Hi I need some help, I have an older iPad which is eating dust at the moment and I have worked quite some time to set up a beautiful lovelace interface. The problem that I face now is that my iPad can’t load the custom cards (I have tried setting javascript to latest, but if I use that I won’t even come at the login screen).
Is there any way to load these lovelace cards for older devices that use es5? I imagine it is not possible at all, but if there would be any way (even if it was a bit hacky).
I’d rather not rebuild it with states UI or use a less suited for my situation solution like HAdashboard or Tileboard (my lovelace setup is built with tablets in mind)
Any help is appreciated.
