I’m running into an issue with the more-info dialog in my Home Assistant setup. I’m using multiple-entity-row v4.5.1, and despite configuring the tap_action to show the dialog for climate.hmip_eg_kueche_wt, it always defaults to sensor.heizgruppe_eg_kueche_custom.
Tapping on Red - does not work, tapping on Green - does.
The standard generic-entity-row (part of this custom card) does not support overridden entity for more-info, but it will change & resolve the issue hopefully.
Update: this functionality was added in HA 2024.11.
HI,
I am using custom:auto-entities along with custom:multiple-entity-row and want to show the upcoming event dates in “YYYY-MM-DD” format without the time, … I tried this
type: custom:auto-entities
card:
type: entities
title: Kommende Geburtstage 🎂
filter:
include:
- entity_id: sensor.anniversary*
options:
type: custom:multiple-entity-row
unit: Tage
entity: this.entity_id
entities:
- attribute: current_years
unit: Jahre
- attribute: next_date
format: date
sort:
method: state
numeric: true
count: 10
which at least seems to be syntactical correct, but it generates:
which is not exactly what I tried to do. It seems to be pretty easy, as I really could not find any solution here in this epic thread; but I also do overlook the butter in our fridge.
Thank you for a hint/solution or pointer.
Juergen
Hi @Ildar_Gabdullin ,
tried before, did not achieve it. I can live with what I see. Clumsy, but if this is the way it has to be, I can/have to live with it.
thank you
Juergen
Finally trying the Multiple Row Entry on one of my dashboards. I would like to include the battery level icon along the % level on the same line. When using a TILE CARD config all I need is the entity specified and I get the sensor name, % of charge and the colored icon that will change as the level drops. Is there some special CSS formatting or card_mod I need to set to have the corrrect icon show next to the %?
Thanks, John.
You have a wrong syntax - show_state is only supported for the main entity.
To show an icon for an additional entity, use “icon: true”.
It is all described in docs.
I had tried the icon: true before but the color was constant. What I needed was state_color: true along witk icon: true. I missed that keyword. Thanks…
I had similar need (but needed unrelated icon) and solved by using separate entity just for icon and colored it with card_mod. This way you can choose colors and have as many states as you need.
