of cropping the artwork it will resize it to fit and then display black bars if the aspect ratio isnât 1:1.
I donât think Iâll add any more artwork parameters, but Iâm open to consider pull requests.
Just tried on one of my own CCAs and it worked, took a good 10-15sec for it to start playing though.
Youâre correct⊠clearly I was just being impatient!
seems I found a bug with the sync_volume options for the Sonos Group
evenif I have not grouped my Sonos Player the volume will be synced across both players (see video)
I get also two error messages in my log
Error doing job: Task exception was never retrieved
File â/usr/lib/python3.5/asyncio/tasks.pyâ, line 241, in _step
result = coro.throw(exc)
File â/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.pyâ, line 289, in _handle_service_platform_call
await func(entity, data)
File â/usr/lib/python3.5/asyncio/futures.pyâ, line 380, in iter
yield self # This tells Task to wait for completion.
File â/usr/lib/python3.5/asyncio/tasks.pyâ, line 304, in _wakeup
future.result()
File â/usr/lib/python3.5/asyncio/futures.pyâ, line 293, in result
raise self._exception
File â/usr/lib/python3.5/concurrent/futures/thread.pyâ, line 55, in run
File â/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/init.pyâ, line 515, in set_volume_level
raise NotImplementedError()
NotImplementedError
and
Not passing an entity ID to a service to target all entities is deprecated. Use instead: entity_id: âallâ
Okay, interesting!
Iâve no Sonos myself so Iâm not able to test the Sonos specific features very well unfortunately.
Next time you have this bug (or if itâs present all the time), please send me the attributes of both Sonos entities.
You can find the attributes by opening the sidebar and pressing the < > icon at the bottom, or navigate to /dev-state
The errors you posted are most likely related to this bug.
Thanks!
Attributes from the master player:
shuffle: false
sonos_group: media_player.schlafzimmer
supported_features: 64063
media_content_type: music
volume_level: 0.2
source_list: B5 aktuell,ego FM,PULS,Superfly FM
friendly_name: Schlafzimmer
entity_picture: /api/media_player_proxy/media_player.schlafzimmer?token=fc9a990b7b815d96a423b762c3a5bf45a832357d25dea9c3d8457330f3da75a5&cache=bef7ea045c969302
source: Superfly FM
is_volume_muted: false
media_title: Superfly FM
media_artist:
Attributes from the second player:
shuffle: false
sonos_group: media_player.bad
volume_level: 0.13
friendly_name: Bad
entity_picture: /api/media_player_proxy/media_player.bad?token=61c77b9d8b325ae63561a9c872b5b881defa4cb412b030cdab9b1050b62f7252&cache=078729dbdf6a88fe
source: Superfly FM
media_artist:
when ever I can help to test please let me know
Thanks, Iâll see if I can find the bug, Iâll let you know when/if I need help testing, thanks a lot!
BTW, I did open an issue#72 on github for tracking this.
great. thank you
