Assume you have
– alpha
– bravo
– charley
– delta
columns.
Any of these parameters may become “unavailable” or just equal to “bad”.
And you need to show a “N/A” value for these cases.
Then use smth like
hide_unavailable: true
hide_if:
value:
- bad
default: N/A
for each column.
Sure, if each column may have own “bad values” - you need to specify these “bad values” for each column.
LotusHenry
(Lotus Henry)
December 9, 2023, 6:42pm
411
Thanks a lot Ildar, that does the job!
Am i able to change the text above each column values for icons
I’m trying to make it look like the plant status card but I would like more than one plant on the same card
Why not placing them in a stack?
dyfcom
(Tetra)
January 29, 2024, 6:16pm
414
Hey,
I want to added padding around the mutiple-entity-row, but I don’t get padding working.
type: custom:stack-in-card
cards:
- type: custom:multiple-entity-row
entities:
- entity: sensor.openweathermap_humidity
- entity: sensor.openweathermap_temperature
entity: sensor.openweathermap_condition
toggle: false
show_state: false
state_color: true
styles: |
.hui-generic-entity-row {
padding: 12px;
When I use the development tool, it is working.
Can someone tell me, what I am doing wrong?
Thanks and Greetings
ladaowner
(Ladaowner)
February 11, 2024, 12:10pm
415
with the code below i get
however pressing the button the toggle button does unlock the door (just once) but the toggle activates twice. example press toogle and it will go on/off/on/off not just off
changing - entity: sensor.door_lock to a light.whatever and the toggle activates just once
why??
secondary_info: last-changed
toggle: true
state_color: true
entities:
ladaowner:
why??
Using a toggle for a sensor which is unsupported, that is why.
ladaowner
(Ladaowner)
February 11, 2024, 12:41pm
417
sorry typo sensor.door_lock should have been writen as lock.front_door
- entity: lock.front_door
toggle: true
state_color: true
entities:
but still doing the same, toggle activating twice
Place the lock entity as a standard entity-row inside Entities card - will it behave the same?
Do you have any automations related to this “lock” which may cause it to “toggle twice”?
Checked with same config:
type: entities
entities:
- entity: lock.virtual_front_door_lock
toggle: true
state_color: true
entities:
- entity: sun.sun
and see no “toggle twice” glitch.
ladaowner
(Ladaowner)
February 11, 2024, 1:08pm
419
wiped out my automation.yaml rebooted and tested and still getting same
ladaowner
(Ladaowner)
February 11, 2024, 1:27pm
420
renamed to lock to front_door1 and it stopped happening so code myside.
ladaowner
(Ladaowner)
February 11, 2024, 2:29pm
421
still messed up.
Changing to
- entity: lock.tesla_model_3_doors
and the toggle works with out a double glitch.
calling nuki_lock from anywhere not the toggle button I get no glitch, however if I use the toggle I get the double glitch.
setting up a card for multiple temp (related) sensors in a decluttering-template, I am a bit puzzled why the
boolean for hide_unavailable: true
doesnt work:
card:
entity: sensor.[[id]]_hygro_temp_temperature
state_header: Temp
entities:
- entity: sensor.[[id]]_hygro_temp_humidity
- entity: sensor.[[id]]_hygro_temp_battery
secondary_info:
entity: sensor.[[id]]_hygro_temp_signal_strength
it’s not the decluttering template, because I’ve also tested the verbose config with the same entity_id, and it shows identically:
please have a look? thx!
update
bte, his does work, core conditional on the same entity:
card:
type: conditional
conditions:
- entity: sensor.[[id]]_hygro_temp_temperature
state_not: unavailable
card:
# hide_unavailable: true
state_header: Temp
<<: &width
styles:
width: 60px
text-align: center
entities:
<<: *width
<<: *width
secondary_info:
sparkydave
(🇦🇺 Dave)
February 14, 2024, 3:21am
423
Is there a way to prevent this last entity from showing the value in both columns? I’d like to just have the temperature inline with the other above and then a blank space where the humidity’s are listed because this location only has temp, not humidity.
type: entities
entities:
- entity: sensor.lounge_multisensor_air_temperature
entities:
- entity: sensor.lounge_multisensor_humidity
show_state: false
- entity: sensor.ensuite_ms6_air_temperature
entities:
- entity: sensor.ensuite_ms6_humidity
show_state: false
- entity: sensor.kitchen_ms6_air_temperature
entities:
- entity: sensor.kitchen_ms6_humidity
show_state: false
- entity: sensor.passage_ms6_air_temperature
entities:
- entity: sensor.passage_ms6_humidity
show_state: false
- entity: sensor.gym_multisensor_air_temperature
entities:
- entity: sensor.gym_multisensor_humidity
show_state: false
- entity: sensor.garage_multisensor_air_temperature_2
entities:
- entity: sensor.garage_multisensor_humidity_2
show_state: false
- entity: sensor.nspanel2_temperature
entities:
title: House Temps & Humidity
show_header_toggle: false
Howdy!
Want the first name not to be truncated. Can i have it maybe next line text? Maybe any custom css can help? but me and gpt doesnt know which
trallan
(karl)
March 11, 2024, 7:40pm
426
I recently integrated my vacuum cleaner. It has MQTT and gives the following:
However I would like to try and put the brush time next to the button instead. This works but is a bit ugly. Is it possible to make it a button or clickable text instead somehow?
Spalya
(Spalya)
March 13, 2024, 9:01am
427
Hi, instead of second entity of temperature sensor use input_text.text with blank text and style: width 50px for this entity
- entity: input_text.text
styles:
width: 55px
text-align: right
Unfortunately that didn’t work.
Spalya
(Spalya)
March 14, 2024, 10:17pm
429
Strange… Did you define input_text in Helpers?
entities:
- entity: sensor.t_h_sensor_1_temperature
format: precision0
unit: "°"
styles:
width: 35px
text-align: right
styles:
width: 30px
