Can you tell me how you add Spotify playlist to Sonos buttons? Can you share the code?
Ofcourse, You just have to add the Spotify playlist to your āMy Sonosā, So you do that inside the Sonos app itself. When you have them there as playlists you just put the buttons in your player. Iāve 2 players (1 for ground floor, 1 for 1st floor):
artwork: cover
entity: media_player.sonos_upstairs
group: true
hide:
power: true
source: true
info: short
shortcuts:
buttons:
- id: Qmusic
type: source
- id: '538'
type: source
- id: Sky Radio 101 FM
type: source
- id: SLAM!
type: source
- id: Mijn Shazam-nummers
type: source
- id: 360 Dance
type: source
columns: 4
source: icon
speaker_group:
entities:
- entity_id: media_player.sonos_upstairs
- entity_id: media_player.sonos_downstairs
platform: sonos
show_group_count: true
type: 'custom:mini-media-player'
Those Shazam-nummers and 360 Dance are the spotify playlists Iāve available in the Sonos app. The name must be exactly the same as over there.
Hi there,
in order to help others i explain how i configured a remote for my sony bravia android tv.
After having installed the Sony integration in hassio integration (normal procedure) and HACS with the mini media player integration, i tried as the procedure explains to add to ui-lovalace.yaml my script for the remote but unfortunately didnāt work.
Then i tried to modify my bravia media player modifying the code from the user interface.
i wrote:
entity: media_player.sony_bravia_tv
info: long
artwork: cover
hide:
mute: false
icon: false
power_state: false
replace_mute: false
shortcuts:
buttons:
- id: Netflix
icon: mdi:netflix
type: source
- id: 'Sky TG24'
type: source
- id: 'Rai 1'
type: source
- id: 'Rai 2'
type: source
- id: 'Prime Video'
type: source
Rebooting Home assistant i ended up having a great media player!!
Iām all new to hass.io. Your mini-media-player rocks! Thanks for the hard work.
Is there any chance to putt the background of the mini-media-player like the general mediaplayer?
It has the artwork cover on the right side en it uses the same color of the artwork left border on the left side.
Many thanks.
Iād love to see that option too.
Itās also the style adopted by Chrome for media control. it would give a more modern look in my opinion.
Hope this feature request can be taken into account !
Is there a way to fix the height of the card?
When Iām clicking buttons in the view sometimes the media title briefly vanishes and the card gets smaller so all the buttons move.
Would be good if the height could be fixed so the layout didnāt jump around.
If Iāve missed an easy way to day this. Please let me know.
Thanks.
Awesome card. really cool.
Would it be possible to add Beolink as a platform? BeoLink (Bang & Olufsen)
I would be happy to test for you
Assuming BeoLink creates a media_player entity, MMP should just be able to use that. Have you tried adding the media player to the card?
Yes it is a normal media_player and works fine for standalone player. The issue is with multiroom as MMP only supports some platforms.
EDIT: Solved. Seems like you cant just copy-past the config for a manual card I had to delete all the spaces etc.
Installed this via HACS on Hass.io and I always get an error when trying to make a card
- type: 'custom:mini-media-player'
entity: media_player.spotify_MYSPOTIFYNAME
icon: 'mdi:spotify'
artwork: cover
hide:
volume: true
source: true
power_state: false
The resource installed itself in ā/hacsfiles/mini-media-player/mini-media-player-bundle.jsā and seems to work because HACS shows the little green box next to your plugin
Has anyone tried using mini-media-player with current development releases of Home Assistant (version 0.111.0.dev)? All of the icons are broken for me. Other cards are working fine, even ones which use the same icon.
Itās a known issue, the Home Assistant 0.110 release totally changes the way icons are handled, most custom cards are going to have to update. Hereās the GitHub issue that you can subscribe to.
Awesome, thank you.
There has to be group management support in the backend component before I can add support for the platform in the card, thatās why only a limited number of platforms are currently supported (multriroom).
Will fix this weekend.
@kalkih are you aware of the changes to squeezebox that will be in 0.110? There will be ability to add to groups etc. I hope we can get that into your card.
I can point you to the PRs once I am not posting from my retarded tablet.
Thanks for reply. The products can do multiroom, by the dedicated app or remote. But how to find out if it is compatible? The link to the other tread i provided, talks about multiroom.
Hello Dear
I have updated Home Assistant 0.110.0b2 .then media player controllers not showing .
see the below image
before there is play ,next, previous , volume and buttons etc ā¦
now only icon and speaker name ā¦
how can i fix this issue
Very nice card !
With tons of optionsā¦
Is there a showcase for the layouts available in a different topic to get inspired by?
What are the settings to get it like that? Any idea?
I would like it so that it shows the cover of the movie playing (thats automatic i know) but when itās idle, or the player is unavailable, i would like to show a static pic, is that possible?
Especially the last āunavailableā
Iām not aware, yes, please link me.
What component are you using?
Fixed in the latest release of this card
That screenshot is not of this card. Thatās the old core media card if Iām not wrong
Use the artwork option to display the cover artwork, and the background option for the idle background.
