@mitchell The progress bar enhancements is now available in the latest release v1.4.1, let me know how it works.
Regarding the new theme variable for progress bar height
# Two ways of doing it
# in your theme (applies to all mini-media-player cards)
mini-media-player-progress-height: 24px
# or with card-mod (applies to single card)
style: |
:host {
--mini-media-player-progress-height: 24px;
It sure is, and itâs built in.
Check the idle_view option, which will render a simpler more compact view if the player is considered idle, based on the options specified in the idle_view option object.
Example config would be
# ... rest of card config
idle_view:
when_idle: true # Consider idle when entity state equals idle
# if your card doesn't have an "idle" state use `when_paused`.
# Edit: And you can of course use a combination of the two options above and any of the other available options.
Is there any way/feature/option to set a different font-family for this card? I see font_size and font_header, but not a way to set a different fontâŠ
HI - I have exactly same problem - wasted hours with it. Tried everything, type : js instead of module with and without ?v=1.4.1 on the resource url. I even installed a fresh hassio/docker on a VM Ubuntu 18.04 and installed HACS and mini-media-player
Same - âCustom element doesnât exist: mini-media-playerâ
Everything is latest/current version and like you Lovelace/ .storage version
The js files opens fine clicking on âopen pluginâ (localhost:8123/community_plugin/mini-media-player/mini-media-player-bundle.js). Tried on 7 browsers on 3 OS ( BTW Edge on Win10 doesnât show the front end - either on states or Lovelace just a spinning wheel)
I donât get any errors in Console - Browser Inspect
Please let me know if you figured it out . Thanks!
Not sure what the issue could be then, try reinstalling it through HACS, you can check the Network tab in chrome devtools and look for the entry that says mini-media-player..., if you canât find it or if itâs red double check so you have entered the resource reference correctly, and at the correct place.
Edit: you might wanna refresh your ha frontend page while youâre on the network tab for items to show up
I rarely use Chrome but here it is - mini-media-player shows up only once and seems ok - no errors
Installed HACS 2x already on this instance and 1 more on a new fresh install hassio - same
Iâll try again tomorrow or over the weekend - very frustrating
Solved - I uninstalled it and delete everything related to it
I installed 1st another plugin - just to see if that works - Monster card - worked without any problems from the 1st try. So i reinstalled and added on top of the Lovelace raw config
resources:
