That is not mini-media-player is it?
Yes, it is of âtype: custom:mini-media-playerâ that I have in a browser_mod.popup.
Then I think the support thread for that is what you want.
Ok, posted in browser_mod support. Thanks.
That looks strange, mini-media-player does not display the state, so I guess the media player state is not off and the media information is reported as off? What integration is the media player using?
You could try the idle_view options I guess when_paused
might work?
How do I integrate stateful switches as shortcuts?
E.g. I would like to integrate the buttons inside the media player card but canât figure out how to show their states
Below are 3 renderings:
- Left is right on the view.yaml
- Middle is via a browser_mod.popup
- Right is via a browser_mod.popup and lovelace_gen macro
Left - observe that âOffâ does not show under the âNook Speakerâ media player.
Middle - again, observe that âOffâ does not show under the âNook Speakerâ media player.
Right - now, observe that âOffâ shows under the âNook Speakerâ media player.
How do I remove the state text? I tried the media_player idle_view options but no luck.
I will post in lovelace_gen.
Maybe you should post your yaml code instead of posting pictures on different threads. That way people can see your actual code an help you. Your card looks a lot more like entity card, not mini-media-player. Please post your code of that card.
Here is the code:
# lovelace_gen
{% macro tap_action_entities(entity) -%}
- entity: {{ entity }}
{% if media_player %}
type: 'custom:mini-media-player'
group: true
{% else %}
tap_action:
action: none
{% endif %}
{%- endmacro %}
title: Test
path: test
panel: true
icon: ''
cards:
- type: custom:layout-card
layout: vertical
cards:
- type: entities
entities:
- entity: 'switch.gosund_dc4f229cc629_relay_2'
- entity: 'media_player.nook_speaker'
group: true
- break
- type: entities
entities:
- type: 'custom:button-card'
name: "via browser_mod.popup"
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: " "
card:
type: entities
show_header_toggle: false
entities:
group: true
deviceID:
- this
- break
- type: entities
entities:
name: "via browser_mod.popup and lovelace_gen macro"
tap_action:
service_data:
title: " "
card:
type: entities
entities:
{{ tap_action_entities('switch.gosund_dc4f229cc629_relay_2') }}
{{ tap_action_entities('media_player.nook_speaker') }}
deviceID:
- this
Ok, Iâve never used lovelace_gen but just from looking at the screenshots and code Iâm pretty confident in saying this is a lovelace_gen configuration issue and would recommend continuing this discussion in the lovelace_gen thread.
Youâre most likely not rendering a mini-media-player card but instead just a normal entity row of the media player, that would explain the look of the card. You can pretty easily confirm this by inspecting the card in the browser developer tools (right click, inspect element) and look for the element name.
Or manually by specifying some specific mini-media-player options to the card and see if they are applied in the card or not.
First of all,
Thank you for this awesome media player.
If have add one for my sonos speakers and using the grouping ability, iâm able to add my other speakers to whatâs currently playing.
But with one speaker being the master, i need a card for each sonos speaker, in order to play the other speakers individually. Is there a way to change the cards entity (master speaker) using a media shortcut button?
Iâm sure this is somewhere in the posts above but there are so many and basic terms are hard to search for and narrow down. I have two questions.
first one. Is there a way for me to show which source is currently playing. I see the music song/artist, but Iâd like to show which source is playing.
Here is what Iâm working on
Iâd like to know which of these stations is playing. My preference would be to highlight the button of the station playing,but I suspect that might be a bit tricky. Iâd still be happy if it could show somewhere in the player.
Second question. In idle view can I display an image, or just a backround color of my choice. I cannot see the settings for what to add to idle_view, just how to turn it on.
I found that hiding the volume also hid the input.
hide:
icon: true
next: true
power: true
power_state: true
prev: true
volume: true
Shows the info above
Removing the hide volume gets me this
I am second for this, iâd really like an option for both your questionsâŠ
Hiding either volume and/or controls will collapse the card into a more âcompact modeâ, this does by default hide the source & only displays the icon, use the option source: full
to override this and display the full source name.
To highlight the active shortcut, see the below link (examples inside).
Did you try the background
option?
How can i make the mediaplayer background transparent when nothing is playing?
i tried many things but im pretty new to this! =)
how to install it
By reading and following the instructions (linked in the first post). https://github.com/kalkih/mini-media-player#install
no, itâs not working
Why not use a conditional card? You can insert the mini media card inside a conditional card and hide it when state is off. It will be hidden completely when nothing is playing/paused.
