0rn0lf
(0rn0lf)
June 13, 2019, 9:01pm
1017
Hey kalkih, i love your card and i hope that i read the notes correctly.
Is it now possible to call a service via shortcut?
I’m trying to play a radio station via tunein on my echo but i cant get it to work with the card.
cards:
- cards: null
entity: media_player.echo_bad
hide:
power_state: false
source: true
more_info: false
shortcuts:
hide_when_off: true
list:
- data:
entity_id: media_player.echo_bad
media_content_type: radio SAW
type: source
- data:
media_content_type: S._W._R. 3
type: source
type: 'custom:mini-media-player'
type: vertical-stack
Sorry for the bad formation. Its from the UI editor.
0rn0lf
(0rn0lf)
June 15, 2019, 1:54pm
1018
ok, nevermind i found the problem. it calls the service now correctly:
cards:
- cards: null
hide:
power_state: false
source: true
more_info: false
shortcuts:
list:
- data:
media_content_id: radio SAW
media_content_type: TUNEIN
type: service
- data:
media_content_id: S._W._R. 3
type: service
- data:
media_content_id: R._P._R. 1
type: service
- cards: null
type: entities
entities:
- entity: input_select.echo_bad_radio
But I found a new problem wihch seems to be Home Assistant related?
It isnt possible to set quotes around the values of media_content_id and media_content_type they get removed. It should be "S._W._R. 3 "
This way Alexa cant understand the radio stations correctly.
kalkih
(Karl Kihlström)
June 16, 2019, 1:24am
1019
Hey @0rn0lf ,
The default shortcut “action” is play_media so you could actually write those shortcuts like this to save some time & lines.
- name: Radio
type: TUNEIN
Yeah, that’s a yaml thing, how it parse strings, but you could try escaping the quotes.
media_content_id: >
"hello world"
or possibly (less likely)
media_content_id: "\u0022hello world\u0022"
EDIT: even simpler:
media_content_id: '"Hello world"'
0rn0lf
(0rn0lf)
June 17, 2019, 2:44pm
1020
thanks. this one seems to work now
xstrex
June 25, 2019, 8:30pm
1021
Great work @kalkih !
For the life of me, I can’t figure out how to theme the idle player though, what am I missing here (the Apple TV element)?
kalkih
(Karl Kihlström)
June 26, 2019, 1:41am
1022
Thanks!
The card background is based on paper-card-background-color atm, will prioritize ha-card-background (if set) in the next version.
https://github.com/kalkih/mini-media-player/commit/24453ec978266a59ba1f4cbd714bf3b5cbe6eb3b
Im having issues grouping my monoprice 6 zone audio system with the mini media player. i think my issue is with the platform section. I can see all media players (all 6) in overlay, but get error "Failed to call service media_player/monoprice_JOIN. Unable to find service media_player/monoprice_join
entities:
- artwork: full-cover
entity: media_player.homecast
group: true
icon: 'mdi:google-home'
scroll_info: true
show_source: true
show_tts: true
tts: google
info: scroll
speaker_group:
platform: monoprice
show_group_count: true
entities:
- entity_id: media_player.living_room_audio
name: Living Room Audio
- entity_id: media_player.bbq_area_audio
- entity_id: media_player.kitchen_audio
- entity_id: media_player.master_bedroom_audio
name: Master Bedroom Audio
- entity_id: media_player.study_audio
- entity_id: media_player.jacuzzi_audio
title: 'Casting Device: Homecast'
show_header_toggle: false
type: entities
I do not think the Monoprice component supports grouping of speakers.
TTS for Alexa has been depreciated, Will you be able to add notify in it’s place?
@kalkih is it possible to integrate monopice 6 zone amplifier into your player like you did with sonos?
kalkih
(Karl Kihlström)
June 26, 2019, 11:57am
1027
Sure, It’s been changed to use notify since v1.0.4.
committed 06:02PM - 12 Mar 19 UTC
I took a quick peek at the component and as @Dansker said, I don’t think it’s possible, sorry.
Bieniu
(Maciek)
July 1, 2019, 10:37am
1028
After update card to version 1.2.1 icons of media players are black. How to change icon color to --state-icon-color without changing any other colors? mini-media-player-base-color change icon color but also some text color.
kalkih
(Karl Kihlström)
July 1, 2019, 12:47pm
1029
Hey, could you provide me with a screenshot of the issue, what is the expected behaviour and what was the behaviour before the update?
Bieniu
(Maciek)
July 1, 2019, 1:16pm
1030
This is media-player-card 1.2.0:
This media-player-card 1.2.1:
And this is media-player-card 1.2.1 with mini-media-player-base-color: 'var(--state-icon-color)' in theme:
I want colors like in 1.2.0 version.
kalkih
(Karl Kihlström)
July 1, 2019, 1:36pm
1031
Thanks for the details, will be fixed in the next version.
https://github.com/kalkih/mini-media-player/commit/dd2d7ca25a43b7d27d34fb5e1165b2dd9bc2e958
The entity icon will be the color of paper-item-icon-color (like the default state-badge), unless mini-media-player-base-color is set.
Do you mind sharing your config for the remote?
krovachek
(Krisztian Borsi)
July 3, 2019, 10:39am
1033
Nothing special. I just used the Mini Media Player based on te documentation with these scripts:
I want to share with you the Kodi remote as I couldn’t find it here.
If someone wants to develop this with me, put your own version here.
To-do list
Playlist button (shows songs from the current playlist or album)
Volume adjustment (for amplifier)
Fast forward and backward
Current track information and picture
Keyboard button
[IMG_0087]
Here’s the code
ui-lovelace.yaml
# Kodi Remote
- title: Kodi
cards:
- type: vertical-stack
cards:
- type: entities
entities:
iantrich
(Ian)
July 4, 2019, 8:13pm
1034
kalkih:
I’m not sure if you are familiar with the google assistant, but you basically feed normal google assistant commands to the assistant relay - “play music on chromecast bathroom”, “play michael jackson from spotify on chromecast kitchen”.
Have you had any issues with some devices not accepting commands from relay? Only a subset of my devices appear to work
kalkih
(Karl Kihlström)
July 4, 2019, 10:32pm
1035
Actually yes, I used it to broadcast messages & start spotify playback on cast devices/groups, but at some point starting playback didn’t function anymore, broadcasting continued to work fine though.
I didn’t really look into it and used this instead, which has been working fine for the last few months.
Probably going to switch to spotcast at some point, since it does seem to support speaker groups now.
iantrich
(Ian)
July 5, 2019, 12:28am
1036
Cool. Thanks for the alternatives
