I searched the thread but could not find - does anyone know offhand what the platform for the google home speakers is?
It seems to work without the correct configuration, but I’m unable to manually select or deselect speakers for group membership as the xxx/join service is not found.
It’s not a huge issue, it works when I have them all in the yaml, I just can’t do it on the fly.
I just have a bunch of different speaker groups set up in Google and then select the group within HA (from an input_select) depending on where I want music
I just found new love for this card, thank you Karl!
Using a mix of different hide options, grouping, conditionals and custom:stack-in-card I have a super tidy card that only shows which speakers are in use and gives me volume control in each area. I had this for a while but it wasn’t as compact until now. Loving it
Below is example from the github page, where to find the id for the Spotify playlist?
Does it have to be a playlist? Can it be just a specific song(and how to find the id)?
but I added one player, my office, in the exclude section
- entity_id: media_player.myoffice
Though it worked perfectly in not showing my playing zone, every 2-5 minutes the zone would pause all on it’s own. The log simply showed that the zone was paused, but no user associated with the pause, nor was there any automations or events or scenes that even referenced this player.
I went and deleted the exclude and I haven’t had a pause in 45 minutes.
This is probably not a mini media player issue, more likely an auto-entity card problem, but figured I’d post this in case someone else has the same issue.
Oh, I thought you were using the Spotify integration, what media player are you trying to do this on?
The Spotify integration is the only media player integration that I’m aware of which supports Spotify URIs through the play_media service.
Hello I am a new user of Home Assistant and was just wondering if this was possible…
It probably is and is easy to set up but i’m struggling to find a solution that works for me.
I have set up the spotify integration, as well as the yamaha integration.
So I have two media players … media_player.yamaha_receiver and media_player.spotify_
How do I get spotify to play on the yamaha receiver?? (The Yamaha Receiver has spotify connect built-in)
I’ve managed to get spotify to play on the current device showing home assistant UI, but not on the Yamaha. I’m sure this is really easy i just cant get round the YAML needed to achieve this…
