Found it !!!
I added to the code:
language: 'it'
If i disable it all is working !!
Found it !!!
language: 'it'
Can you post your config for the card (using the format button </> )?
My experience with mini-media-player is this.
I have this configuration withe latest version also of Alexa Media player
- type: custom:mini-media-player
entity: media_player.echo
tts:
platform: alexa
group: true
icon: 'mdi:amazon-alexa'
icon_state: true
hide:
controls: true
entity: media_player.mini
tts:
platform: google
language: it #not necessary
group: true
icon: 'mdi:google-home'
icon_state: true
hide:
controls: true
and it works.
language: it
works only with Google TTS, but itâs not necessary. I get same language, italian, also if there isnât this row.
One main difference is that with Alexa media player the volume slider is alway active and the Power ON/OFF button does nothing, while with Google media player, the volume slider is available only if I turn on the device with the Power ON/OFF button.
I donât think Alexa as media player entities ever turn off, they instead go standby.
You can use the idle view feature to kinda simulate on/off. There are a few options available for the idle_view object, but I think when_standby should work with Alexa as media player, check the card docs for other available options.
idle_view:
when_standby: true
You could I guess also hide the power button if you want as thereâs no on/off for the alexa component
From the source
def turn_off(self):
"""Turn the client off.
While Alexa's do not have on/off capability, we can use this as another
trigger to do updates. For turning off, we can clear media_details.
def turn_on(self):
"""Turn the client on.
Iâm having an unusual issue with the media player card - added it to my configuration yesterday and to begin with it was working fine, however today instead of seeing the cards Iâm just seeing a bit of text that either says âoff noneâ âidle noneâ or âplaying noneâ depending on the state of the player.
When I click on the text it writes to the log:
https://xxxxxxxxx.duckdns.org/local/mini-media-player-bundle.js:1:36259 TypeError: this.value.handleEvent is not a function. (In 'this.value.handleEvent(e)', 'this.value.handleEvent' is undefined)
My lovelace yaml seems pretty normal:
resources:
- url: /local/mini-media-player-bundle.js
type: js
âŠand where configured:
NB I promise indentation is all correct - Iâm sending this from a work computer where proper formatting doesnât want to work for some reason
The only change Iâve made is a global font change but I canât see any reason why that would have scuppered things - Iâll try changing back to the previous font and see if it fixes it and report back
BTW media players are all google cast devices
Iâd like to use the tts feature in my media player card.
This is my config and it works fine like this.
As I donât need the tts feature everyday it would be nice to only see it when I click on the player. Is that possible?
the correct way is
resources:
type: js
Sorry - again, at work PC, not able to copy and paste from configurator. Your correction is what I already have in yaml. Post edited to reflect this
EDIT: Havenât got around to changing fonts yet, but tried adding ?v=0.01 to my url in the lovelace yaml - it briefly worked properly again, then I refreshed the home assistant app on iphone and lost it again. Odd
Yes, skip the cards tts and use the tts input in the default more info popup, which you get to by clicking/pressing on the entity.
Thatâs strange, try replacing type: js
with type: module
, this is obviously not a viable solution if you are dealing with older devices.
When I press the entitiy the pop up window doenât include a tts field.
No matter if a press the entity, the default card or your lovelace card.
I guess the player has to support TTS.
Otherwise, you could use popup-card and create your own popup.
That seems to have worked!
I also have the custom graph card installed, weirdly what seemed to happen before is when one was working, the other wouldnât.
Both behaving correctly now! Many thanks!
It supports tts. Itâs a alexa mediaplayer entitiy.
Awesome, my cards are really built as modules, so importing as type: js
could cause unwanted side effects.
Iâve been experimenting with a new build process for the mini-graph-card, which seems to solve most of these issues.
Okay, I checked the frontend source, and the logic to show/hide the tts input is this.
return !ttsLoaded || !playerObj.supportsPlayMedia;
So the player has to support the play_media service (SUPPORT_PLAY_MEDIA
) in order for the tts input to show up. The custom Alexa as a media player component does not.
But as I mentioned, you could create your own popup with popup-card.
Thanks, ok I will create a popup-card, but should we maybe inform @alandtse about that. It might be easy for him to add this.
so this is weird. im using the exact same code on both of the chromecasts, but 1 isnât showing the artwork:
code card:
artwork: cover
background: /local/media/card_background2.png
entity: media_player.badkamer_boven
type: âcustom:mini-media-playerâ
style:
background-color: ârgba(50,50,50,0.3)â
background-repeat: no-repeat
background-size: 100% 68px
border: âsolid 1px rgba(100,100,100,0.3)â
border-radius: 20px
color: white
type: âcustom:card-modderâ
CODE:
card:
artwork: cover
entity: media_player.slaapkamer_jasper
style:
border-radius: 20px
color: white
Thanks to this nice card Iâve made this:
I can send the text and control the volume on each device.
This is the code
- type: entities
title: Google Home / Alexa
show_header_toggle: false
entities:
entity: media_player.alexa_2
tts:
platform: alexa
idle_view:
when_standby: true
icon_state: true
group: true
hide:
controls: true
entity: media_player.echo_2
tts:
platform: alexa
idle_view:
when_standby: true
group: true
icon_state: true
hide:
controls: true
entity: media_player.googlehome
group: true
icon_state: true
tts:
platform: google
hide:
controls: true
entity: media_player.studio
group: true
icon_state: true
tts:
platform: google
hide:
controls: true
I think most core HA components utilize the play media service to actually play the tts snippets. The custom alexa component does not support play media, Iâm sure there is a good reason for this, hence the custom tts implementation I think?
Weird indeed, is it possible that the second chromecast simply has to artwork available? You can check this by navigating to /dev-state
and see if the chromecast expose the entity_picture
attribute.
Also, please post your yaml in code blocks, and for testing purposes, consider taking out card-modder while debugging.
Looks great!
