Getting a little frustrated. I have been running behind on HA and still have my main setup on 0.89.2. In this version, when a door is left open an alert will show up on my main HA screen. I also have an alert setup to email/gmail me.
I have setup a current 0.100.3 version I am trying to migrate to but cannot get these previous alerts to work.
1st issue: no auto alert. I added a card but it doesn’t give me the option to turn it off. If I click to open it, there is a switch but it always reverts to on.
I have tried without using the ‘secrets’ just in case. The old HA (89.2) still works with the original settings so I am guessing I am missing something that changed in one of the versions. Any thoughts?
Try changing your sensor to a binary sensor, this has the advantage of using device classes which make the icons pretty and take care of the states (open/closed) for you. Note though that in templates you still use on/off states for the binary sensor rather than what the device class displays in the frontend:
Check the open state message is ‘1’. I guessed. The template needs to resolve true for ‘open’. If there are many messages for open and you can only use the closed state in teh template, use this value template:
value_template: "{{ not is_state('sensor.garaged_alarm_level', '0') }}"
Either way your alert becomes:
garage_door:
name: Garage Door is open
entity_id: binary_sensor.gdstatus
state: 'on'
repeat:
- 5
- 30
- 60
can_acknowledge: True
skip_first: True
notifiers:
- gmail
