I added the entity_id and it works like a charm again!
Thanks a lot for your support Karl!
Ok I see! Thanks for clearing that out.
Another thing, im trying to use the shortcut command to change source. I want to change between different Spotify connect outputs somehow. Is that possible? I dont understand what id to use to change to a specific Spotify connect!?
Also, it would have been great if the âpowerâ button could be used for this as well! Like if i press the power button it would change to that input sourceâŠ
As long as the sources show up in the Spotify Component (I guess this is what you are using?), the following should work.
shortcuts:
attribute: source # optional
buttons:
- icon: mdi:cat
type: source
id: Bedroom Speakers # Make sure this matches the exact name of the source
buttons:
- icon: mdi:dog
type: source
id: Bathroom Chromecast # Make sure this matches the exact name of the source
You can find the exact source names by navigating to your HA setup at http://[IP]:[PORT]/developer-tools/state
, look for your Spotify entity and see the source_list
attribute.
This card also has a source select built-in, which should automatically show up if there are sources available.
Thank you! Works perfectâŠ
Would it be possible to use the power button as source selector? It would be perfect for use with multiroom speakersâŠ
Looks good!
Unfortunately not possible, would have to use shortcuts, unless you modify the source code yourself.
Could be made customizable in the future, but not likely.
Ok, but would it be possible to replace the power button with shortcut then? Then the end result would be the sameâŠ
Not possible, unless you modify the source code.
That worked great thank you, i can am trying to move to the progress time (numbers) above the progress bar
i have tried
.mmp-progress {
padding-bottom: 50px !important;
but that doesnât seem to work,
hereâs how its looking so far.
(so far so good)
i welcome any upgrades to the progress bar, I spent hours trying make my own âKodi sliderâ using input number slider and MQTT, and all i achieved was making Kodi get stuck in 1 second loop
This should do the trick
.mmp-progress__duration {
padding-bottom: 50px;
And yeah, might have to add !important
if that doesnât stick.
What kind of upgrades are you looking for?
Ideally, this is the seek bar from yatse (a Kodi android remote) I am trying to get as close to this as possible
I use volume_stateless on a couple of cards. Is it possible to define a step value for the + and - buttons? Essentially, define how much one click increases or decreases the volume?
Alright, so whatâs missing is the ability to drag on the bar to fine adjust the seek position.
Iâve implemented that now, will be included in the next release.
Not possible unfortunately, the card utilize the volume_up
& volume_down
media_player services and they donât have an option for step size, I guess the main reason being thereâs no standardized step size in HA & media players & components handle & compute volume differently.
That looks amazing do you have a donations page?
Tried the below, but the times donât move (mmp-progress__duration) the other CSS is working.
style: |
ha-card {
--paper-progress-height: 60px !important;
.mmp-player {
padding-bottom: 100px !important;
.mmp-progress {
padding: 100px !important;
When using the default theme, the icons set in the card are not anymore shown. What to do to make them visible with the default theme?
Thanks!
Sure, you can press the sponsor button at the top over at github.
Just double checked the style and yes, youâre right, that wonât work, the progress-bar is in something called the shadow DOM, which basically means card-mod canât manipulate it.
Iâll instead implement a theme variable for the progress-bar height, similar to --paper-progress-height
but which will handle and adjust all of the styles necessary (extra card height, time marker position etc).
Hey, I havenât noticed this, checked in Chrome and Safari (MacOS), Iâm still on HA 0.98.0 though.
What browser/operating system & HA version are you having the issue in?
I am running 0.99.3 version of HA and using Chrome on android and MacOs devices. In all the browsers the icons disappearâŠ
I noticed this happens only for the mdi:cast, mdi:google-home and mdi:google icons⊠the others (mdi:speaker-wireless, mdi:spotify) are regularly shownâŠ
This is one of my cards:
- entity: media_player.googlehome5670
type: custom:mini-media-player
group: true
icon: mdi:google-home
artwork: full-cover
max_volume: 60
icon_state: true
tts:
platform: google_translate
language: 'it'
entity_id: media_player.googlehome5670
hide:
power_state: false
power: false
mute: false
volume: false
progress: true
source: true
idle_view:
when_idle: true
when_paused: true
More, i added this in my default theme:
mini-media-player-accent-color: var(--primary-text-color)
mini-media-player-overlay-color: rgba(255, 255, 255, .75)
mini-media-player-artwork-opacity: .25
Maybe is this the cause?
Awesome, amazing Dev! Will that be in the next release?
Thanks, yes it will, could probably do a new release tomorrow.
I upgraded to HA 0.99.3 and tried with your theme and card config and still canât reproduce the issue.
Make sure you have the latest version of the card.
And a tip If you want to debug this further, try to eliminate any potential outside factors; place the card in the root of the view, use the default-default theme, omit any non-required card options etc.
Itâs very strange⊠to the default theme i added only the three lines i posted, i am running the 1.3.1 release of the media player.
