Lovelace: Multiple entity row
Multiple Entity Row
Show multiple entity states or attributes on entity rows in Home Assistant’s Lovelace UI.
See the Github page for installation and configuration.
Features
  • Show multiple additional entity states on a standard entity row
  • Show attribute value instead of state (from any entity)
  • Any entity or attribute value as secondary_info
  • Show toggle (for switch, light, etc)
  • Hide default entity state to only show additional entities
  • Customize name and unit on additional entity object
  • Customize default entity row as you would any other
  • Custom tap actions on all entities (e.g. service calls)
  • Icons instead of entity states
Example
type: entities
entities:
  - entity: sensor.bedroom_temperature
    type: custom:multiple-entity-row
    entities:
      - sensor.bedroom_min_temp
      - sensor.bedroom_max_temp
      - entity: sensor.bedroom_humidity
Thanks a lot! I’ll give it a try!
This is really GREAT card!!!
Especially for letting show attributes!
What is the correct word to use for a third attribute after primary and secondary?
(Disregard, it looks like those are all states)
Well, great implementation!
Do you think is possible to adapt it to a picture against an entity?
I my case I would like to implement a picture entity for my person.name adding attributes like position + battery + whatever without using picture-elements.
It currently only supports two additional entity states or attributes. This is mostly because there is such a limited space for rendering things in between the default entity name and state.
Most likely possible, but my current custom card development experience doesn’t extend past the generic entity rows. I might have a look at other cards some time in the future.
@benct Very very useful for showing attributes! Thank you !
Is there any way that I can set the name using an attribute? ( just one way to show more attributes)
Thank you!
Are you using the card described in this thread? From the image it looks like you are using my other earlier card, attribute-entity-row.
I have just added support for using an attribute as the name on the attribute-entity-row card. Doing the same for multiple-entity-row will involve a bit more work…
Oops. You are right. Sorry about that. Thanks a lot.
I am using a name (one of the attributes) as:
however this does not seem to work. any suggestions?
name_attribute: country
Perfect! thank you @benct
I did notice that the icon isn’t an option, but it also does not take my customized icon. any idea?
Great additional card. I wondered whether there is any way to include input_* entities? At present it seems not to be possible, and only suitable for sensors, right? Is there any way I can use input* entities, more specifically in my case input_datetime entitities? This type of card would be great to specify intervals for a schedule. Putting start and stop items each at their own row works, but is both not very intuitive and takes up a lot of room.
It is possible in my configuration that looks like this:
temperature and humidity sensors are displayed as badges?
THX.
Excellent addition, but i do notice a small problem. The switch or the states do not update after any changes. Forcing a browser refresh does make the change. Any ideas, has anyone else found the problem?
Im running into the same issue as Carl, my switch states are flicking back to off and then not updating:
Imgur
Also would it be possible to integrate other custom cards such as the lock-entity as above?
Sorry for the late reply, I’ve been abroad for quite a while.
No, I’m afraid not.
This issue was also reported on github and I released a fix for this last week. Sorry again for it taking such a long time.
Unfortunately, it will not be possible to easily integrate other custom cards just like that. I might be able to add support for a lock-entity mechanism in some future release.
updated and everything now ok. Thanks. Brilliant addition.
Thanks a lot for this nice addition. :slight_smile:
I was already trying to build something like that on my own.
Using it to display a table-like card for temperatures of all rooms and the outside temperature.
As I also want to quickly see the relative humidity in the rooms and the absolute humidtiy everywhere to decide if it’ a good idea to open the windows, this solves my needs perfectly.
