I can’t get name: false to work either
This card addon had been brilliant if it worked
Tried without space (shouldn’t work I suppose) and then the whole sub-entity dissapeared:
On your 1st picture you specified nothing for the “name” option.
2nd picture: spaces are obligatory.
1st picture was to show when it said something was wrong
Got help and the problem was I missed entity: at beginning of row above name-tag
type: entities
entities:
- entity: sensor.forrad_trh_temperature
type: custom:multiple-entity-row
secondary_info: last-changed
entities:
- entity: sensor.forrad_trh_humidity
Thanks for trying to help!
Seems that it was not just “trying to help” ))) Close the issue on GitHub then as it was advised. - DONE
aha… same person who actually helped me in the other place - then I should have said: THANKS! Problem solved
(I think I managed to close the other ticket)
Hi! How can I change the icon color based on an attribute value of a template sensor?
type: entities
title: Aree
entities:
- entity: sensor.area_cancelli
icon: mdi:gate
show_state: false
entities:
- attribute: disinserito
icon: mdi:lock-off
tap_action:
action: call-service
service: switch.turn_on
service_data:
entity_id: switch.partitionswitch_cancelli_disinserisci
styles: ????
I would like icon of Disinserito to be green if attribute disinserito
of sensor.area_cancelli
is 1, gray if 0. Possibly without using config-template-card.
Thanks for helping!
card-mod thread → 1st post → link at the bottom → styles for multiple-entity-row
Thanks. I already did read your post, but there’s nothing similar to my case. I want to change the color icon of an - attribute
respect to its value, not respect the state of the main entity.
And what is a difference here?!
Use state_attr() instead of states().
Sure, that was not the problem. I was not able to find the right CSS selector. I will check with more attention.
You may style a color of the main icon & “secondary” icons as well.
Check that post I mentioned.
Found it. Thanks.
type: entities
title: Area cancelli
entities:
icon: mdi:gate
show_state: false
secondary_info: last-updated
style:
hui-generic-entity-row:
state-badge {
color: orange;
div.entity:nth-child(1) state-badge {
{% set COLOR = "#14ce17" if state_attr("sensor.area_cancelli","disinserito") else "#bdbbbb" %}
color: {{COLOR}};
Hello, somebodye mantain a forked version of this beautiful card with improvments and corrections" ?
Does anyone know how I can change the displayed state of a binary sensor with device_class
‘lock’, so that it shows locked
and unlocked
instead of off
and on
- entity: sensor.cupra_born_state_of_charge
icon: mdi:car-electric
state_header: Charge
card_mod:
style: |
:host {
--paper-item-icon-color:
{% if (states(config.entity)|float(333)) <= 20 %} red
{% elif (states(config.entity)|float(333)) <= 30 %} orange
{% else %} #30BC3F
{% endif %};
--card-mod-icon:
{% if is_state('sensor.myenergi_zappi_XXXXXXXX_status','charging') %} mdi:car-electric
{% else %} mdi:car
{% endif %};
entities:
- entity: binary_sensor.cupra_born_overall_status
- entity: sensor.cupra_born_range_in_miles
tune up yourself
- type: entities
entities:
- entity: weather.buienradar
card_mod:
style:
hui-generic-entity-row $: |
.info {
display: none;
toggle: false
show_state: false
state_color: false
entities:
- entity: sensor.buienradar_temperature
- entity: sensor.buienradar_wind_force
- entity: sensor.buienradar_wind_direction
- entity: sensor.buienradar_pressure
- entity: sensor.buienradar_precipitation
- entity: sensor.buienradar_goes_irradiance
- entity: sensor.buienradar_humidity
shows like:
and Ive tried/experimented with the justify-content etc.but still the names dont show on the same horizontal line.
Do we have a magic property for that?
you are doing a wonderful job and I thank you very much. that’s great.
I too would have liked to know how to make the windows appear as “open” and not “on”
Thanks a lot
Can you pls help to see why my code isnt working? It is not showing the secondary info for the multiple-row entities… here s the code
type: entities
entities:
- entity: group.doors_kids
style: |
:host .entities-row {
justify-content: flex-start;
align-items: unset;
:host .entities-row div.entity:nth-child(1) div::after {
color: var(--secondary-text-color);
font-size: 0.7rem;
content: "\A {{relative_time(strptime(states.binary_sensor.fal_d.last_changed,"%H:%M:%S %d/%m/%Y"))}}";
white-space: pre;
:host .entities-row div.entity:nth-child(2) div::after {
font-size: 0.7rem;
content: "\A {{relative_time(strptime(states.binary_sensor.faf_d.last_changed,"%H:%M:%S %d/%m/%Y"))}}";
white-space: pre;
:host .entities-row div.entity:nth-child(3) div::after {
font-size: 0.7rem;
content: "\A {{relative_time(strptime(states.binary_sensor.fay_d.last_changed,"%H:%M:%S %d/%m/%Y"))}}";
white-space: pre;
state_color: true
show_state: false
entities:
- entity: binary_sensor.fal_d
icon: mdi:door
state_color: true
- entity: binary_sensor.faf_d
icon: mdi:door
state_color: true
- entity: binary_sensor.fay_d
icon: mdi:door
state_color: true
I m trying to get it to show the last changed under the door icon for the 3 entities. Can you please see why it doesnt work?
Your templates are wrong.
Check them in Dev tools → Templates.
Also, your color style will not work w/o “!important”
Also, placing "
inside "
is wrong.
forgot to post the answer to that quest:
.entities-row {
align-items: start !important;
width: 100%;
justify-content: space-evenly !important;
and have it show perfectly like:
thx Ildar and Arganto
Hi - I am struggling to customize icons based on state when using type: custom:multiple-entity-row
type: entities
entities:
- entity: switch.g0294_block_ufh_circulation_pump
name: Block UFH Circulation Pump
show_state: false
icon: mdi:block-helper
state_color: true
tap_action:
service: button.press
entity_id: switch.g0294_block_ufh_circulation_pump
entities:
- entity: binary_sensor.status_ufh_circulation_pump
type: custom:button-card
state:
- value: 'off'
icon: mdi:autorenew-off
- value: 'on'
icon: mdi:autorenew
icon: mdi:autorenew
state_color: true
state:
- value: 'off'
- value: 'on'
icon: mdi:autorenew
the last entity displays the status of a circulation pump, which is either off or on. based on the status value I would like the icon to be different.
Thanks,
Martin
